Old 07-08-2002, 01:40 AM   #1
christoph1371
Member#: 1090
Default My Outback Super Sport
Just put this
In This
christoph1371 is offline   Reply With Quote
Old 07-08-2002, 01:44 AM   #2
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
.....................and.......................
HOK is offline   Reply With Quote
Old 07-08-2002, 01:45 AM   #3
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Talking
................results...........
Old 07-08-2002, 02:04 AM   #4
christoph1371
Member#: 1090
Dyno day soon to come. But 1st I must get it smogged Tomorrow is the day when I meet the CA state referee with my salvage motor Vin/receipt in hand. Wish me luck
Old 07-08-2002, 09:02 AM   #5
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Looks like a US WRX engine and upgrades to speak of? I'm guessing your running samco hoses at minimum.. hopefully better than stock exhaust too.
I'd like to see some pics of it installed in the car!
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 07-08-2002, 11:42 AM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I love it! If I had the money, I would do the same thing, and if my RS ever go totalled from behind, I want the 2.5L going into an OBS. Good job, can't wait to see the dyno on it, and good luck with the smog police.
HondaH8er is offline   Reply With Quote
Old 07-08-2002, 12:19 PM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Yes!
Good luck my OBS friend.
Kevin Thomas is offline   Reply With Quote
Old 07-08-2002, 02:48 PM   #8
christoph1371
Member#: 1090
mods now:
samco hoses, jdm upipe, FP turbo, Exedy clutch and flywheel, Prodrive GT suspension, 18mm rear sway, and '99 RS rear disc brakes.
After smog:
willwood front 4-pots, 565 injectors, walbro fuel pump, our own turbo back exhaust and LINK.
After I buy my house:
a new paint job (grey or red haven't decided), top and bottom rear spoilers, front and rear wrx/sti seats, and running boards
Old 07-09-2002, 05:07 AM   #9
XT6Wagon
Member#: 524
04 STi
Looks like someone forgot to get a Turbo transmission while they were at it.
XT6Wagon is offline   Reply With Quote
Old 07-09-2002, 05:26 AM   #10
christoph1371
Member#: 1090
Sorry to dissapoint you. I left the 2.2 tranny in on purpose.
I have already used a 2.5 tranny in another conversion plus a 2.0 tranny. I want to see what this one can do. So far, this tranny suit my neds best. Short 1-3 gears(rs style) and long top 4,5 (wrx style).
This is a happy medium for now
Old 07-09-2002, 10:24 AM   #11
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
are you telling me that the ratios for 1-3 gears on the outback 2.2 tranny are same as the RS and 4,5 are the WRX?
Old 07-09-2002, 03:39 PM   #12
christoph1371
Member#: 1090
NO not all gears are the same. the first three are closer to the RS than the WRX and the last two are closer to the WRX then the RS.
Here is the tale of the tape:
2.2 manual tranny gear ratios
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - .780
Final 3.900
Old 07-09-2002, 03:54 PM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
damn maybe i should put that tranny in my car.... i always hit the rev limit JUST at the beggining of the end of the 1/4 so i lose a lot of time trying to chnage into 5th which i never get in anyways cause i miss it... i tried even changing each gear earlier and still was just done letting the clutch out and the 1/4 was done..
Old 07-10-2002, 10:09 AM   #14
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
HOK you could change your final drive. Since your profile says you have an RS, then your current final drive is 4.11 so change your ring and pinion gears to 3.90. However your in Hong Kong so I'm confused if you have an RS (didn't know they offered them there).
either way go up in your final drive
4.44 --> 4.11
4.11 --> 3.90
and if you're at 3.90, then I think there are some 3.65's out there somewhere. If you've got standard gear ratios and you're hitting 5th with 3.90 final drive in the 1/4 mile.. your car is damn fast!
Jon
Old 07-10-2002, 10:21 AM   #15
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - .780
final 3.900
I was under the impression that these are the 2.2L N/A gear ratios
1st - 3.545
2nd - 1.947
3rd - 1.366
4th - 0.972
5th - 0.780
final drive ratio - 3.90
What you have listed is RS gears, except for the final drive.
1st - 3.545
2nd - 2.111
3rd - 1.448
4th - 1.088
5th - 0.780
reverse - 3.333
final drive ratio - 4.11
Have you proven that maybe the OBS gears are different than standard 2.2L impreza's? Where did you get your info?
My info comes from here: Gear Ratio Reference Thread
Old 07-10-2002, 11:29 AM   #16
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Jon
The SVX uses a 3.54:1 final drive ratio.
wawazat is offline   Reply With Quote
Old 07-10-2002, 12:33 PM   #17
christoph1371
Member#: 1090
Hmmm. interesting omahasubaru. I pulled my data from alldata.com
I have a subscription there for my obs. I get all my online data, for that yr/model, there on the site. Perhaps I read the wrong colum. I will double check and post the pic ASAP.
Old 07-10-2002, 01:06 PM   #18
christoph1371
Member#: 1090
Here is what I found for my 2.2 1997 obs:
Old 07-10-2002, 02:13 PM   #19
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
thanks omaha... isn't a big deal to change the final drive crack the bell housing open and all that... ? i have an RS you are correct... I'm in Hong Kong for work and stuff and the car is back home in canada...
yea my gears are all standard we are all surprised i havn't blown the tranny yet... knock knock... i was just thinking since i was in hong kong i could get a tranny or something adn bring it back or change my driving or something... how about wheel diameter? you think that would help?
Old 07-10-2002, 03:19 PM   #20
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
tire size helps, but what your looking for is more gear, not less so that wouldn't really work out for you. final drive would be where I'd start and put it to 3.90
Tell you want I'm looking for 4.11 ring & pinion set, if you have someone in Canada who can pull them out for you they can send them to me I'll swap them in and send back the 3.90 ring & pinion set from my car.
Then we'll both be happy! and withought paying $600 to get new ring/pinion sets.
Jon
Old 07-11-2002, 02:35 AM   #21
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
tempting offer... i'm in hong kong now.... so i can't do much to the car anytime soon... sorry... but why don't you see if you can find a wrecked car and get the tranny...
Old 07-11-2002, 05:17 AM   #22
XT6Wagon
Member#: 524
04 STi
Heh, there is also 3.70's, but from wha tI can tell the 3.70 & 3.90 use one pinion and the 4.111 & 4.444 use a different one. SO I imagine going from a 4.111 to a 3.90 would be the most expensive since you would need a new pinion and ring gear.
Lighting mods for my Outback Sport? mummer43 Interior & Exterior Modification 5 10-10-2006 11:14 PM
Question about noise my outback sport is making...... chillington General Community 5 09-11-2005 02:00 PM
Introducing the Outback Super Sport christoph1371 Bay Area Impreza Club Forum -- BAIC 35 07-09-2002 09:51 PM
Opinons on Lowering my Outback Sport FlooredSubaru Brakes, Steering & Suspension 1 01-31-2002 08:36 AM
I love my Pirelli P7000 Super Sport 25psi Brakes, Steering & Suspension 11 02-24-2001 12:03 AM
