Old 07-08-2002, 11:24 AM   #1
Jewbaru
Member#: 1994
2013 Impreza WRX
Default EGT question, my EGTs are LOW
And I mean WAY low. At cruise doing 45-50MPH I'm reading 800F, WOT doesn't get over 1000.
This has got me a bit freaked out. I checked the thermocoupler, and it looks ok, the car doesn't idle oddly, no smoke from the tail pipe, nothing. The only thing is it doesn't feel as strong, but I can probably chalk that up to the 90+ degree temps, and high humidity we've had here lately.
I'm wondering if a weak power supply could cause the problem. Any ideas?
Jewbaru is offline   Reply With Quote
Old 07-08-2002, 09:33 PM   #2
RallyNavvie
Member#: 7113
2008 Spec B
Y'know I usually run at about 1350F at around 3000rpm cruise but ever since this hot and humid weather we've been getting it rarely gets up over 1200F with the same conditions. I wonder if it has something to do with atmospheric density on the exhaust? Monitored the engine data with the laptop and didn't notice anything else out of the ordinary so I wonder if it really isn't a problem.
~Garrett
RallyNavvie is offline   Reply With Quote
Old 07-09-2002, 12:55 AM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
With those kinds of EGT's and not as much power there are many possibilities. We don't have enough info yet to diagnose. It seems that the problem is there in closed loop and open loop.
For instance, you could have a blockage or problem in your RRFPR (if you have one) that is raising fuel pressure too high. or, for example, I once had a bad #3 plug wire and was running rich due to a weak spark but only in #3 cylinder where the EGT probe was placed (but I was rich only under boost in open loop with misfires noted).
Where is the EGT probe mounted?
Did you just install the EGT and triple check the connections?
What did the EGT's run prior to this, any prior history?
Did you ever cut the wires to the probe shorter and change the connections from the way the probe was originally supplied?
Do you have a CEL for catalyst efficiency (might indicate too rich closed loop) or misfires?
Etc... Need more info.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 07-09-2002, 01:18 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Joel - Is it an Autometer gauge? And did it happen overnight? It may be a bad unit, thermocouple or gauge. Give them a ring and ask if something like that is a common-type failure.
Old 07-09-2002, 10:55 AM   #5
Jewbaru
Member#: 1994
2013 Impreza WRX
The weather has been hot and sticky, so the car hasn't felt as strong. At night it feels stronger when the air is cooler.
Larry:
This just happened maybe a week or so ago, before the EGTs were pretty much normal. BUT, the guage needle did have a habit of "jumping". It'd be at 1400, then jump down to 12, not a smooth movement, but rather an instant jump, and only at WOT.
The EGT probe looks fine, I didn't cut any of the wires, and it's located in the passenger side collector. The Fuel Pressure seems fine, and the car isn't running overly rich. It IS possible I have a fouled spark plug over there. I need to check them.
I have had a CEL since the turbokit went in. Catylist efficiency, and now my front A/F sensor is dying.
Nick:
Yes, it's an Autometer, so is the sender. I'll give them a ring and see what they say.
Old 07-09-2002, 01:46 PM   #6
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
get an other probe... test it out.... it should be the probe... sounds like when i cross wires on the probe...
HOK is offline   Reply With Quote
Old 07-09-2002, 02:19 PM   #7
Jewbaru
Member#: 1994
2013 Impreza WRX
They told me to send the guage, and control module in for repair.
Old 07-09-2002, 03:48 PM   #8
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
weird i heard probes are first things to go... but i'd test it first... with a good probe you'll know immediately if its guage, CM or probe... you don't want to be sending stuff back and forth... you got subie buddies around?
Old 07-09-2002, 06:11 PM   #9
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
off topic, but hok are u still running a wrx ic?
akcel is offline   Reply With Quote
Thought Sti uppipes had EGT bung...mine doesnt? MachinesWRX Newbies & FAQs 4 11-22-2005 07:49 PM
Stock boost gauge - mine reads low, or not jlp7t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 03-27-2004 05:29 PM
The guys in the office next to mine are playing Christmas music... NeedAWD Off-Topic 22 11-07-2003 01:54 PM
What door speakers are you using, installer says mine are to deep. Digital-RX Texas Impreza Club Forum -- TXIC 10 06-29-2002 01:32 PM
Anyone interested in GT wheels, mine are FS...$300 gtguy Legacy Forum 8 01-05-2002 07:57 PM
