Old 01-15-2011, 05:03 PM   #1
ej20ajk
Member#: 113223
08 WRX NB R180
Cool DS1 AVCS wiring diagram EJ207
About to wire EJ207 into a bugeye WRX. Had a hardcopy of the DS1 guide unfortunatley its on USB stick at work. So if anyone has copy or how to..Post it up or PM. Thanks
ej20ajk is offline   Reply With Quote
Old 01-15-2011, 05:05 PM   #2
Airelpaso
Member#: 139566
2004 Forester XT
Gold
Please post up your guide when you get it back from work!
Airelpaso is offline   Reply With Quote
Old 01-15-2011, 05:19 PM   #3
Tom W
Member#: 136728
04 PSM WRX STI Wgn
FP Black 82HTZ powered
Tom W is offline   Reply With Quote
Old 02-11-2011, 05:25 PM   #4
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
Does anybody have this guide? DS1 no longer exists I pmed the OP but if anybody else has it that would be great!
181stLeader is offline   Reply With Quote
Old 02-11-2011, 05:34 PM   #5
driftfc88
Member#: 218308
06 STI
EJ207 swap
This article is kind of helpful, I guess.
http://www.importtuner.com/tech/0311...ion/index.html
driftfc88 is offline   Reply With Quote
Old 02-12-2011, 08:07 AM   #6
ej20ajk
Member#: 113223
08 WRX NB R180
Old 04-22-2011, 11:45 PM   #7
llamsn
Member#: 201554
2to6 WRX Wagon
Thanks for the upload!
llamsn is offline   Reply With Quote
Old 12-28-2011, 05:33 PM   #8
HooliganSTi
Member#: 161608
2004 WRX Wagon
PSM V8 STi swapped
You're the man!
HooliganSTi is offline   Reply With Quote
Old 02-18-2014, 11:40 PM   #9
DWUsSubaru
Member#: 220644
2004 WRX Wagon
did anyone else follow this diagram to a T but still not get AVCS to work after?
DWUsSubaru is offline   Reply With Quote
Old 02-20-2014, 09:13 PM   #10
required
Member#: 78241
2002 SRP WRX
now with 100% more 6spd!
I've been wondering about this as well. I'm doing the research for a ej207 v8 swap into my 02 WRX, and haven't found anything about that. According to the instructions, you move the wires to the correct locations on the ECU (I assume), but I don't think that the USDM ECU automatically knows how or that it's supposed to use them. Maybe the tuner enables the AVCS when doing the tune on the new-to-you motor? Sorry I'm not much help on this one.
required is offline   Reply With Quote
Old 02-20-2014, 11:47 PM   #11
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Required, must use the correct jdm ecu to enable avcs, it will not happen with a usdm wrx ecu. Strange user name.
D-Rodman is offline   Reply With Quote
Old 02-21-2014, 09:17 AM   #12
required
Member#: 78241
2002 SRP WRX
Thanks for the reply! I figured that's how it was.
When I was registering on the boards, all the user names were taken, and the registration screen had a message on it that said "user name is required", so I tried it, and here we are
Old 02-19-2016, 09:58 AM   #13
redfogo
Member#: 426213
I know this is an old thread but wanted to say the wiring diagram from D1 is wrong. Use this wiring diagram http://bebeu.free.fr/43R-STi_Eng.pdf
Or use the D1, but know that there wiring is wrong on the E84/F61 connector. Pin 16 and 17 need to be swapped on E84. You can see the error if you look on page5 it shows pin7 being Blue + which is correct and Blue Yellow being - which is correct. But on Page 4 it will show them as the opposite. So you will need to swap them on the ECU side or the engine side your choice.
Hope this helps someone as this guide comes up as the 1st option when your looking for wiring help.
redfogo is offline   Reply With Quote
99 V5 EJ207 wiring diagram ckcadavona Pre-2002 Factory Turbo Powertrain 19 04-30-2009 05:38 PM
Ver.7 and Ver.8 into 02'-05' AVCS wiring diagram DS1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-17-2008 02:06 AM
AVCS Wiring diagrams for Ver.7 downshift1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 127 10-28-2007 10:43 AM
AVCS wiring on EJ207 rjrutzky Electrical & Lighting 8 04-03-2007 01:23 PM
'93 turbo legacy ecu wire diagram for avc-r? aludeman Legacy Forum 4 08-19-2002 06:44 PM
