Old 01-14-2011, 11:29 PM   #1
Studmike02
Member#: 220095
'95 MX-5
Default Cranks then later no start.
To make this short, I started my 06 impreza 2.5i (4EAT) three times today.
Weather was cold (15-20 degrees)
First time (Morning): Cranks and starts within around 3 seconds. (Longer than usual.)
Second time (Late evening): Cranks and took two tries to start the car and finally started.
Third time (Just now): No crank, nothing.
Any ideas? Im thinking dead battery or something.
The night before, I was just driving in some deep snow, dont know if its the cause.
Just seeing what you guys think before I check again in the morning to see what the impreza got to show me.
Thanks.
Studmike02 is offline   Reply With Quote
Old 01-15-2011, 01:39 AM   #2
mrcrawford84
Member#: 225059
2009 Impreza hatch
Obsidian Black Pearl
Alt might be going. Causing the battery to slowly drain. Notice any rough idling? Have em tested perhaps?
mrcrawford84 is offline   Reply With Quote
Old 01-15-2011, 01:54 AM   #3
Jaren1
Member#: 195061
1997 \_(ツ)
Green
Probably dead battery caused by bad alternator. Are your headlights dim? that would tell you if the bat. is dead.
Jaren1 is offline   Reply With Quote
Old 01-15-2011, 11:36 AM   #4
96GreenLX
Member#: 60073
1996 Impreza LX
Green
This happened to me last year when I was basically plowing snow coming home. The belts were not tight enough but without it starting you may also need to get a jump or charge.
96GreenLX is offline   Reply With Quote
Old 01-15-2011, 06:40 PM   #5
Studmike02
Member#: 220095
'95 MX-5
Changed the battery to Duralast gold, car started no problem.
Will see what happens in the morning after sitting overnight.
Newly assembled hybrid with cranking and no start and no CEL, suggestions? 240sxguy Built Motor Discussion 7 08-20-2012 10:00 PM
No Crank no start mmkay? Trogasarus Electrical & Lighting 3 11-19-2009 11:45 PM
White smoke then no start DeMoe Aurelius Normally Aspirated Powertrain 10 03-02-2008 10:34 PM
Crank/no start - no spark - ideas? PeteDucati Built Motor Discussion 12 04-29-2007 04:29 PM
XT6 (92), Does anyone have a illustration of the timing belt(s) Crank No Start. munkis Normally Aspirated Powertrain 0 10-20-2002 11:25 PM
