Old 01-14-2011, 11:06 AM   #1
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Default Dyno experiments; ECU theories you want tested?
I have the opportunity to use a dyno tomorrow and depending on the schedule of the daily hosting me, I may have extra time to try out some changes in tunes and see what results I get. I have one experiment I want to try pertaining to fuel ratios and rpm/load but I may haver extra time to try other things. I won't be able to do any hardware changes so anything I try has to be ECU related. If you have any ideas, lay 'em on me.
Looking at you, Ty, BRR, Jay, etc.
Old 01-14-2011, 11:31 AM   #2
mattmak
Member#: 211128
2005 2.5RS 5MT Sedan
what do you have for heads/cams/headers/intake/exhaust, or anything else relevant?
I'd be interested to see where your timing/AFR ends up for MBT.
mattmak is offline   Reply With Quote
Old 01-14-2011, 01:35 PM   #3
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
I'm interested in seeing what correlations you can find between EGTs and power. More heat should = more power, up to the point that too much combustion is happening well after TDC. I've heard of some road tuners using EGTs to help find peak power, and that would be very useful for on-the-fly tuning at track and autocross events.
BAN SUVS is offline   Reply With Quote
Old 01-14-2011, 01:36 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Also, can you run on really high octane race gas and find true MBT, then see how close you can get on pump 91/93? Particularly if we're talking about a high compression/high RPM motor.
Old 01-15-2011, 03:50 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
First, run the car at 12.0, 12.5, and 13.0 AFR (dead-nuts on), optimize timing for each AFR individually, and compare power output on optimized states.
Second, if it's a load-holding dyno (meaning you can tell the dyno not to let the roller speed change no matter how much or little power the car puts out), create a grid of 2500, 2750, 3000, 3250, 3500 RPM on the X-axis and 0.40, 0.50, 0.60, 0.70, 0.80 g/rev on the Y-axis. Set the dyno to hold speed for each of those RPM setpoints. Then use the throttle to get the engine to each load setpoint. Advance timing (via the OBD-II increase timing command to make this faster). Find out if stock timing really is MBT or if advancing timing in the mid-RPM, mid-load ranges increases power output. If it increases power output, that means it also increased fuel economy.
Old 01-15-2011, 10:08 AM   #6
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
+1
Subyroo2.5 is offline   Reply With Quote
Old 01-15-2011, 07:28 PM   #7
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
The G.O.A.T. is offline   Reply With Quote
Old 01-16-2011, 11:06 AM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Well guys, bad news for you all wanting some data... The car on the dyno b4 mine, a porsche 928 twin turbo, broke some belt on the dyno itself. So my session was late and very brief since the shop employees were waiting to go home. I did gain 12 hp over what I had already tuned by adding a little fuel and reducing timing 1 deg in the high load/high rpm range.
It was a mustang dyno, so it does have load holding capabilities and I may have other chances to play with it in the future. If I do, I'll post here.
For my motor and setup, mbt was 13.3 afr tapering evenly to 12.8 from 5600 to 6500.
Old 01-16-2011, 07:27 PM   #9
mattmak
Member#: 211128
nice gains - have a plot for us to see?
also, what kind of mods/setup are you running?
FS : Would you like a computer that will work and do what you want it to when you want it? OvrClkdPmp MWSOC Private Classifieds 14 10-28-2010 09:34 AM
You wanted to see my car on the dyno? moosecakes North West Impreza Club Forum -- NWIC 22 07-22-2009 04:08 AM
So you want to test drive the 2006 STi? Bundyboyz Mid Atlantic Impreza Club -- MAIC 3 10-24-2005 08:18 PM
Subie Gurus please give ECU theory to my problem... Proj-R Engine Management & Tuning 2 08-12-2003 03:05 PM
FR500. You can talk Subaru all you want, but I want this!! Bahumut General Forum Archive 20 07-09-2000 05:53 AM
