Old 07-08-2002, 05:47 PM   #1
Corey
Member#: 618
2000 2.5 RS #89 STS
MODERacing / Bridgestone
Default More power to be had with tighter valve lash?
While doing my 2nd valve lash adjustment since installing the COBB street cams I started thinking ... If the valve lash is adjusted to be tighter than factory, it would provide more lift, and more airflow... maybe a few extra "free" HP also?
Obviously you would have to be careful not to make it too tight or your valves wouldn't close completely.
Could this be some free power to be had for all those running on stock cams?
I'd like to hear the opinions of some of the experts on this, maybe I'm way off
Corey #89 SM
Corey is offline   Reply With Quote
Old 07-08-2002, 08:34 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
you will probably experience excessive cam wear if the lash is less than the minimum factory spec, which is the (IIRC) .008" and .010" listed under the hood and in the FSM.
beyond that point, then yeah maybe the valves won't close all the way. probably not, you'll probably just wear the cam and rocker tips.
ColinL is offline   Reply With Quote
Old 07-09-2002, 12:37 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Corey - What specs are you using to set the valve lash with your street cams? Of course, it's probably different since you have a SOHC and I have a DOHC, but I'll ask anyway. I'm having the dealer check/adjust mine on Thursday, and I need to find out from Cobb if there are any special specs to use, or if the factory specs are good to go.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-09-2002, 01:58 AM   #4
Scubaru
Member#: 1530
I always thought you wanted to set your valve lash to the ''loose" side of the adjustment spectrum to free up the valve train from binding and excessive wear on your cams. Or the thats what I've learned building motorcycle motors. We just had to monitor valve clearances more often though -Scu
Scubaru is offline   Reply With Quote
Old 07-09-2002, 03:27 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you CAN NOT over adjust the valves...you WILL burn an exhaust valve because it is not using the valve seat as a heat sink properly...set them to .25mm on the exhaust and .20mm on the intakes...any tighter and you risk burnign a valve.
jeremy
Old 07-09-2002, 03:28 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
colin the specs under the hood are wrong...they are not what the manual says to set them at...the ones under the hood are maximum allowable clearance, not the desired clearance
Old 07-09-2002, 06:43 AM   #7
Corey
Member#: 618
2000 2.5 RS #89 STS
Pat,
I used .007 on the intake and .009 on the exhaust as recommended by Cobb Tuning.
Thanks for all the insight guys.
Corey #89 SM
Old 07-09-2002, 09:38 AM   #8
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
HndaTch627 is correct: Not enough valve lash can cause the valves to burn. When the valves get hot, the stems get longer. If there is not enough clearance, the valve will not seat and hot combustion gasses will go around the valve and burn them. Bad idea to try and make power by cheating on the valve lash specs...
subarumantoo is offline   Reply With Quote
Old 07-09-2002, 11:38 AM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
jeremy you were on such a roll but you failed to notice that your recommendations are exactly .008" and .010" when converted.
also, the service limit on valve lash is much higher than this number. it's so loose your valvetrain would be clattering viciously... (no comments about keif's momz please. )
Old 07-09-2002, 02:58 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
oh it wasn't those numbers colin, it's just that under the hood of the car the allowable clearance is .25mm on the intake and .30mm on the exahust and IIRC the manual had those as maximum allowable clearnances. but i could be wrong, i knew your numbers were right on cause well let's face it, your a damn genious .
Jeremy
p.s.: you said keif's momz sounds like a diesel truck cause she's too loose
Old 07-09-2002, 10:19 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thanks, Corey, I called Cobb today to confirm and the specs are the same for the DOHC setup.
Pat
Deals to be had, money to be saved! GS/GMS/SPT/Walbro subaruwrxparts.com Engine/Power/Exhaust 0 06-19-2009 11:54 AM
Agency Power Wheels in stock!! great deals to be had on enkei's as well! IMPORTIMAGE Wheels/Tires 504 09-16-2008 05:12 PM
how much more power is to be had with an ewg? godforbid67 Newbies & FAQs 1 10-08-2007 03:05 AM
HP to be had with porting? valve seals? deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-09-2005 07:48 PM
Do caps with LCD readouts & remote power on still have to be charged with a resistor? AcquaCow Car Audio, Video & Security 6 04-01-2004 02:49 PM
