Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 01-09-2011, 03:52 AM   #1
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
Default 2007 2.5i rear diff ratio?
just a quick question.
What is the rear diff ratio on a 2007 2.5i, and what years of diffs would work from WRX's/STI's?
The G.O.A.T. is offline   Reply With Quote
Old 01-09-2011, 04:16 PM   #2
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
trans/driveline forum, n00b
RaceFaceXC is offline   Reply With Quote
Old 01-10-2011, 02:11 AM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No STi rear diff will work.
No WRX (complete) rear diff will work.
You could transplant the VC LSD unit from inside the rear diff of a WRX into the rear diff of a RS, but why would you want to? The VC LSD units are crap.
Old 01-15-2011, 08:11 PM   #4
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
UsVERSUSThem WFC #197
I have a 3.9 Sti r180 that's going in my 2.5i in the spring. Why would this not work if my stock diff is a 3.9?
SubIELove is offline   Reply With Quote
Old 01-15-2011, 08:15 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
With a sufficient swap, yes, you could change the entire rear end and put in an R180. However, you'd need to determine how much of the mounting hardware, rear subframe, etc, you'd have to change to get the R180 in there.
Most people, when they ask what you did, want to know if it's a direct bolt on or if they can swap internals, etc.
Old 01-15-2011, 08:22 PM   #6
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
My full setup will be the v8 Spec C STi 3.9 2 way plated diff and axles, and 04 Sti full hub assemblies. I also have the 5x100 rotors from the spec c. Pretty straight forward bolt in affair.
Old 01-15-2011, 08:25 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, for most people, diff, axles, knuckles, brake assemblies, etc all at once doesn't count as straight forwards. To me, that's "Tuesday afternoon", but for most people that's "hire a mechanic".
Have you confirmed the R180 has the same bolt pattern on the snout as the R160?
Old 01-15-2011, 08:29 PM   #8
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
It doesn't, the snout ring needs to be replaced in favor of the r160 ring to keep the stock driveshaft. The splines are identical on both snouts and the rings are interchangeable. This is a fairly involved job, will most likely take me a weekend. Pretty straight forward bolt in job. I'm converting the car to RWD using an old school Chip Torque Australia center diff spool as well.
Old 01-15-2011, 11:28 PM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, I mean the bolt holes for securing the snout of the main casting to the carrier.
Old 01-16-2011, 12:42 AM   #10
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
Yeah it's all the same, all gd's use the same rear subframe.
2007 2.5i front and rear wagon seats. 97sportwaggie NWIC Private Classifieds 13 10-28-2008 08:23 PM
2005 STI Stock Front/Rear Sways Fit 2007 2.5i??? Willis1550 Brakes, Steering & Suspension 1 09-01-2007 08:51 AM
WRX rear diff ratio automatic? Also Driveshaft length? ciper Transmission (AT/MT) & Driveline 9 12-12-2002 05:09 PM
Rear diff ratios? Rovah Transmission (AT/MT) & Driveline 6 11-07-2002 08:08 PM
Rear Diff Ratios? Greg555 Transmission (AT/MT) & Driveline 10 03-28-2002 03:54 AM
Message Board Statistics All times are GMT -4. The time now is 04:55 AM.
