Old 01-21-2016, 08:56 PM   #1
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
Default Subispeed F1 Brakelight V.1
Hey guys, just picked up one for really cheap but kind of confused on how to correctly wire it as a brake light only, disable the flicker, and turn on dim along with my tail lights while my low beams are on
Currently I have the tail as turn harness on and will be splicing into that instead of the factory harness.
Let me know if this is the correct wiring:
Fog light wire (red) on the lamp to the brown wire on the OEM brake light wire (brown
Black Wire - Negative aka Ground (wire to black on the new harness)
Which wire to splice into for yellow since I am connecting the red to the brown instead of the black with white stripes.
Midnite8 is online now   Reply With Quote
Old 01-21-2016, 09:46 PM   #2
sc00by4life
Member#: 97135
isn't the entire point of those lights specifically for that reason? i mean, its not like you need 4 brake lights.
Old 01-22-2016, 12:17 AM   #3
Kijho
Member#: 311882
2016 WRX
CWP
Sell it to me if ya don't want it
Kijho is offline   Reply With Quote
Old 01-22-2016, 12:11 PM   #4
Kryptonnyc
Member#: 429534
2015 WRX limited 6mt
WR blue
I don't think there is a way to disable the flickering light.. That's why they made a version 2, with a switch, to enable/disable it
Subispeed has a video on the install you can watch that, then just follow the wires through the clip, and splice them on the tail as turn module
Kryptonnyc is offline   Reply With Quote
Old 01-22-2016, 04:45 PM   #5
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
"Kevin" from Subispeed commented on my post from 2015+ WRX/STI page said to me:
"If you would like to wire the light without the F1 function, you will leave the yellow unplugged. Other than that, you have the correct wiring laid out. Red wire from the fog light to Brown wire on OEM and Black wire from fog light to Black on OEM."
I think they made v.2 so that you wouldn't need to do different wiring, just a switch.
Old 01-31-2016, 12:32 AM   #6
Midnite8
Member#: 430858
2016 WRX Premium
World Rally Blue
I gave up trying to make the F1 brake light to function properly with my lights. I am connecting to to my tail as turn harness through the corresponding wire colors but only one side of my brake lights work when it is connected.
