Old 01-05-2011, 07:44 AM   #1
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Default Speedometer reads zero MPH
1999 Legacy GT 5-speed with less than 80,000 miles.
It happens intermittently although it seems to happen more and more often... possibly related to cold weather.
Has anyone else had this problem, and if so what did you do to fix it ?
Yes, I should have done a search, but I am not sure what keywords to use.
Thanks !
Jonathan is offline   Reply With Quote
Old 01-05-2011, 09:26 AM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Does it happen when you're stopped?
Samirr76 is offline   Reply With Quote
Old 01-05-2011, 10:02 AM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I think I've heard something about water/loose connections on the speed sensor/wiring. That's where i'd start.
fibuz is offline   Reply With Quote
Old 01-05-2011, 02:54 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Mine will do it once in a while also. It seems related to colder temps, but it normally snaps back in a minute.
DLC is offline   Reply With Quote
Old 01-05-2011, 09:11 PM   #5
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
Happened to me recently. Replacing the speed sensor on top of the tranny fixed it.
Btw if left unfixed like I did the ECU goes into limp mode.
bangedlegacywagon97 is offline   Reply With Quote
Old 01-06-2011, 04:10 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Interestingly enough, when stopped, it appears to consistently read Zero MPH.
This is as it should.
Its when its reading ZERO and I am traveling along at perhaps 40-50 MPH and I see a speed limit 45 MPH sign and there is a cop behind me, that I get nervous as I don't really know how fast I am traveling.
Old 01-06-2011, 07:30 PM   #7
droppedOB
Member#: 251101
BSM
second on the speed sensor. i picked one up at autozone for 120ish bucks but im sure its cheaper at rockauto. fixed it completely!
droppedOB is offline   Reply With Quote
Old 01-07-2012, 08:08 PM   #8
namdoogttam
Member#: 306178
1999 Subaru Forester
Red
Default Try this first!
This seems to be a very common problem with the 1999's.
Before you buy anything, I recommend trying the no-cost fix in this video first: www.youtube.com/watch?v=jNP-lnHB2RY
I had an intermittently working speedometer/odometer for 11 months. It drive me mad because I was trying to keep track of mileage while it wasn't working, which was on-and-off all the time. Oh, not to mention the fact that you have no idea how fast you're going.
namdoogttam is offline   Reply With Quote
Speedometer Reads 3-5 MPH fast....Help Izero Interior & Exterior Modification 39 05-11-2010 10:37 AM
Oil pressure reading zero biglongdong Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-19-2010 09:41 AM
Varying speedometer readings - 07 STI capnchunk Service & Maintenance 4 01-23-2008 12:51 PM
VAC on boost gauge reads zero, boost 30PSI stock!!! xS2k Electrical & Lighting 12 10-23-2005 12:06 AM
Speedometer reading difference STi-Nismo Dood Transmission (AT/MT) & Driveline 2 04-22-2004 08:15 PM
