#1 |
Member#: 198830
I had my helper take the motor apart and he did not mark the belt to reinstall. I want to make sure its on correct so what do I do?
#2 |
Member#: 94350
NESIC
what car? You can count teeth and mark them yourself. I know the 1.8 is 44 teeth and 40.5. from left to crank then to right cam, I believe 2.2 is the same.
#3 |
Member#: 198830
its a single cam 2.5 98 legacy. Thats what I was hoping for do you think those #s are the same?
#4 |
Member#: 268990
What 98 2.5 was a single cam? I thought that they were all DOHC setups until the 3 or 4th gens....
#5 |
Member#: 28685
Vehicle:2004 FXT 4EAT very STi'd |
If it's single cam, it's 2.2 liters.
How old is the belt? Unless it's practically new, I'd go ahead and replace it. They're quite cheap. |
#6 |
Member#: 198830
It was a 96 sorry. I got it figured out runs good. Thanks for the help.
| Thread Tools | |
| Display Modes | |
| hyperco springs with no markings? | nhat | Brakes, Steering & Suspension | 9 | 09-23-2012 08:04 AM |
| Help! Timing Belt Install, stuck on the... you know, install | RS-Flyboy | Normally Aspirated Powertrain | 11 | 07-09-2009 01:03 PM |
| Timing belt install?? | AK'S REX | Factory 2.0L Turbo Powertrain | 2 | 05-15-2004 12:18 PM |
| Timing belt installation for a PE belt? | IA Performance | Factory 2.0L Turbo Powertrain | 9 | 10-27-2003 03:45 PM |
| 02 WRX timing belt install after crash | cky211 | Service & Maintenance | 1 | 12-28-2002 11:25 PM |
