Old 01-14-2011, 03:34 PM   #1
Member#: 261585
1997 95 Legacy EJ20R
Red
Default WRX Swap into BD Legacy (97 GT)
Hey guys
I got my hands on an 02 WRX for a decent price and I'm wanting to do a full swap into my 97 Legacy GT
My goal is to have a complete WRX inside the BD shell. Engine, turbo, trans, rear diff, ecu, wiring, etc.
Mechanically I know everything will work. I'll have to change the driveshaft (shorten it I believe) and use the WRX cradle to bolt up the engine (due to turbo piping right?).
My biggest concern is the wiring. I'm wanting to have as close to stock WRX wiring as I can. By this I mean ALL of the wiring will come out of the BD to be replaced by the WRX wiring.
How difficult is this to do and how much of a headache will it be? I'm sure someone out there has done it that can chime in with a bit of advise before I tackle this project.
Thanks
John@TA is offline   Reply With Quote
Old 01-14-2011, 08:19 PM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
How difficult is this to do and how much of a headache will it be? I'm sure someone out there has done it that can chime in with a bit of advice before I tackle this project.
The wiring is very difficult. Even with the schematics from both the Legacy and WRX Factory Service Manuals it isn't uncommon to spend literally months attempting to make sense of it all.
East Coast Swappers had a service by which if you sent them both wiring harnesses and ~ $ 900.00 USD they would perform the "merge" for you. From what I have read about the hell that others have gone through attempting to do this on their own, I think it is money well spent.
Jonathan is offline   Reply With Quote
Old 01-14-2011, 10:05 PM   #3
aekOne
Member#: 203705
yeah the best bet would be to send the two wiring harnesses away to get spliced. that way they'll just plug straight in and you'll be good to go. There's a guy over here in Australia that does them for $600 so i'd assume there must be someone you could find to do it for a similar price in the US
aekOne is offline   Reply With Quote
Old 01-14-2011, 10:07 PM   #4
Member#: 261585
Red
I guess what I'm missing is what would there be left to splice if I just used ALL the wrx wiring?
Old 01-14-2011, 11:49 PM   #5
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
As someone who has actually completed a full conversion, I can tell you that there is a LOT more wiring and fabrication involved in going that route vs just splicing in the engine-related functions.
You will need to splice all the wires for the doors, roof harness, trunk harness, front lights, radiator fans, steering column & HVAC. If you retain the Legacy ABS you will need to splice that too. You'll need to fabricate items like new brackets for the interior fuse box, gauge cluster, the list goes on.
In the end if you're not comfortable reading wiring diagrams and handy with a soldering iron, you're going to end up with a real mess on your hands.
The engine harness merge is very well documented here and on rs25, and is far simpler than the full conversion.
Good luck!
Dan Cech is offline   Reply With Quote
Old 01-14-2011, 11:57 PM   #6
Dobes
Member#: 164
2008 Exige S240
If you want a complete swap, you're going to have to swap gas tanks too otherwise your WRX ECU will not be happy with the '97 Legacy emissions equipment. Ask me how I know...
Dobes is offline   Reply With Quote
Old 01-15-2011, 12:16 AM   #7
Member#: 261585
Red
Good luck!
Thanks for the info!
You did your conversion yourself right? Is there any other words of wisdom you can share?
I should have clarified this a little more in my orignal post. With the engine, I'm also talking about all related emissions equipment. I need it to pass emissions. I know the ECU can be spoofed into "always ready" (a few local guys have done it here) to avoid failing OBDII emissions, but I would rather keep everything the way it should be.....at least as much as possible lol
Old 01-20-2011, 09:06 PM   #8
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I have an 04 STI drivetrain in my Legacy.
As for the driveshaft. The longer driveshaft from an automatic transmission Legacy should mate up and you won't have to fabricate one.
Follow Dan's advice. You can get everything working properly without going thru the trouble of swapping the whole harness.
Kraziken is offline   Reply With Quote
Old 01-21-2011, 08:34 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I think you mean shorter. The 6MT is longer than the 5MT, so you need a shorter driveshaft. It just so happens the 4EAT driveshaft works like a charm.
Old 01-26-2011, 12:29 AM   #10
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
In [email protected]'s case he would need the auto driveshaft from a 96-99 legacy.
~Josh~
Old 01-27-2011, 08:55 PM   #11
TDIpowered
Member#: 128339
2004 Chevrolet
2500hd 6.0 gas
Alright man so let me ask you(or whoever else knos) a question. I know that the diff, hubs, brakes, engine, transmission, and all that good stuff will bolt up to the BD chassis legacy. but what about the cross members, tierods, control arms, and pretty much everything else from under the car? could you use the ones from an sti on the 96-99 legacy's? I guess what im asking is will they bolt up to the legacy chassis?
TDIpowered is offline   Reply With Quote
Old 01-27-2011, 09:32 PM   #12
Dobes
Member#: 164
2008 Exige S240
My '97 WRX swap used a new GC8 turbo front cross member. It has a depression in it that helps clear the exhaust. From what I heard, you can also use a turbo Legacy cross member but I don't know which one.
All the tie rods, controls arms etc are still from my '97 Legacy. That includes the axles too.
Old 01-28-2011, 01:59 AM   #13
TDIpowered
Member#: 128339
2004 Chevrolet
2500hd 6.0 gas
well thats what im wondering because on paper it would seem that the legacy parts wouldnt be as beefy as the sti parts. correct me if im wrong of course
Old 01-28-2011, 04:18 AM   #14
Kraziken
Member#: 38629
Thanks for the correction Patrick.
The Legacy parts are not as beefy, but isn't a concern unless you are really beating on the car (drag racing, etc.).
I am considering swapping all STI gear. Going with the STI arms/axles, etc I believe pushes the track wider, which will cause fender rubbing issues. Someone correct this if I'm wrong.
As I'm considering a 5x114.5 swap, and going that route, my plans include body work and widening the fenders.
Old 01-28-2011, 01:42 PM   #15
TDIpowered
Member#: 128339
2004 Chevrolet
2500hd 6.0 gas
yea i figured it would so something to the track width but that would just make it handle that much better. take care of the fender issues and you would have a legacy that would really carve.
Old 02-03-2011, 11:17 AM   #16
smb_usmc
Member#: 272777
Default Swap
Man...that sounds like a lot of work. Good luck to you.
smb_usmc is offline   Reply With Quote
Old 02-07-2011, 07:48 PM   #17
GuamSTI
Member#: 210071
04 STI
I was wondering how hard it would be to just swap the JDM 2.0 Twin Turbo motor. Send the harness to ECS and then install the motor. The problem is that I am not good with electrical and I would not be able to remember where all the ends plug into.
GuamSTI is offline   Reply With Quote
Old 02-07-2011, 10:27 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
And you probably have a LHD car, which means the twin turbo motor won't fit.
WRX Suspension Swap onto BD Legacy Ride Height Issue RallyLegacy Legacy Forum 12 04-03-2012 03:03 PM
WRX SWAP into a Legacy GT 2000 5MT android25ua Subaru Conversions 10 03-02-2010 09:16 PM
My planned 96-97 EJ20R swap into 1990 Legacy wagon reddevil Subaru Conversions 26 11-17-2009 09:36 PM
wtb BD legacy 97-99 sedan with 5mt. sachilles NESIC Private Classifieds 3 10-31-2007 01:21 AM
WRX shift linkage swap into old Legacy nicebloke Transmission (AT/MT) & Driveline 5 02-09-2005 07:47 PM
