Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 09-30-2010, 08:09 PM   #1
rack
Member#: 32908
2005 Impreza WRX STI
BLUE
Default Whining noise when throttle active
When i'm going 50+ MPH and I have the throttle going, I hear a whinning noise. Goes away if I take my foot off the gas.
I notice when I slow down (from 30 coming to a stop sign) I hear almost like I can hear my transmission or something.
Its pretty loud now.
rack is offline   Reply With Quote
Old 09-30-2010, 08:12 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
my front diff does that.
at speed pop into neutral and see if the noise changes.
Mavrik is offline   Reply With Quote
Old 09-30-2010, 09:33 PM   #3
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
I have a similar situation. My noise is 45mph+ only while accelerating. From what I've read its because i have hardened rear diff bushings.
MOBBiN is offline   Reply With Quote
Old 09-30-2010, 09:44 PM   #4
QwikEVO
Member#: 44172
2003 Lancer Evo 8
Plasti-Dip is for TOOLS
t-case
QwikEVO is offline   Reply With Quote
Old 10-05-2010, 09:01 PM   #5
Mavrik
Member#: 90347
Yamaha FZ8
Update?
Old 10-06-2010, 07:38 PM   #6
SLDWYS
Member#: 58877
BMW e30 XI
From JDM to DTM
My old WRX's transmission would whine. So much so that when I was revmatching/downshifting I scared myself the first time because it sounded like a cop siren.
The STi has it x2. You ruled out the transmission?
SLDWYS is offline   Reply With Quote
Old 10-07-2010, 03:14 AM   #7
garrettak07
Member#: 230345
2007 wrx tr
blue
i had the same whine took it in, it was a bearing in the trans
garrettak07 is offline   Reply With Quote
Old 10-07-2010, 12:38 PM   #8
SLDWYS
Member#: 58877
BMW e30 XI
From JDM to DTM
Must be talking about a different whine then.
Old 10-27-2010, 04:15 AM   #9
rack
Member#: 32908
BLUE
WIth School/work/baby I haven't had a chance to call around to have someone open it up and get a diagnosis.
I had seth listen to it, and he agreed it wasn't normal, LOL.
The odd thing is, I remember this sound since back when I had my downpipe put in. It just been getting gradually louder. And I finally realized it when I was giving my mom a ride to the airport, and she bitched at me about it.
Old 10-27-2010, 03:32 PM   #10
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
I think it sounds like a mini chainsaw in your tranny. If you take it out of gear you can still hear it on deceleration.
I looked up and down the drivetrain for visible issues etc all looked normal. What ever it is a buzzing like that is grinding more down everyday in my opinion.
I am interested to see if anyone else has heard something like what you have before. I have not ever heard the noise your car makes coming from and STI drivetrain.
P3Auto is offline   Reply With Quote
Old 10-29-2010, 01:10 PM   #11
NikFu S.
Member#: 78982
1992 NFSVX LSL 5mtGT
Long name, short temper.
Pretty typical of a failed bearing, only problem is discovering which one.
Could be the driveshaft carrier, could be in the trans.
I also have this horrible noise. Either cause is plausible.
NikFu S. is offline   Reply With Quote
Old 10-29-2010, 01:19 PM   #12
Nomadgene
Member#: 22923
2002 Hybrid JDM 2.0L
TWIN-SCROLL Black Bugeye
I never used to hear much from my transmission or differential over the first 7-8 years of ownership. After my team of skilled mechanics put in all the stiffer mounts this summer, well those whines and whirls are common now.
Nomadgene is offline   Reply With Quote
Old 10-29-2010, 02:03 PM   #13
Mavrik
Member#: 90347
Yamaha FZ8
Yeah I hear all kinds of noises now that my engine and trans mounts are solid lol
Old 01-22-2011, 09:34 PM   #14
rack
Member#: 32908
BLUE
Ok, so my car is rediculously problem prone. I just replaced the radiator. I found the issue with the Cylinder 1 misfire (injector).
My focus is now turning to this noise again.
What shops around town does everyone recommend to check out the noise,?
Also, Lilpnoy linked me these a while ago. Posting here incase they do end up relating after I get it inspected.
http://forums.nasioc.com/forums/show....php?t=1147847
http://forums.nasioc.com/forums/show...smission+whine
Old 01-22-2011, 09:36 PM   #15
Nomadgene
Member#: 22923
Only two I would trust with my ride…..Continental (scooby tech) and Specialized Import.
Old 01-22-2011, 10:05 PM   #16
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
I know rack and I discussed this, but for the good to the thread. We are going to swap the trans fluid and see if that helps.
Suggestions comments?
LiLpNoY is offline   Reply With Quote
Old 01-22-2011, 10:08 PM   #17
Nomadgene
Member#: 22923
take a good hard look at the fluid under light, look for metal shavings in the slurry
Old 01-22-2011, 10:38 PM   #18
Mavrik
Member#: 90347
Yamaha FZ8
what ever you use, make sure its good stuff. I've come across an Sti or two in my time to see and hear what happens if the wrong mix is put in.
Old 01-22-2011, 11:36 PM   #19
Wes_FSTGDB
Member#: 59400
2005 STi Atlas Grey
2008 BMW 335XI Space Grey
I have the same whine, but I blame it on several things, upgraded cusco tranny mount, engine mounts, and lightweight flywheel. Tranny/diff is serviced every 10,000 miles so I consider it to be normal.
Wes_FSTGDB is offline   Reply With Quote
Old 01-23-2011, 12:20 AM   #20
rack
Member#: 32908
BLUE
Is 10k the normal tranny service interval???
Old 01-23-2011, 12:29 AM   #21
Wes_FSTGDB
Member#: 59400
2005 STi Atlas Grey
I think it's 15,000, but Kiwi told me he changed his around every 10-15K when he had his WRX. I stuck to the 10K, normally after the summer it's pitch black (drag strip/I get on it a lot lol) and in the winter because of the snow/drifting/rougher conditions.
I'm actually due for one this month, just haven't had time. I'm going to swap in the Subaru stuff that Tribal and them were talking about. So far everyone has liked it.
Old 01-23-2011, 12:51 AM   #22
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
conti is the only shop intown certified on the subaru 6mt, but it will be expensive to have that sucker even cracked open if its not warrantied.
Alaskan EJ20 is offline   Reply With Quote
Old 01-23-2011, 01:17 AM   #23
Nomadgene
Member#: 22923
Yup, yup……..its slickery!
Old 01-23-2011, 01:42 AM   #24
rack
Member#: 32908
BLUE
Extra-S?
Old 01-23-2011, 01:43 AM   #25
rack
Member#: 32908
BLUE
So your saying the only diagnosis that can be done is cracking it open? I sure hope not.
Whining noise when I turn the wheel. Maner Brakes, Steering & Suspension 15 03-11-2013 06:21 PM
WRX whine noise when engaging gears at certain speeds Blue2002WRX Transmission (AT/MT) & Driveline 0 04-27-2009 12:46 AM
whining noise when i turn the wheel Hyelude Newbies & FAQs 6 09-27-2008 02:04 AM
Whining noise when I accelerate thugzlife Newbies & FAQs 9 03-23-2008 09:54 AM
weird whining noise when turbo spools dragggn714 Newbies & FAQs 6 06-20-2007 01:15 AM
Message Board Statistics All times are GMT -4. The time now is 09:45 AM.
