Welcome to the North American Subaru Impreza Owners Club Saturday November 21, 2009
Old 07-07-2002, 10:30 PM   #1
Mach5WRX
Member#: 17060
Question NX Ntercooler=Better 1/4mile time?
I've seen some old posts about this...http://www.nitrousexpress.com/produc...=31101&loc=101
Has anyone used/seen this used recently on a WRX. I'd like to pick this kit up. I think it would kick booty for use here in hot/humid Hawaii.
Mach5WRX is offline   Reply With Quote
Old 07-08-2002, 01:15 AM   #2
Ronin2121
Member#: 13798
02 Wrx
Cool
If you are going to spend the cash. Put the nitrous into your engine instead of on your i/c and you can be sure to have a bigger smile.
Ronin2121 is offline   Reply With Quote
Old 07-08-2002, 01:19 AM   #3
SubyRex
Member#: 10794
2002 Impreza WRX
13.47 @ 98.98MPH
Bingo, then add the water spray kit for those hot/humid Hawaiian days and put ice cold water in the bottle
SubyRex is offline   Reply With Quote
Old 07-08-2002, 02:35 PM   #4
Mach5WRX
Member#: 17060
I don't want to spray nitrous on my intercooler, I want to spray CO2. As fas as a water spary kit, I've looked around and I think this set up would work better. Oh well can't hurt to try it out.
Old 07-08-2002, 02:43 PM   #5
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
I'm working on mine right now. Going to use a paintball cyl and a nitrous solenoid. Should be able to put one together for under $100. Anyhow, some guy in a white rex (didn't get his name), was using a homebrew setup based on a nos kit. Had a piece of drilled tubing mounted to his intercooler that sprayed down. Iced up the IC very quickly. His times sure were convincing, especially when you consider the mid-upper 90's temps and high humidity.
jb
jimb is offline   Reply With Quote
Old 07-08-2002, 03:09 PM   #6
Mach5WRX
Member#: 17060
I was thinking of using a cheap nitrous kit and a burner from a gas BBQ I found at Sears.
Old 07-08-2002, 03:23 PM   #7
Carlo
Member#: 18376
367 WHP!
460 HP at the crank!
Damn, dude, you stole my idea. Give it back
Carlo
Carlo is offline   Reply With Quote
Old 07-08-2002, 03:39 PM   #8
Mach5WRX
Member#: 17060
Great minds think alike
Old 07-08-2002, 03:46 PM   #9
Leonardo
Cowabunga!!!
Super Moderator
Member#: 185
2005 Legacy GT wagon
CFR SCCA ESP #17
True, but I'll make min to spray the top and the bottom so it's well iced, cuz if you spray the top, the bottom is still hot.
Leo
Leonardo is offline   Reply With Quote
Old 07-09-2002, 12:51 AM   #10
Mach5WRX
Member#: 17060
Should be fine if you don't do a crap load of runs all at one time.
Old 07-09-2002, 11:27 AM   #11
tmarcel
Member#: 7555
Default Co2
The benefits of running CO2 over the IC should be far more COST effective vs. NO2 with similar results I would think.
tmarcel is offline   Reply With Quote
Old 07-11-2002, 07:02 PM   #12
Mach5WRX
Member#: 17060
Well my mind is made up. I'm going to get this kit. Anyone know where I can pick one up for cheap?
The only place I can find this kit is on the nopi web site, and they want $80 to ship it to me!
Old 07-11-2002, 08:30 PM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 XT6 AWD/Auto
Default Re: Co2
Why do you say this? I'm ignorant of this CO2 stuff. I looked here and it states that CO2 is $5.00 per lb. Nitrous costs me $4.00 a lb. Of course cost varies. Also, the website I provided said this:
"DoT regulations and Compressed Gas Association standards state that all tanks, steel or aluminum, used for the storage of CO2 which measure over 2 inches in diameter must be hyrdostatically tested every five years.
