Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 01-05-2011, 09:14 PM   #1
mitsumodder
Member#: 134441
Default 1997 2.2l cam plug leak
I have a 1997 Impreza 2.2l. There is a "cam hole plug" on the rear of the left/driver side head. It is leaking oil. I ordered the part but can't find any info on removal and installation. Help?
mitsumodder is offline   Reply With Quote
Old 01-06-2011, 12:37 PM   #2
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Ouch that sucks, i replaced mine when i did my cams but i had my engine out. I had the valve covers off and took out the rocker assembly out before you can get the camshaft plugs out. You can do it in the car but with that limited work room and having to take out the battery, washer tank, radiator and timing belt, it's was just easier to take the whole engine out. just make sure you get the Subaru liquid gasket along with the new plug to make sure it doesn't leak again. I'll pm you my instructions for the cams, it will give you an idea at least. I'll check around and see if there is an easier way because it seems like a lot of work of a plug that can leak.
aclver1 is offline   Reply With Quote
Old 01-06-2011, 06:10 PM   #3
mitsumodder
Member#: 134441
Well, I have a few things going for me. I'm a mechanic and this is one of the only problems with the powertrain at 270k miles. I was hoping someone would say you can pop it out the back of the motor and install a new one with a special tool.
You never said if you took the plug out twords the inside of the motor or if it pops out the outside back of the head.
Thanks for the help.
2.2L cam gears and 2.5L cam gears newsuby2211 Normally Aspirated Powertrain 7 09-22-2010 09:09 PM
1997 2.2l awd drivetrain. chris sanborn Drivetrain 2 04-11-2008 11:35 AM
Anyone Done A 1997 2.2l To 98 2.5rs??? TurboCharged97L Subaru Conversions 6 09-03-2006 09:41 PM
WTB: 1997 2.2L Impreza L Wiring Harness odogg Private 'Wanted' Classifieds 0 09-29-2005 10:50 PM
('93-'01) K&N Part number for 1997 2.2L Impreza L? CirrusWRX Impreza Forum 4 08-20-2004 09:30 AM
