Old 07-09-2002, 02:43 AM   #1
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
Default What 3 gauges do i need?
Yeah, i did a search, but too many listings to look at... what 3 gauges do i need? im planning on getting a Apillar bezel and gauges as my first mod... which gauges do i need? TIA
wReXeRw is offline   Reply With Quote
Old 07-09-2002, 02:46 AM   #2
deepbeep
Member#: 1392
Responses will definitely vary. I'm planning on going with Boost, EGT and Oil Pressure myself...
deepbeep is offline   Reply With Quote
Old 07-09-2002, 02:57 AM   #3
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 07-09-2002, 03:00 AM   #4
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
well, i want 3! heh , so what 3 should i get?
Old 07-09-2002, 03:04 AM   #5
FloridaWRX
Member#: 7708
'83 huffy 10-speed
yellow
Boost
EGT
Oil pressure/Fuel pressure.
on the third i prefer oil pressure.. if you run out of fuel, the car stops.. if you run out of oil... bam.
FloridaWRX is offline   Reply With Quote
Old 07-09-2002, 03:15 AM   #6
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
sorry for the n00bieness, but whats the EGT?
Old 07-09-2002, 03:34 AM   #7
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
EGT - exhaust gas temp, pretty important to know, also one of the more expensive gauges
I drive a WRX wagon is offline   Reply With Quote
Old 07-09-2002, 03:35 AM   #8
debtfree
Member#: 21100
exhast gas temp.
debtfree is offline   Reply With Quote
Old 07-09-2002, 03:37 AM   #9
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
ohh I see, whats so important about EGT's
Old 07-09-2002, 04:21 AM   #10
ScoobyBoy
Member#: 6418
id say boost, air fuel, and egt...but if you get the blitz dtt, you can get an extra guage since it comes with a digital boost guage.
ScoobyBoy is offline   Reply With Quote
Old 07-09-2002, 04:52 AM   #11
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Hrm is oil temp just not a popular choice or what? I alerady have the factory boost gauge so Im thinking of going A/F, oil temp, and either oil pressure or EGT.
I think oil temps are important, especially if you go on the track.
M3sum is offline   Reply With Quote
Old 07-09-2002, 05:56 AM   #12
oldmansan
Member#: 17877
Midnight Pearl
Default I would rather have an oil pressure
gauge than oil temperature. If the oil temp is getting out of line, the water temp should follow. But if the oil pressure drops drastically, I may be able to stop in time to prevent engine damage. I agree with the majority above, boost, EGT, and oil pressure. I have an electronic boost controller, so I'm going 2 gauge pillar mount as well (don't like the center gauge pod look).
San
oldmansan is offline   Reply With Quote
Old 07-09-2002, 06:01 AM   #13
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Ahh ok, makes sense. Is there a range that the WRX should be in terms of oil pressure? Im new to this kind of stuff. Or do we just kinda see what range normal driving brings it to and go from there? Thanks
Old 07-09-2002, 11:35 PM   #14
WizardBlackWRX
Member#: 14979
I would not use the stock boost gauge.
Personally, I would go with Greddy 60mm peak hold warning
EGT
Boost
A/F Ratio
WizardBlackWRX is offline   Reply With Quote
Old 07-09-2002, 11:51 PM   #15
Need4Mods
Member#: 17201
2002 WRX - Sedan
WR Blue w/JDM Rear Wiper
Oh nothing really. Something like more boost, higher EGT's, meltdown of the precat, cat debri hitting the turbine, no more turbo, shell out more money
Need4Mods is offline   Reply With Quote
Old 07-10-2002, 01:31 AM   #16
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Yah, I figured its nothing
Old 07-10-2002, 01:40 AM   #17
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
1. Boost
2. EGT
3. Time
4. Outside temperature
Sordid Philosopher is offline   Reply With Quote
Old 07-10-2002, 11:19 AM   #18
BamBooI
Member#: 10945
2006 Evolution IX
Boost EGT Oil Pressure. I have Boost now and am getting EGT.
