Old 01-17-2011, 11:31 AM   #1
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
Default car wont start after timing belt install
ok so i have a 1.8l connected to a auto trans in my '93 FWD impreza all stock motor, decided to do my water pump and timing belt yesterday im on my 5th try with the belt. the first time it went on its likely i was off by a tooth or two, i know it sucks i know better than to rush a T-belt, i start it, it cranks a few times and i hear what sounded like metal on metal. i know what you guys are thinkinn, valves bent. but honestly it sounded more like the starter and flywheel connecting, not sure hope its not valves. anyways i do the belt 4 more times making sure the belt is DEAD on. it just cranks and never turns over. so, heres my question, if it was off a couple teeth the first time would it be enough to bend some valves and would it be enough to make it not turn over? i hear of ppl running their cars on bent valves and not knowing it just hearing a ticking noise. and is there anyway to advance or retard timing? I hope you guys have some anwsers for me its much appreciated, thanks
jobxiii is offline   Reply With Quote
Old 01-17-2011, 12:33 PM   #2
JoshP
Member#: 94350
Those arent interference so no bent valves. Not sure why it wont start though, did you disconnect anything electrical and forget it? Plenty of fuel? etc etc
JoshP is offline   Reply With Quote
Old 01-17-2011, 12:49 PM   #3
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
oh well thats great news, only thing elec. that got disconected was rad. fans....online repair manuals said something about using a "Driveplate stopper tool installed-automatic transaxle equipped models" and " Aligning the marks on the flywheel with the marks on the flywheel cover" is this nessacery in addition of alignment of crank and cams?
did compression last night 150psi and plenty of spark, on cyl 1. then tester failed :/ car ran great before this
Old 01-17-2011, 12:57 PM   #4
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
*note* i have checked online repair manuals and every source has the 1.8l noted as having 2 timing belts, L and R. mine clearly has one. also the pully diagram is wrong. looking at the 2.2l diagram shows my exact motor, so i got think maybe someone swapped my motor but it does have the "ej18" stamped on it. but the new belt that was ordered as a 1.8l matches the old one perfectly so i wonder what the 2.2l belt looks like? any other 1.8l owners have this problem?
Old 01-17-2011, 12:58 PM   #5
JoshP
Member#: 94350
That stopper thing is to hold the engine so you can break the crank pulley bolt free. You arent using the paint on the pulleys to line them up are you? Only use stamped lines ignore all paint. Also the crank you want to use the line on sensor pickup and the arrow will point right by 90*. If you used the arrow to align thats wrong.
Old 01-17-2011, 01:03 PM   #6
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
[IMG][/IMG]
make sure the timing marks look like this. now that u know u got spark make sure u get fuel also. check one of the fuel lines, with ignition on u should see fuel coming out
kbaldi_29 is offline   Reply With Quote
Old 01-17-2011, 01:20 PM   #7
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
i will gab some pics of the belt, yea ignoring paint marks using hash marks, will try timing once more
Old 01-17-2011, 01:31 PM   #8
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
anybody have this issue? The bottom 2 pics are supposed to be for 1.8l impreza, which is what i have but the 2.2 matches my motor
Old 01-17-2011, 03:00 PM   #9
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
those diagrams r not the right ones for ur engine. ill ppost the right ones
Old 01-17-2011, 03:11 PM   #10
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
does this look good?
Old 01-17-2011, 04:57 PM   #11
JoshP
Member#: 94350
No it doesnt, your crank is wrong. Rotate it 90* clockwise and line up with the straight line. Not that triangle
Old 01-17-2011, 04:58 PM   #12
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
crank looks different!
Old 01-17-2011, 05:04 PM   #13
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
u should check if there is another mark on the crank sprocket. not in the front like the one u r showing, right on the teeth where the cranks position sensor reads.
Old 01-17-2011, 05:07 PM   #14
JoshP
Member#: 94350
Originally Posted by kbaldi_29 View Post
they look good to me. did u check the fuel?? u say got good spark right!!!
Then you have never done a timing belt so please stop posting misinformation.
OP: Heres of a pic of how it should look. The red arrows are pointing to the correct marks. Note the triangle pointing to the right.
Old 01-17-2011, 05:15 PM   #15
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
Probably done twice as much as u! Better be careful when u talk to somebody like that u. Never know with who r u dealing with. there is not necessity to be disrespectful.
Old 01-17-2011, 05:27 PM   #16
kbaldi_29
Member#: 222707
2003 WRX EJ207
SD Carberry....
Cool
U never know when u could need help from somebody.
Old 01-17-2011, 08:55 PM   #17
jobxiii
Member#: 158866
'98 S14/'93 impreza
Nissan Super Black
yea that was it, thanks guys, i almost said screw it put a ej257 in it and call it a day
HELP: Car won't start after timing belt change wlchan Service & Maintenance 18 06-01-2013 09:18 AM
Car wont start after boost gauge install burnrubber Electrical & Lighting 0 04-18-2010 04:24 PM
Coworkers car wont start after head unit install Soulofdarkness Newbies & FAQs 7 08-07-2009 10:37 AM
car won't start after timing belt install 02ncwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-18-2009 10:17 PM
NEED HELP! car wont start after deck installation! yeng Car Audio, Video & Security 7 04-28-2003 05:53 PM
