Old 12-22-2010, 05:54 PM   #1
97ej22
Member#: 255912
1997 impreza outback
white
Default thinking about doing a swap i need help
I have a 97 obw what would be the best motor/trans swap for the buck
97ej22 is offline   Reply With Quote
Old 12-23-2010, 10:03 AM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
There really isn't a cheap option with swaps.
Probably the least expensive would be to find an '02 WRX EJ205 with transmission and rear diff. You also need all of the electrical harness and the ECU (or an aftermarket ECU).
Give east coast swappers a call, they can help you out.
Wrong forum BTW. There is a conversions forum that contains everything about swaps.
Old 12-25-2010, 12:06 AM   #3
psychorunner
Member#: 226568
2002 Bugeye STI
best bang for your buck in the end is getting a good deal on a totalled donor car weather it be a WRX or STI. If you buy parts from here and there you will get nickle and dimed to death IMO at least.
psychorunner is offline   Reply With Quote
Old 12-25-2010, 01:22 AM   #4
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
I'm in the middle of swapping a jdm wrx into my 97 ob biggest pain so far is pulling the dash out down to the firewall to remove the harness. RiteWire is making my life easier in the harness merge. So far it's just like leggo.
CBXJ is offline   Reply With Quote
Old 12-28-2010, 07:08 AM   #5
FLUBYUx2
Member#: 3856
2001 Impreza 2.5RS
sedona red pearl
Any more info on this? Did you need help with the merge because the swap is out of a gd model, not a gc/gm? I was searching and saw that a v3-v6 jdm swap only needed extended on the harness behind the dash. Once it was lengthened, it would plug in to everything?
FLUBYUx2 is offline   Reply With Quote
Old 01-05-2011, 05:11 PM   #6
ZapBrannigan
Member#: 251356
My swap was like lego for a while, enjoy it
ZapBrannigan is offline   Reply With Quote
Old 01-06-2011, 12:04 PM   #7
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
I sent my wires off to RiteWire (they sorta part of east coast swappers). the ECU's are totally different (plug wise) between the 97 leggy and the 97 JDM WRX donor, so I'm letting them do that part. As mentioned the dash is a pain, not hard, just tedious, I changed my crossmember to an STI one, turns out (or so I'm told) IF I had got a pre 05 crossmember my steering rack from my leggy would have bolted up, however I got an 05 and that meant changing the rack and adapting my steering shaft to teh STI rack, it's not all bad though, I end up with a quicker ratio rack. Cooling wise I'm going to try with my stock leggy rad (I'm in Alberta it never gets that hot here, so maybe I wont have heat problems)... just add the fitting for the extra plumbing... anyway so far so good.. (easy to say since it's not all back together yet).. lemme know if you want any pics, or updates, I can do that..
Old 01-09-2011, 01:29 AM   #8
BrianMB
Member#: 176104
2005 STI
sorry I posted a bit late in your thread there CBXJ, click for link, but if they still have your wiring make sure to be asking a ton of questions and make sure you are getting what you ask and pay for.
BrianMB is offline   Reply With Quote
So you're thinking about doing a swap... Zaider Subaru Conversions 15 06-20-2011 02:32 PM
*** do I do about my Buddy Club exhaust!!!! Need help now! 03twrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-17-2005 03:10 AM
Thinking about doing a WRX front brake swap on my RS...Questions WRC1 Brakes, Steering & Suspension 0 05-04-2005 03:13 PM
Thinking about doing an unusual motor swap... sperry Subaru Conversions 10 10-01-2003 02:00 PM
doing EJ20 swap soon need help! TSimpreza Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-09-2002 04:36 PM