BamBooI is offline   Reply With Quote
Old 07-10-2002, 12:14 PM   #19
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
A/F is useless if you don't go with something like the Greddy A/F unit.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-10-2002, 03:08 PM   #20
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Jorge (RiftsWRX)
www.ProjectWRX.com
Why is this? Does the Greddy unit use a wideband sensor or something?
driggity is offline   Reply With Quote
Old 07-10-2002, 03:11 PM   #21
mlambert
Member#: 13831
I already have the stock boost and im planning on going egt, greddy a/f and oil temp. I wanna have all matching face/needle though to match the dash...so im kinda stalling.
mlambert is offline   Reply With Quote
Old 07-10-2002, 03:17 PM   #22
mdot
Member#: 15884
2002 wrx wagon
boost
egt
oil temp*
*after a long q&a time i finally decided on oil temp 'cause the car has a oil pressure light. true if oil pressure drops quickly you could seize, but the light will come on, smoke will billow, and you'll know quickly enough. but high oil temp is a slow death you might not recognize while waiting for the stock water temp guage to rise. high oil temp is a killer over time, especially for the turbo. if your not comfortable with the stock oil pressure light, you could always put in a no-pressure light of your own, and really, that's all the information you need from the pressure side of the argument. (true higher pressure might tell you it's time to change your oil, but if you aren't doing that simply based on the odometer guage, why would you pay attention to a oil pressure guage) ANYWAY...i tend to ramble.
mdot is offline   Reply With Quote
Old 07-10-2002, 03:56 PM   #23
QA Guy
Member#: 6739
Supposedly the stock oil pressure idiot light will only come on around 2 psi of pressure. This means that when your engine is ruined because of low oil pressure, the light will come on and inform you of the reason a short time later...
I am in the boost, egt, oil pressure camp, BTW.
QA Guy is offline   Reply With Quote
Old 07-10-2002, 07:59 PM   #24
mdot
Member#: 15884
2002 wrx wagon
"Supposedly the stock oil pressure idiot light will only come on around 2 psi of pressure. This means that when your engine is ruined because of low oil pressure, the light will come on and inform you of the reason a short time later... "
yes, but what would cause a oil pressure catastrophy that would drop oil pressure from 80psi (wild ass guess at oil pressure) to 2 psi?
1) blown gasket=lots of smoke.
2) hole in oil pan=spots/puddle in your driveway and/or idiocy if you didn't check for a hole after you hit the rock.
3) break in any other line, which would most likely cause 1 and/or be caused by 2... anyway....
now, what happens when your oil temp is 100 degs hotter than spec, but you don't notice the water temp needle up more than a few fractions of an inch (an you dismiss that because it's a hot day)?...what happens is, you fry your turbo.
i may be exagerating, but that's more my concern than not noticing if i blew a gasket or drove over a rock the size of a soccer ball.
but that's just MHO.
Old 07-10-2002, 08:14 PM   #25
AlanTheWoo
Member#: 19652
1990 GTR
2006 Range Rover Sport
there's a lot of debate over oil pressure vs oil temp, but what about a/f? no one's really mentioned the pros and cons of having an a/f gauge.
i was personally thinking about getting boost, egt, and a/f. but now i'm thinking about ordering the column oem boost and getting egt, a/f, and oil pressure
AlanTheWoo
AlanTheWoo is offline   Reply With Quote
What gauges do I need? kirkeemonster Electrical & Lighting 10 11-02-2006 07:46 PM
What 3 gauges needed? xcntrk75 Electrical & Lighting 6 01-03-2005 11:33 PM
What aftermarket gauges do I need? GHST Newbies & FAQs 16 08-27-2004 02:22 PM
DEFI gauge question: What other parts do I need? samwY General Community 7 11-11-2003 02:52 AM
what gauges do i need the spacecowboy Normally Aspirated Powertrain 24 03-20-2001 12:17 PM
