Old 01-08-2011, 08:27 AM   #1
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Possible problems with rear main seal install
I just removed and installed a new rear main seal while changing my clutch at 145k. when I poped it in with the a 4" pvc coupler, it seated much deeper than it was when I pulled it out. Is this going to be a problem?
cdigerlando is offline   Reply With Quote
Old 01-08-2011, 09:34 AM   #2
ocei77
Member#: 119726
yes.
It should be flush or just a little in from rear of crankcase.
O.
ocei77 is offline   Reply With Quote
Old 01-08-2011, 10:34 AM   #3
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Thanks for the reply.
Damn. I wonder how i'm going to back this thing out without damaging it now. pisses me off because they always show you hammering these thinks in. I wonder if the oil pressure will push it back into position?
Old 01-08-2011, 11:16 AM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
oil pressure will not push it into the correct position. you will most likely have to tear this one out and get a new one, they're not that expensive.
Old 01-08-2011, 11:56 AM   #5
Feign
Member#: 68604
06 STi
Yep, remove and replace unless you can get it out without any damage (highly unlikely).
Feign is offline   Reply With Quote
Old 01-13-2011, 02:53 PM   #6
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Seal
Thanks. Removed and replaced. Hopefully for the last time.
Possible problem with rear diff paintbing Transmission (AT/MT) & Driveline 7 03-01-2010 10:12 PM
A little problem with rear sway bar install, please help. SubieSubie Brakes, Steering & Suspension 8 07-31-2008 06:01 PM
Rear Main Seal problem rivman05 Service & Maintenance 2 12-01-2007 08:02 AM
MAIC! Need install help: rear main seal in Legacy Siper2 Mid Atlantic Impreza Club -- MAIC 15 09-16-2005 08:12 AM
Installing a clutch? Why not throw in a new rear main seal. Tim Sanderson Transmission (AT/MT) & Driveline 0 07-08-2004 10:02 AM