Hydrostatic testing consists of inserting the tank into a water filled containment vessel and increasing the pressure to five-thirds (5/3) of it's rated pressure. If the tank fails, as in the picture to the right, it does so in the water filled container designed to contain the blast."
Nitrous bottles do not need to be hydrostatically tested.
Again, I'm ignorant of all the CO2 stuff so I am posting these questions. Thanks for any feedback.
Kevin Thomas is offline   Reply With Quote
Old 07-11-2002, 08:43 PM   #14
ChicksDigWagons
Member#: 20508
1997 Green OBS
Turbo coming...NOW!
I can pick up 20oz of Co2 at my local paintball place for $5, you can pick up a 50Lbs bottle for ~$50+$100 deposit I think for the bottle. Last I checked nitrous was $40 to fill up a 10lbs bottle.
Plus Co2 is much more widely availible. As for the Hydrostatic testing, it's just regulation. Co2 is very safe to handle, the gas is typically around 800psi, and most tanks have a burst pressure far in excess of 3000psi, with a 2000psi burst valve. Plus you can pick up empty tanks for cheap and they are highly availible.
I'm also pretty sure No2 tanks need to be certified in the same manner as Co2 tanks, especially if exposed to high (125 degree) tempratures.
Thats my contribution.
ChicksDigWagons is offline   Reply With Quote
Old 07-11-2002, 10:10 PM   #15
RobPA
Guest
Member#:
What if any way could you actually spray the CO2 in a "Regulated maner??? is there a co2 "Sprayer" i would like to do this rather then icing the intercooler, i really like this idea but how would you phsyically "Spray" it??
Rob
Old 07-11-2002, 10:42 PM   #16
Mach5WRX
Member#: 17060
Rob
Click on the link on the first post
Old 07-11-2002, 10:48 PM   #17
Mach5WRX
Member#: 17060
Default Re: Re: Co2
This kit is made by Nitrous Express. It comes with..... - Complete kit including 5lb bottle, stainless steel bottle brackets, 16ft -4 feed line custom intercooler discharge ring, nitrous solenoid, arming switch, push button and installation hardware.
The bottle is a normal 5lb compressed gas bottle.
Old 07-12-2002, 02:19 PM   #18
Mach5WRX
Member#: 17060
Here's a picture of the kit.
Old 07-12-2002, 02:28 PM   #19
Dori Dori
Member#: 6780
1993 Nissan
A friend of mine has it down here in South Fl.
I'm not going to post the difference in times b/c I know a lot of you will flame and call me a liar...I'll just say that the difference in times was more than I thought they would be and that it was done on the same night, back to back and that I was there.
Dori Dori is offline   Reply With Quote
Old 07-12-2002, 02:52 PM   #20
Mach5WRX
Member#: 17060
Where did he get it from?
Old 07-12-2002, 03:04 PM   #21
tmarcel
Member#: 7555
Okay so now that we've established that the Co2 is less expensive, then how would one piece a kit together? I wonder if the Nitrous Express kit could utilize Co2 in the bottle rather than the No2?
This would make since if that would work. Otherwise, you would have to re-invent the wheel and source the parts.
Old 07-12-2002, 03:20 PM   #22
Dori Dori
Member#: 6780
1993 Nissan
He's a vendor...so probably a distributor...but I'm not sure at all.
Old 07-12-2002, 04:12 PM   #23
Mach5WRX
Member#: 17060
From the NX web site.....For supercharged or turbo applications where nitrous is not an option, NX offers another alternative, the “N-tercooler”. Using either nitrous or "CO2" this unit can reduce air inlet temperatures dramatically. In a recent dyno test, a turbocharged Honda, equipped with an NX “N-tercooler ”, increased its baseline by an astounding 52 horsepower! If it makes horsepower, it must be Nitrous Express!
Old 07-12-2002, 04:14 PM   #24
Mach5WRX
Member#: 17060
If some people want this kit, let's do a "group buy". Anyone up for that?
Old 07-12-2002, 05:18 PM   #25
digga
Member#: 21310
I am interested in a group buy depending on how much cheaper the cost will be
digga is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:06 PM.
