Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 01-11-2011, 12:44 AM   #1
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Default Dash Flocking
If you're like me, you don't make it to the interior/exterior section of the forum often, so I figured I would post this here.
I always wanted a flocked dash because it looks awesome, and is practical since it cuts down on the glare. I never looked into actually doing it until recently. Turns out there's a cheap kit that a lot of people use and have great success with. It's called the 'mini flocker kit' and can be found here:
http://www.donjer.com/
It's pretty simple. You put the glue down, then use the mini flocker to shoot the fibers onto the piece you're working on. After that it has to cure for at least 72 hours.
Find a clean flat surface to work on, so you can recover unused fibers. They say not to skimp on the stuff, so a lot of it ends up on your work space.
I highly recommend getting a friend to help apply the glue on any large pieces you might be flocking. You have 10-15 minutes to get all the fibers on from the moment you start putting glue down.
Results:
-Justin
MSP608 is offline   Reply With Quote
Old 01-11-2011, 12:58 AM   #2
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
flocked dash: Its what makes a rally car, a rally car
UP2MTNS is offline   Reply With Quote
Old 01-11-2011, 02:20 AM   #3
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Looks flocking amazing!
biggreen96 is offline   Reply With Quote
Old 01-11-2011, 08:13 AM   #4
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Pretty flocking nice! (I wonder how many people will make that joke ) I'm planning on doing the same thing to my dash when I have time. You should pull that firewall mat out, it's a good 15 or 20 lbs. of easy weight savings.
boost junkie is offline   Reply With Quote
Old 01-11-2011, 11:53 AM   #5
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Haha, I've seen plenty so far.
Hmm, the black thing that also goes around the transmission tunnel? I was wondering about that. I pulled a little bit up around the shifter just to see how thick/heavy it was. I'm guessing it must go all the way up the firewall for it to be 15-20 lbs. Is it fireproofing, sound deadening, both?
I bet it's a pain to pull out with all the hvac crap in the way. I think I'll leave it in for now.
Old 01-11-2011, 01:17 PM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Yeah, the black mat with the yellow insulation inside. I think it's mainly for sound deadening but I assume it's for heat blockage as well. I didn't notice any extra heat in the cabin after I removed mine though.
It is kind of a pain to remove with all that stuff in the way. I ended up cutting around the parts that were obscured and removing all that I could. I removed the rest when I took out the heater core.
Old 01-11-2011, 01:17 PM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
If you got the dash out the HVAC crap is like 10 more minutes lol
Just clamp off the coolant lines that run to the heater core, remove them then remove the ac lines (im sure your not even running them) then it's like 4 bolts and out she comes.
Rokkit is offline   Reply With Quote
Old 01-12-2011, 10:09 AM   #8
coolblue05
Member#: 39169
2008 Cayman S, 335xi
Tuned Perfection
nice work!!
Dash flocking is one thing that I seem to never get around to doing.
coolblue05 is offline   Reply With Quote
Old 01-12-2011, 10:53 AM   #9
TPNORTH
Member#: 210741
how much was left over maybe enough to do the pillars also?
TPNORTH is offline   Reply With Quote
Old 01-12-2011, 10:57 AM   #10
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
Great flocking work.
hcsi99 is offline   Reply With Quote
Old 01-12-2011, 04:07 PM   #11
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
holy flock
DutchOven is offline   Reply With Quote
Old 01-12-2011, 07:43 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
Flocking-A !!!!
Old 01-12-2011, 08:33 PM   #13
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Well I need to keep my HVAC crap to defog my windshield and what not. There's really only 4 bolts holding the blower and evvveerything else in?
Originally Posted by coolblue05 View Post
nice work!!
Do eeet, it's awesome. Comes in a ton of different colors too.
I didn't have the best work space, but still had a full tube's worth leftover. I forgot to do the little vent though, that goes on top of the dash up against the windshield. I'll probably have a half tube's worth now. If you setup a really good workspace (like what I have in my pic, but boxed off on the sides), you miiight be able to do everything I've done plus the a-pillars. I have plenty of the glue leftover from this though.
Old 01-12-2011, 08:42 PM   #14
tank1987
Member#: 223181
05 WRX, stage mehh
hybrid built SOLD!!! :(
Sweet, looks really good, been contemplating doing this as well, thinking you might have helped my decision to go through with it.....
tank1987 is offline   Reply With Quote
Old 09-13-2012, 11:58 PM   #15
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
wow that looks awesome. I think i will try this out.
Daddy_Digital is online now   Reply With Quote
Old 09-14-2012, 10:38 AM   #16
hcsi99
Member#: 115175
2004 Impreza WRX
2012 Outback 3.6R
not this flocking thread again!
Old 02-16-2013, 04:37 AM   #17
WelDun1
Member#: 249130
1999 Ver5 STi RA
Couple Questions,
how many square inches does the 3oz bag cover?
Did you only use the 3oz bag that came with the kit, or did you get extra, & if so, how much?
I'm thinking of going Two-tone with Black & Charcoal Grey. Maybe even doing some kind of stencil or pattern work if its even possible. You did a good job on your dash. I'll make sure to post pics of my interior after I'm done. Thanx for the write up!
WelDun1 is offline   Reply With Quote
Old 02-16-2013, 09:31 AM   #18
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
I am also curious about how much fiber you had to use. I might to this to my L while I have the dashboard out for my EG33 swap
bigolrig is offline   Reply With Quote
Old 02-16-2013, 12:03 PM   #19
Daddy_Digital
Member#: 274205
World Rally Blue
I want to see how the glue is applied and where is a thread on how to remove the dash? I really want to flock my dash. the glare is too much sometimes.
Old 02-17-2013, 07:45 PM   #20
mopar3.0
Member#: 261696
2004 wrx
red
how durable is it for a street car, can it be cleaned?
mopar3.0 is offline   Reply With Quote
Old 02-17-2013, 09:00 PM   #21
FjStix
Member#: 289425
You dont flock around i see. good work !
FjStix is offline   Reply With Quote
Old 02-17-2013, 09:51 PM   #22
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
why is this in motorsports
m1r4g3 is offline   Reply With Quote
Old 02-17-2013, 11:39 PM   #23
Daddy_Digital
Member#: 274205
World Rally Blue
Ever notice the glare from the sun reflecting off of your dash board when you are driving? Flocking the dash board helps eliminate that.
Old 02-18-2013, 03:39 AM   #24
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Because rallycar
Counterfit is offline   Reply With Quote
Old 02-18-2013, 01:01 PM   #25
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
so does sunglasses and tinted visors
rjrutzky is offline   Reply With Quote
Dash Flocking edvoskanian Southern California Impreza Club Forum -- SCIC 13 01-14-2010 11:58 PM
How much should I charge for dash flocking? PitwrkzZ1 General Community 24 06-22-2009 06:00 PM
Anti-Glare Dash Flocking (Spray on Seude Finish) rally-fast Interior & Exterior Modification 61 09-24-2008 07:04 PM
Where to get dash flocked in the US ?? wrxmyers Interior & Exterior Modification 9 04-14-2008 12:42 AM
Dash Flocking/Suede Wrap? Pakin North West Impreza Club Forum -- NWIC 0 07-12-2006 12:58 AM
