Old 01-18-2011, 12:31 PM   #1
JeanGrey
Member#: 204539
Question Quick question about coolant changes for head gasket issues
I had the head gasket leak that was typical of Subarus about 30,000 miles ago. I've also seen it discussed in this thread... http://forums.nasioc.com/forums/show...4#post26433214
Is it still the consensus to change the coolant to try and avoid corrosion of the gaskets? I know I read somewhere that there's a certain type of coolant that is superior and less likely to become corrosive but I'm not sure what it is... any pointers?
Thank you!
JeanGrey is offline   Reply With Quote
Old 01-18-2011, 12:40 PM   #2
JoshP
Member#: 94350
Yes you should change coolant, the schedule will be in your owners manual. I change mine every year. Subaru coolant from the dealer and distilled water.
JoshP is offline   Reply With Quote
Old 01-20-2011, 06:44 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ +1. However I was told to follow a two-year change schedule.... some places can check coolant acidity to determine when to change it.
Question about salvaged 98rs' and head gasket problems ohfiveRS Service & Maintenance 1 04-20-2009 05:20 PM
quick question about coolant conditioner fusionchicken Service & Maintenance 4 11-24-2007 03:52 PM
Quick question about brake setup for track. DinoGuan Brakes, Steering & Suspension 8 09-26-2006 05:08 PM
Quick question about oil change AlucardR Service & Maintenance 5 03-27-2004 04:21 AM
Quick question about oil change T-WREXX Texas Impreza Club Forum -- TXIC 11 03-19-2004 02:59 PM
