Old 08-18-2013, 11:03 PM   #2326
mejifair
Member#: 11356
2012 WRX STi Hatch
Originally Posted by dsn112 View Post
Insulate your hatch and you will have 75% less drone. Worth it for sure
Is there a walk-through how to insulate your hatch? I installed dynamt where the spare tire would be, but it feels like I am going to break the connectors that hold on the metal and Styrofoam pieces. If I could insulate the whole thing I think it would really help.
mejifair is offline   Reply With Quote
Old 08-19-2013, 12:10 AM   #2327
CASHxMONEYxMIKE
Member#: 228719
2013 STi
Satin White Pearl
Anyone check out the new Invidia dual N1's for the hatch??
CASHxMONEYxMIKE is offline   Reply With Quote
Old 08-19-2013, 01:55 PM   #2328
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
I didn't take the metal pieces out (tried and gave up) when I installed a dynamat-like material (B-Quiet) during my subwoofer install, but the pins holding the styrofoam in are a pain in the ass. I pried them out with a trim tool by pressing the styrofoam down a bit. When they come loose, the f-ers fire out of there at like 300 miles an hour. One ended up 20 feet away from the car. Now when I take 'em out, I hold a rag over them to keep them from disappearing!
For what it's worth, I don't think just vibration dampener (Dynamat/B-Quiet) will make that huge a difference on its own. If you want to reduce transmitted noise (as opposed to keeping stuff from rattling) you also need some sort of closed-cell foam.
evilspoons is offline   Reply With Quote
Old 08-19-2013, 09:35 PM   #2329
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
Here are a few short videos of a Borla ATAK on my '11 sedan. Invidia Catless DP. The second video won't imbed for some reason.
http://youtu.be/DZc-WXhqiRo
bigbenp is offline   Reply With Quote
Old 08-19-2013, 09:46 PM   #2330
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
Originally Posted by WRXinpa View Post
Already done!
I'll add, my "insulation" was limited to adding 2 layers of carpet padding under the hatch cover. There's a thread somewhere on NASIOC that I posted to.
About a year ago, I pulled out the whole interior and lined it with HVAC insulation. That helped with road noise, but not exhaust noise.
WRXinpa is offline   Reply With Quote
Old 08-19-2013, 11:45 PM   #2331
mejifair
Member#: 11356
2012 WRX STi Hatch
nice I will remember that if I want to take out the foam.
Old 08-23-2013, 01:11 PM   #2332
jlundy11
Member#: 324709
2012 WRX Sedan
Noticed a little bit of rasp in the rpms from my Turbo XS catback. Checked it for leaks and noticed there was a small hole covered in carbon (wiped off for pic) in one of the welds. So it's definitely leaking, I was just wondering if this small hole is capable of causing the rasp I'm hearing in the high rpms?
jlundy11 is offline   Reply With Quote
Old 08-23-2013, 01:38 PM   #2333
GSXpress
Member#: 95825
2011 WRX Hatch
Default CNT turboback
Stock DP vs CNT catted DP
Stock catback vs CNT catback
Reflection shot
Installed
GSXpress is offline   Reply With Quote
Old 08-23-2013, 03:36 PM   #2334
zohh_amaze
Member#: 158592
2004 4Runner V8
How's the quality of the CNT catted dp?
zohh_amaze is offline   Reply With Quote
Old 08-23-2013, 03:46 PM   #2335
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Stock DP , Tomei Expreme Ti
Crappy quality vid , but it sounds great in person and under load especially
saar is offline   Reply With Quote
Old 08-23-2013, 03:48 PM   #2336
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Old 08-23-2013, 03:58 PM   #2337
GSXpress
Member#: 95825
2011 WRX Hatch
I have no complaints.
Old 08-23-2013, 04:10 PM   #2338
jlundy11
Member#: 324709
2012 WRX Sedan
I have the same one. Only 15k on it, but so far so good. Good fit too.
Old 09-02-2013, 12:01 AM   #2339
Ray521
Member#: 324129
2015 Evo
Does TurboXS currently make a quad tip for a '13 hatch that bolts up to the stock down pipe. Everything I find either doesn't specify or says its the old version. Haven't found anything saying new version.
Thanks
Ray521 is offline   Reply With Quote
Old 09-02-2013, 09:55 AM   #2340
mejifair
Member#: 11356
2012 WRX STi Hatch
Thanks
I have only seen the turbo back and catback. I don't think that make one that only includes the midpipe.
