Old 01-16-2011, 10:44 PM   #1
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
Default ej25 timing and torque specs
doing a headgasket job on a 96 outback. have all the parts i need and heads back from the machine shop, going to put it back together tommorow. any helpful links to torqe on head bolts and cam caps or info on timing the engine? i searched but keep coming up with dead links and counterdictory information
nicko360 is offline   Reply With Quote
Old 01-17-2011, 09:33 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
These are from the '97 EJ25D FSM, but I don't see any reason yours would be different.
Timing belt
Head gasket
Cam caps
Pat Olsen
Old 01-17-2011, 01:29 PM   #3
Twokandan
Member#: 269128
1999 2.5 RS
Default Head gasket torque
Do you know if those torque specs correlate to single overhead cam heads? I'm trying to get my 99 2.5 rs back together and the info I found is confusing me
Twokandan is offline   Reply With Quote
Old 01-17-2011, 02:01 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Twokandan,
here you are.
~Josh~
Old 01-17-2011, 02:46 PM   #5
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
thanks!!!! your the man!
Old 01-18-2011, 01:08 PM   #6
Twokandan
Member#: 269128
1999 2.5 RS
Default Thank you
Thanks Josh. I've been having difficulty navigating this site. I just need a little more time to figure out how threads work. Anyhow, I got the driver side head installed and torqued down. I'm doing it in the car so I had difficulty getting at that #4 bolt, lol. I just got the cam plate bolted down on the passenger side head and am getting ready to set the valve lash. wish me luck. Also, I made a degree gauge out of a plastic milk jug. I just cut a circle out of it, folded it in half twice and cut a square in the center. It slides on the torque wrench before you put the socket on. Not exactly professional, but works fine
Torque Specs, sequence, and Timing help Hoak Pre-2002 Factory Turbo Powertrain 2 10-11-2008 05:45 PM
EJ25 Tollerances and Torque Specs Chocoholic005 Built Motor Discussion 11 06-10-2008 11:55 AM
Lug nuts and torque specs.? jsbush Newbies & FAQs 27 07-01-2006 04:57 PM
torque specs for intake manifold '00 EJ25? Dr Ken Normally Aspirated Powertrain 0 09-13-2003 10:40 PM
