Old 07-08-2002, 05:32 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default brake pad installation: what is the goop you smear on the pads?
What is that pasty goop that you smear on the back of brake pads when you replace them and do i have to buy that stuff separately at an auto supply shop before installing pads at home?
Ed
edkwon is offline   Reply With Quote
Old 07-08-2002, 07:58 AM   #2
driver8
Member#: 6997
It is usually included in a small blister pack w/ a new set of pads. But you can buy it separately, in a tube. I don't remember what it's called, but any autoparts store should have it - the "blue anti-squeak stuff".
driver8 is offline   Reply With Quote
Old 07-08-2002, 08:53 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
It's anti-squeal stuff. The best stuff I have used is the red goop from CRC. It's not the spray stuff, it's the orangish-red goopy stuff in a tube.
Legacy777 is offline   Reply With Quote
Old 07-08-2002, 11:11 AM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Yep. . .anti-squeal. Like legacy777 said. . the stuff in the orange bottle is the best. Been using it for a few years now and the stuff works great. Just remember that a little goes a long way.
Calvin
cnk is offline   Reply With Quote
Old 07-08-2002, 11:38 AM   #5
Gozzi
Member#: 14479
2002 WRX wagon
platinum
Default Consider not
You might consider not using this stuff, it does tend to collect brake dust and generally gunk up the caliper. I just changed pads on an older 911 someone had used copious amounts of this on and it was like the whole caliper was dipped in silly putty. Yuk.
Gozzi is offline   Reply With Quote
Old 07-08-2002, 12:31 PM   #6
Legacy777
Member#: 4800
Done properly....it's not going to affect the caliper at all! you put a light coating on the backing of the pad, let it tack up, install pads.
The only place it touches the caliper is where the metal fingers are and the pistons themselves. I've NEVER had any instances of it causing any problems when used properly.
Old 07-08-2002, 01:25 PM   #7
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
for track or autoX use, the goop will burn up. I have seen it smoking and at the track on fire. Best to leave it off if you brake hard.
elgorey is offline   Reply With Quote
Hypothesis: The hotter you sound on the phone the uglier you are in real life. OriginalSin Off-Topic 7 02-25-2008 10:34 AM
rant: car navigation units, especially the ones you mount on the dashboard BigWrecKs Off-Topic 31 04-24-2006 01:27 PM
what is a reasonable mileage (read on the odometer) for a new car? ibear Newbies & FAQs 29 06-27-2005 04:02 PM
What car parts have you seen on the roads? nimaxpro Off-Topic 10 01-26-2004 02:28 PM
Attention Detroit Folks: What outdoor activities do you do on the weekends? Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 1 06-13-2002 01:40 PM
