Old 01-11-2011, 11:54 PM   #1
chompy630
Member#: 166434
1998 Impreza L 2.5
Red
Default P1507 after swaping in Wrx transmission
I have a 98 impreza L with a 98 2.5 rs motor and a 02 wrx tranny and rear diff with a 12lb flywheel and excedy oem clutch. After swaping the tranny in I get a P1507 cel code. I extended the wire to the neutral switch on the new tranny and cleaned my IAC valve. I had to replace the center diff and transfer gears because they mashed together. What is causing this code it puts my car in fail safe mode and it is undrivable unless I unplug the maf sensor but this only makes the code take longer to come on. HELP!!
chompy630 is offline   Reply With Quote
Old 01-12-2011, 10:34 AM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
http://forums.nasioc.com/forums/show....php?t=1196685
after i read, seems the $20 neutral switch fixed some members 1507
pinched wire between tranny to car shell?..........bc u extended wire?
GL
AliBenn is offline   Reply With Quote
Old 01-18-2011, 05:03 PM   #3
chompy630
Member#: 166434
1998 Impreza L 2.5
Red
Update:
I put the Neutral Sensor Switch form my old tranny on the new tranny and the code went away. I have no way of knowing if the other one was bad or if my ecu couldn't decode its signals but it works now so I don't really care.
E-Brake on after swaping Cluster jonpark Electrical & Lighting 4 05-01-2010 01:05 PM
how do i refill coolent properly after swaping motors 93white_impreza Newbies & FAQs 0 01-01-2010 05:51 AM
P1507 after long sit rallyrab Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-03-2008 02:43 PM
Help, no power after swaping turbo sleestak6326 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-05-2006 08:04 PM
('93-'01) Has anyone swaped a WRX engine in a 2.5 RS? ForeginRacer Impreza Forum 12 08-05-2001 03:39 AM
