Old 07-07-2002, 11:10 PM   #1
HpiRally
Member#: 3864
Question Oil Catch Can Installation?
Anybody have some pictures of theirs installed and how it is done? Any help is appreciated.
I have a MY98 RS just to let ya know.
Joe
HpiRally is offline   Reply With Quote
Old 07-10-2002, 12:19 AM   #2
Section 8
Member#: 821
If you want pictures, search "catch can" and look for the threads with paperclips in the title. THere was quite an extensive thread with many pictures a few months back.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-10-2002, 01:46 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I've been interested in this too.......I've done a search......have not found anything with any sort of pics and such......
Legacy777 is offline   Reply With Quote
Old 07-10-2002, 02:27 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Here's my setup. You have to remove the stock intake and relocate the MAP sensor (If you look, it's just to the left of the catchcan.) Works fine. I have 2 more bungs to weld into the can for the valve cover breathers.
Eric
Eric SS is offline   Reply With Quote
Old 07-10-2002, 02:28 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
pic 2
Old 07-10-2002, 02:30 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
One more thing, the nice thing is that all the holes are existing including the holes where I mounted the catchcan and the holes for the MAP sensor.
Eric
Old 07-10-2002, 03:13 PM   #7
Legacy777
Member#: 4800
Interesting setup........
Old 07-10-2002, 04:25 PM   #8
kickin_81
Member#: 16679
2004 Forester XT
Yes, interesting....
What does it do?
kickin_81 is offline   Reply With Quote
Old 07-10-2002, 05:12 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
What does it do?
It catches oil instead of recirculating it through the intake.
Eric
Old 07-10-2002, 05:28 PM   #10
jeffg
Member#: 2958
2001 6.0?RS
Eric
Just so you know that is not the MAP sensor. That is the ambient air temp sensor. You map is bolted to the top of your intake manifold, right behind the throttle body.
J
jeffg is offline   Reply With Quote
Old 07-10-2002, 05:31 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
J
Really?? hehe.. I guess you learn something new everyday.
I'm not even sure why I thought it was the MAP.
Eric
Old 07-11-2002, 12:28 AM   #12
Jademonkey
Member#: 9213
2000 RS
Red
Why do you need an oil catch can on a NA car?
Jademonkey is offline   Reply With Quote
Old 07-11-2002, 01:21 AM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
My car is Turbo.
Eric
Old 07-11-2002, 11:14 AM   #14
Section 8
Member#: 821
The same reason why you want it on a turbo car. In an ideal world you would not need a catchcan at all becasue ail would stay where it should and not splash around. A turbo car has more blow-by than a NA car (assuming equal build engines, ie no bad rings ect) so it has the capasity to blow more oil out of the engine breathers. NA cars can still suck oil out of the breathers, but usually not in the same quantities. A car with modified suspention, tires and brakes can move oil around more as well and case it to escape into the breathers. If your intake feels oily on the inside near the ports, you could use a catch can to keep it out of your intake.
cheeRS,
Greg
Old 07-11-2002, 11:25 AM   #15
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
I have one included with my Rallispec intake.
GooseMan is offline   Reply With Quote
Old 07-11-2002, 12:42 PM   #16
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Originally posted by ciper
Imprezinator: I guess you havent seen a screwed up IAC yet becuase of crap running through it from the crank.
Even with an 8 inch elevation from the crank (not counting the valve covers) there is alot of oil being sucked through those pipes. With subarus unusual (in my mind) design of a pcv valve that is bypassed through the intake before the throttle place it only makes it worse.
I'm not trying to be rude but can you clarify what you are talking about? I don;t understand. I don't have any oil recirculating through my intake. not even PCV. And I've never heard of an IAC going bad from oil either but I don't do a lot of Subaru work.
Eric
Old 07-11-2002, 01:53 PM   #17
Legacy777
Member#: 4800
You're really not sucking any oil through the IAC valve. All the vent & PCV hoses go in past the IAC valve air pickup. It does get carbon'd up a little, and a little slimey due to the fact it's right under the PCV stuff.
Old 07-11-2002, 02:30 PM   #18
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Sorry my brain was on backwards today, I was think throttle plate when I said IAC!
The crank vent goes to a T connection, one of which is on the pcv valve and the other is directly into the intake before the throttle plate. Any time you have a vacumn most of the oil goes through the intkake. This happens alot at idle when the throttle plate is mostly closed. Both carbon dust and oil gets stuck to the plate, and probably everything else.
Old 08-20-2002, 12:11 PM   #19
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Wouldn't having a catch can mess things up a little? it seems the oil/oil vapor recollection system needs vacuum to work properly. With the catch can, there's no vacuum since the intake is left out.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-20-2002, 12:19 PM   #20
Section 8
Member#: 821
The catch can is connected to all of the breathers AND the intake to generate vacuum. It is "inline" so to say with what is already there. Your not changing anything, you are just adding a collection tank. Just like adding an air water seperator to a compressor line.
You need to make sure that you connect your vacuum line before the turbo (if you have one).
cheeRS,
Greg
Old 08-20-2002, 12:36 PM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
My idea of the routing for the catch can would be that it matches exactly that of an engine without one, just the can is inline.
From that image I see a filter on the top. Either there is no vacuum to draw the air out of the crank case and valve covers or he is introducing additional air into the intake that runs through the catch can. I only see one line entering the catch can, did you T the crank case and valve covers together? How is the PCV valve functioning? It seems that instead of a filter on top you should have a hose plumbed back into the intake before the turbo.
Either way I still cant figure out why there is a filter on top of the catch can, I always thought the crankcase and valve covers werent supposed to be postive pressre (vacuum or equal to atmosphere)? Seems like if the catch can and its filter is in any way restrictive you would be putting pressure on the oil pan gasket and on the valve cover gaskets, couldnt that lead to leaks?
Edit: Perhaps I need to study the piping on the turbo engine, maybe I have missed something?
Old 08-20-2002, 03:19 PM   #22
Section 8
Member#: 821
Oh! in the picture!!!
I would always plumb it back to the intake. You can run it with out it just fine (as alot of people do) but it is best to keep as much of a vacuum in the crank case as you can.
Some people belive there to be gains to venting your crankcase to the atmosphere, this is a VERY minimal gain in a modern, properly running engine. If you have a worn out engine with lots of blow by, you can see good gains becasue you are getting more air instead of engine exhaust from the blowby in the crank case. You would have much better performance by replacing the rings, than venting to the atmosphere.
I have a friend with a ~76 Bronco, and when we took off the breather from the filter pan, it was like a second exhaust pipe emptying into his intake tract.
cheeRS,
Greg
My Greddy oil catch can install mattjk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 01-07-2007 07:59 PM
oil catch can installation? OoAcHuToO Newbies & FAQs 2 11-20-2002 06:36 PM
Definitive Tread for Oil Catch Can Install. Gil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-20-2002 05:07 PM
Check out my oil catch can install jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 07-30-2002 11:50 AM
cant find the cusco oil catch can install WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-08-2002 09:40 PM
