Old 01-11-2011, 11:15 PM   #1
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Default DIY Cam Holder for Phase 1 DOHC motors
After messing around with clamps and wrenches to do my timing belts for years now, I finally got around to building a cam holder tool, for about 15% of the cost of buying a pair from SPX.
Each side takes 2x 17mm sockets, 2x 5/8" x 2" bolts, 2x 5/8 nuts, 2x 5/8 1/4" washers, 2x 1" x 7" x 1/8 steel flats
I can take better pics if anyones interested in making one. Total cost was about $25, assuming you own all the necessary tools to make it.
Splinter is offline   Reply With Quote
Old 01-12-2011, 02:21 PM   #2
johnny p
Member#: 141232
02 v7sti wagon
signal green
this is awesome!
i have used my own elaborate solution . this one wins!
johnny p is offline   Reply With Quote
Old 01-13-2011, 12:28 PM   #3
icky
Member#: 210349
Yes, please show more.
icky is offline   Reply With Quote
Old 01-13-2011, 10:20 PM   #4
Spankie
Member#: 117352
2005 WRX
This looks really cool. Post more pic.s and show us all now this thing works!
Spankie is offline   Reply With Quote
Old 01-13-2011, 10:30 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
A pair of $1 vise grips work just as good.
sidewayz is offline   Reply With Quote
Old 01-14-2011, 12:36 AM   #6
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Um, how do you figure that?
Here's a better pic of the tool.
Basically the sockets are free to rotate normally (they're welded to the end of the bolt), you slip them onto the cam bolts, tighten down the nuts and it locks the cams in place.You can then slip the belt on without worrying about the sprockets suddenly leaping half a rotation while you're trying to align the timing marks
Old 01-14-2011, 09:00 AM   #7
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Maybe a dumb question, but why the thick rings between the flat bar and the sockets??
Why not use deep reach sockets, and use a bolt with the head sticking out the back (through the squarehole a ratchet normally goes into).
That way you do not have to have access to a welder.
Also, what is the CtC of the holes in the flat bar, as I am hella making one for future use.
Dutch Scooby lover is offline   Reply With Quote
Old 01-14-2011, 10:19 AM   #8
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
So you can hold the cam in place with one wrench while you tighten the nut. Give it a try tho! Spacing is 5.0 inches
Old 01-23-2011, 07:45 PM   #9
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Nice rig, I may put one together
2slofouru is offline   Reply With Quote
Old 01-29-2011, 06:23 PM   #10
Spankie
Member#: 117352
2005 WRX
Oh I get it this is to help hold the pulleys so that they dont move while installing the timing belt. I thought it was to hold the pulleys so you could take off the cam gear bolts. Kindof a big contraption just to hold a pulley still. I guess if you do it allot then it makes since.
Old 01-31-2011, 12:53 AM   #11
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I used them a couple weeks ago to do my water pump and it made it soooo much easier. You can use the bolts to make small adjustments to the cam gears to get the timing bang on, then just slip the belt on. It was a treat. It used to take quite a bit of time and frustration to get the timing marks all lined up and the belt on without something slipping out of place.
I install a timing belt at least once a year, usually more. For someone who does one every 6 years, no this wouldn't be worth building.
Old 07-25-2012, 09:10 PM   #12
CRPD
Member#: 138253
1996 Impreza
Red
Do you need to build two to hold each side?
CRPD is offline   Reply With Quote
Old 07-26-2012, 01:32 PM   #13
mackeymx
Member#: 258525
2004 STi-BW7670
R6-Red/White
No, only one would be needed. I really like this idea, Did you have any trouble welding the sockets? I know back in highschool I built a ghetto t-handle welding sockets to the end of steel. The sockets gave me a real hard time welding.
mackeymx is offline   Reply With Quote
Old 07-26-2012, 10:37 PM   #14
Subikid90
Member#: 239233
1998 LGT
If you get the chrome finish off they should weld just fine
Subikid90 is offline   Reply With Quote
It's Alive: phase 2 ej22 with phase 1 dohc heads in 96 Impreza ej20forester Normally Aspirated Powertrain 10 09-17-2010 03:38 PM
NTB: Phase 1 DOHC EJ25 motor suby53 RMIC Private Classifieds 0 01-27-2008 04:38 PM
1998 Phase 1 DOHC swap for a newer Phase 2? adam555 Subaru Conversions 4 06-03-2004 05:44 PM
phase 1 DOHC heads or phase 2 DOHC heads.. whats better to use? YaZahX Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-05-2003 06:16 PM
Cam shafts for 2.5 DOHC joemamad Normally Aspirated Powertrain 1 10-21-2002 09:03 PM
