Old 01-04-2011, 11:56 PM   #1
maruksai
Member#: 233276
2009 2.5i Hatch
Default Is the EJ253 is on oil?
I'm a bit confused as to if the 2.5 NA engine is hard on oil. I have read verious threads on BITOG "bobistheoilguy" that include comments from many people to use the cheapest oil as long as it's in the proper grade. I have read on here that the 2.5 gets a lot hotter than a standard inline 4. What's right?
maruksai is offline   Reply With Quote
Old 01-05-2011, 12:02 AM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Cheap is fine, just stay on top of your intervals.
chazly413 is offline   Reply With Quote
Old 01-05-2011, 08:43 AM   #3
maruksai
Member#: 233276
2009 2.5i Hatch
What about using the weird oil brands at a Dollar Store? I think it's called Accel?
Old 01-05-2011, 09:12 AM   #4
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Generally speaking, subies consume oil more than most cars. There's nothing wrong it's just the nature of the beast. A lot of people will rant and rave about what brand oil "works best"...for them. However the general concensus is Rotella seems to burn off less than other brands do. Personally, I found Castrol 0W-30 runs best in my car. However I'm also running an air/oil separator so that helps a bit as well. My advice is to try a few of the perfered oil brands for our cars and see what your motor likes best. It's also a very good idea to keep an extra quart in the car.
treksofar is offline   Reply With Quote
Old 01-05-2011, 09:47 AM   #5
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I would probably stay away from Dollar Store engine oil. You can get a good brand oil for about $2-$3 per quart. Pennzoil is only $2.59 a quart at Target. 0W-XX is probably the best for cold weather. It flows better when cold.
As far as oil consumption, until I started getting some valve cover gasket leaks, I never used any oil. It doesnt burn any oil since I had all my engine seals replaced. I always put 4 quarts in and get 4 quarts out when i change it.
Samirr76 is offline   Reply With Quote
Old 01-05-2011, 09:52 AM   #6
kpotzmann
Member#: 215454
2005 9-2x Aero
Walmart FTW.... 5quart Mobil clean 5000 5w30 $11.50
Inexpensive oil makes me more likely to short change intervals. I start thinking about it around 3000 and it is usually changed by 3300
kpotzmann is offline   Reply With Quote
Old 01-05-2011, 09:58 AM   #7
Samirr76
Member#: 4835
2003 Baja 5MT
Yeah Walmart is pretty cheap on brand name oil.
Old 01-05-2011, 01:39 PM   #8
chazly413
Member#: 151079
2005 2.5RS RBP
I'm talking Pennzoil yellow bottle cheap. As far as synthetics go, you're not dealing with real synthetics until you get to the $12 a quart ****.
Old 01-05-2011, 04:00 PM   #9
cmiovino
Member#: 134005
2004 WRX Premium
I use Quaker State High Mileage from Walmart... $13.50.. gets the job done.
Old 01-05-2011, 04:21 PM   #10
GEE-OTTO
Member#: 201277
2009 Legacy GT
I used 5w-40 only b/c ive got 76K on my 2008 before that I used Quaker State 5w-30 (for 50K miles)
GEE-OTTO is offline   Reply With Quote
Old 01-10-2011, 04:03 PM   #11
Str8cypherm80
Member#: 202129
2012 WRX Hatch
Ice Silver Metallic
ROYAL PURPLE+K&N filter FTW. cost an arm and a leg but put my mind at ease.
Str8cypherm80 is offline   Reply With Quote
Old 01-10-2011, 04:22 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
Subaru's don't necessarily nor have to burn oil. Random manufacturing tolerances sort of makes it hit or miss. However, a good builder and a rebuilt motor to tight tolerances can make it burn virtually nothing, even the turbo cars.
Is the up-pipe on a wrx my04 the same as on a sti my04 ? as7r080y Newbies & FAQs 8 07-01-2008 06:01 PM
What size is the torque bolt on the injectors on an 05 STi? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-10-2006 03:40 PM
What wire is the remote turn-on lead on the stock HU? Bankie Car Audio, Video & Security 2 12-03-2003 08:52 PM
What is the stock GL-5 oil in the STi transmission? boxerT Transmission (AT/MT) & Driveline 4 11-12-2003 06:42 PM
What is the purpose of an oil pressure gauge? redobs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-01-2002 12:59 AM
