Old 01-16-2011, 04:36 AM   #1
Suby2go
Member#: 270235
2008 Impreza WRX
Default Need Aluminum welder or Advice!!
Tonight, I was getting on the free way, when all of the sudden I heard a HUGE exhaust leak, so I pulled over right away, next thing I know, I noticed one of the pipes from the headers that is attached to the mount that than mounts to the block had a huge hole. Like the welding just broke...I need someone to temporarily weld it back so I can at least use it until I get a new one, or advice on how to fix it!
This is my only car!
Suby2go is offline   Reply With Quote
Old 01-16-2011, 05:28 AM   #2
TIGWERKS
Member#: 256615
not sure what aluminum has to do with it. But your gonna need to take the headers off the car and have someone bolt the headers to a mock-up block or a jig to bolt them flanges down. Then just clean the material and weld it up.
TIGWERKS is offline   Reply With Quote
Old 01-16-2011, 11:13 AM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
An exhaust shop would be able to help you out. If not a permanent/elegant solution, it should be ok for a temporary stop-gap.
Old 01-19-2011, 10:13 PM   #4
jleable
Member#: 266105
2011 WRX
JB weld might be a temporary solution. I once fixed an oil pan that had a 1/2 inch hole in it with that stuff and it held.
jleable is offline   Reply With Quote
Old 01-22-2011, 04:57 PM   #5
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
JB weld will not hold up. The exhaust gas temperatures are around 650 C right at that weld. Get an exhaust shop to weld it up and you will be fine.
BTW- your headers are steel, if they were aluminum they would have melted already.
speedyHAM is offline   Reply With Quote
I really need some help or advice I'm out of ideas NJ2.5RS Brakes, Steering & Suspension 5 10-23-2010 05:47 PM
Need a steel welder or decent shop/Nova Nico Flax Mid Atlantic Impreza Club -- MAIC 19 07-10-2008 01:47 PM
Computer gurus.... need some help or advice ricified Off-Topic 7 05-09-2007 02:58 AM
Aluminum Welders subiehopeful South West Impreza Club Forum -- SWIC 1 03-03-2006 10:51 PM
Aluminum Welders in Piedmont Triad BLACK02WAGON South East Region Forum 1 12-18-2004 05:54 PM