Old 09-05-2013, 03:30 PM   #2341
KMA2
Member#: 254771
2011 WRX hatchback
silver - Stage 2
It was newly installed and a very cold start... Sound got a better after broken in and definitely when it warmed up.
KMA2 is offline   Reply With Quote
Old 09-05-2013, 03:59 PM   #2342
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
Thanks
the 08+ sti & 11+ wrx quad tip from TurboXs fits the stock downpipe.
i have the sponosored catback right now mated to the stock downpipe, i will be installing the downpipe as well in the next few days.
[url=http://s1335.photobucket.com/user/fearofheights1/media/null_zps4c3fbdac.jpg.html]
^ uhh, what? a catback & turboback includes a midpipe.
rosedaleny806 is offline   Reply With Quote
Old 09-05-2013, 11:02 PM   #2343
mejifair
Member#: 11356
2012 WRX STi Hatch
Tell me more! I have a high pitched "pssssst" sound at WOT above 3000 RPM, and I gave up trying to find a leak, but I only looked at the gaskets.
Did you have to take the mid pipe off to see the leak? I slid under the car earlier this week and tried to look closely at all of the welds but did not see anything.
I bet I have a leak like that though. I have never thought the sound I heard was right. No way it could be a wastegate...
Old 09-06-2013, 11:52 AM   #2344
jlundy11
Member#: 324709
2012 WRX Sedan
Luckily mine was facing down close to the flex pipe. Called Turbo Xs. They sent a new mid pipe out no questions asked. I'll get it monday and install it next weekend. I'll keep you updated.
BTW I heard about some other XS exhaust gaskets leaking and were cured by using this.
http://www.permatex.com/products-2/p...t-maker-detail
Old 09-06-2013, 01:24 PM   #2345
mejifair
Member#: 11356
2012 WRX STi Hatch
I may take it off to look...
And for gasket leaks I already installed the GrimmSpeed adapter kit (and 2X thick gasket for the axleback>midpipe connection) and used the gasket sealant that you noted.
Old 09-08-2013, 09:02 PM   #2346
mightymints
Member#: 252858
2015 STi WRB/Gold LE
2013 WRB STi 5dr Stage1AP
My 2013 STi with Gymkhana acelback
Got more at facebook.com/ashturnerphotography!
mightymints is offline   Reply With Quote
Old 09-09-2013, 07:01 AM   #2347
subyjo
Member#: 302509
2008 sti
red
Also had a ugly rasp. Went away with the install of double rear box..
subyjo is offline   Reply With Quote
Old 09-09-2013, 03:38 PM   #2348
bSER272
Member#: 363130
2013 WRX Hatch
CBS
Just picked up a used Injen Axleback. Had to straighten it out a bit with a couple zip ties, but in the end I think it looks pretty good. Sounds real mean. Quad 4in burnt tips.
http://imgur.com/4bK5sRz
bSER272 is offline   Reply With Quote
Old 09-12-2013, 01:52 PM   #2349
Bulls_fan
Member#: 289104
2011 WRX Limited
World Rally Blue
Here is a video of my 11 WRX hatch with the Nameless axleback, 4" mufflers and non-staggered single wall tips. I love it!
https://www.youtube.com/watch?v=6wj4g8McIpc
Just try to ignore the extremely loud cicadas in the background...
Bulls_fan is offline   Reply With Quote
Old 09-12-2013, 02:27 PM   #2350
Jdmoon86
Member#: 283328
2011 SWP WRX 4-door
TorquedPerformance Stage2
Originally Posted by Smokin' Joe View Post
For a sedan or hatchback? I've noticed a different note in the sedans that is a bit more subdued than the hatchback. I have a hatchback
I have a sedan. Sorry for such a late response. haha
Jdmoon86 is offline   Reply With Quote
2011 Subaru WRX/STI Front lip! AndrewtechAutomotive Exterior/Styling 16 07-09-2012 10:13 PM
2011 Subaru WRX STi Limited Sedan 1080p and stills, near Mt. Hood. HannahSubaru North West Impreza Club Forum -- NWIC 118 12-24-2011 01:51 AM
2011 Subaru WRX STI ricochet NASIOC Official News, Articles and Polls 176 07-07-2011 09:29 PM
2011 Subaru WRX STI Sedan vs. 2007 STI AVANTI R5 News & Rumors 42 01-18-2011 10:47 PM
Subaru WRX / STi Exhaust Parts + More ViperBoy Private 'For Sale' Classifieds 6 10-10-2004 12:26 AM
