Old 01-08-2011, 01:32 PM   #1
rdn2fst
Member#: 257699
2006 Impreza WRX STi
Default Cobb OTS maps HWG and LWG
I'm checking to see if i'm interpreting this correctly
HWG OTS descriptions say "2 for vehicles unable to hit target boost using standard Stage 2 map"
LWG OTS descriptions say"for vehicles that over boost using the standard Stage 2 map"
So, my car has a Blouch turbo and I know I need a protune but i'm trying to buy just a few days of safer driving before that happens.
Is the LWG map not the correct map to use for a turbo that is boosting higher than i want? it's hitting 22.6PSI and I'd be happier if it were topping out at 19PSI. LWG is the map i should use, right?
i have a blouch turbo (not sure which one), and a TurboXS turbo back exhaust along with a TurboXS uppipe. ..and a crappy Injen short tram intake with perrin inlet tube. ...stock ebcs.
rdn2fst is offline   Reply With Quote
Old 01-08-2011, 01:34 PM   #2
rdn2fst
Member#: 257699
im just confused because i read that the waste gate is normally closed so in my mind i would think the HWG (heavy waste gate) would be the map that holds the waste gate open more so as to releive boost. ...confused noob here.
Old 01-08-2011, 02:27 PM   #3
arghx7
Member#: 232940
Stop boosting. You could blow your engine up. Limp the car to a tuner.
arghx7 is offline   Reply With Quote
Old 01-08-2011, 02:57 PM   #4
jmikolich
Member#: 210165
HWG = High Waste Gate and is referring to the duty cycle, not the "heavy"
and the only SAFE thing is to limp the car to a tuner.. 3k RPM or less, no boosting.
Do you have Wideband 02? if not, completely forget about boosting you could blow your car up and not even think anything is wrong... bye bye ringlands.
jmikolich is offline   Reply With Quote
Old 01-08-2011, 07:06 PM   #5
Tripintaz
Member#: 245218
2013 STI Limited
Load the LWG map and stay out of boost and get to a tuner. If you try going into boost on an OTS map with your mods you have a decent chance at damaging the motor.
Tripintaz is offline   Reply With Quote
Old 01-09-2011, 10:24 AM   #6
rdn2fst
Member#: 257699
i appreciate your responses. I know i need to get it to a tuner and i will very soon. im just checking to see if there's any way that i can turn the boost down via the cobb before i get there.
...I'll just drive it like i'm grandpa
Old 01-09-2011, 03:30 PM   #7
Tripintaz
Member#: 245218
2013 STI Limited
If you have Access Tuner Race, you can zero out the boost targets and WGDC tables. That will cause the car to run on only mechanical boost.
If you unplugged the vacuum line to the waste gate wouldn't it have the same affect as the above? I think that will cause it to run on mechanical boost only as well. But you should double check that because I am not 100% sure.
Old 01-10-2011, 09:18 AM   #8
xlsupreme
Member#: 120789
2005 USDM STi
Do the opposite: run a length of tube (5/32") from the turbo compressor nipple to the wastegate actuator, this will allow you to run mechanical WG boost pressure.
If you were to disconnect it completely, as suggested, your WG would never have a reference signal, which would cause it to never open, which would cause you to boost until it blew the engine / you took your foot out of it.
You'll obviously have to cap off your solenoid so there isn't a huge hole in your intake now.
xlsupreme is offline   Reply With Quote
Old 01-10-2011, 10:17 AM   #9
Tripintaz
Member#: 245218
2013 STI Limited
LoL woops, I had it backwards
Old 01-12-2011, 01:58 PM   #10
Cobb Tuning
Member#: 4803
As has been indicated, these maps are not for your car at this point at all. Running one of these maps on your car in boost may cause engine damage. Connecting the pressure reference to the wastegate will limit you to mechanical boost, but again, you need a tune as you are already aware of.
I would advise extreme caution if you continue to drive your vehicle untuned. Stay out of the boost and go see your tuner. What kinds of supporting modifications do you have? (injectors, fuel pump etc)
Travis
COBB Tuning
Old 01-26-2011, 06:38 AM   #11
rdn2fst
Member#: 257699
Thanks guys. I took her to Cobb, the Doctor, and she is all better.
I'll post my results and mods in the proven power forum and link it here.
Superb work, attention to detail, and customer service by the folks at Cobb! I am very pleased.
cobb ots maps DausWRX Newbies & FAQs 4 02-19-2008 12:31 PM
Use Modified Stock Injectors with Cobb OTS map? Spike700 Newbies & FAQs 1 12-01-2007 03:55 PM
cobb ots maps scooterman Newbies & FAQs 21 08-13-2007 08:57 AM
Cobb OTS Map - VF39 93 MT101 Vs. FP18G 93 MT101 rhinotech Engine Management & Tuning 23 06-21-2007 09:15 PM
Will the FP 16G Cobb OTS map work? crashnscar AccessPort 1 01-30-2007 02:20 PM
