Old 01-07-2011, 03:40 PM   #1
ryno50485
Member#: 79878
05 Impreza 2.5 RS
SRR
Default Idle issue! 05RS
First off i searched the forum and no one really had an answer to this issue...my car just recently had the speed sensor go bad.. when the CEL was read and then reset my car would idle so low that it would stall out at every stop sign. Had this problem before when i bought a new battery.. but it eventually fixed itself..
When they checked the CEL it threw 2 codes for the MAF low input and Intake Air Temp high input.. I tested my MAF by swapping it with an identical one that was on my buddy's car.. no change.. Thoroughly cleaned the MAF and throttle plate as well as the Intake Air Temp sensor.. Still no change!
I then put in brand new NGK plugs along with NGK wires.. bought them from the Subaru Dealer.. Still nothing changed..
Does anyone know whats going on? i have read that other people had the same issue but no one seems to know a solution. Thanks! Ryan
ryno50485 is offline   Reply With Quote
Old 01-07-2011, 03:53 PM   #2
colorfull
Member#: 136688
2005 Impreza RS
When you reset the ECU (i.e delete codes or disconnect the battery), you need to turn the car on and let it idle for aproximately 10mn without touching the gas pedal.
The 2005+ imprezas have an electric throttle, so the ECU needs to re-learn a bunch of parameters every time you reset it.
Try it out: reset the ECU by disconnecting the battery, then let it idle for 10mn. The car should idle just fine after that.
colorfull is offline   Reply With Quote
Old 01-07-2011, 05:50 PM   #3
ryno50485
Member#: 79878
05 Impreza 2.5 RS
SRR
Thanks man i'll give it a shot.
Old 01-07-2011, 05:51 PM   #4
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Let it idle until the radiator fan comes on - should be about 10 minutes as mentioned above, but might be more.
mslstixx is offline   Reply With Quote
Old 01-07-2011, 06:01 PM   #5
ryno50485
Member#: 79878
05 Impreza 2.5 RS
SRR
the fan automatically comes on when i start the car because my ecu is in limp mode from the CEL for the Speedometer gear that isn't fixed yet.. which is a whole other issue but yea i asked the dealership as well as a few friends if the two issues were related and they said probably not ...
Old 01-07-2011, 06:28 PM   #6
ryno50485
Member#: 79878
05 Impreza 2.5 RS
SRR
hey thanks guys! that did the trick! apparently i didn't let it idle long enough before
Jumping idle issues, any ideas? Also fueling issues. roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-20-2009 11:32 AM
weird idle issue...not average idle stuff slingshot Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-25-2006 04:24 PM
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Idling Issues KTB Warranty Issues & SOA Problems 7 04-17-2002 08:00 PM
Long overdue update on idle issue plus website info :) Warp3 South East Region Forum 4 01-17-2001 07:38 PM
