Old 01-19-2011, 03:21 PM   #1
mike25
Member#: 197948
93 WRX JDM
Default WRX 93 jdm ej20 , will an Down pipe + the cat-back from an 2002 WRX fit?
My entire exhaust line need to be change ASAP and I need to know if an WRX 2002 down pipe and cat-back is bolt on. Thank you and sorry for my english .
mike25 is offline   Reply With Quote
Old 01-20-2011, 07:31 AM   #2
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
I was told that my turbo back exhaust from my 02 would work on my swap, only way it wouldn't is if you mixed the downpipes and catback since jdm downpipe is longer then usdm.
KOJAK-02-WRX is offline   Reply With Quote
Old 01-20-2011, 10:33 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
JDM downpipes are shorter. but if you use the rest of the JDM pipeing it will work fine.
you can also use the full USDM exhaust on your 93 and it will work just fine. it is missing one hanger on you car, the is on the newer cars. but this will not be a problem.
i have done this a few times with 02-05 exhause on 93-94 cars with JDM engine swaps.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 01-20-2011, 11:55 AM   #4
mike25
Member#: 197948
93 WRX JDM
is the headers and uppipe the same?, I saw a kit with that the only thing missing is the catalytic converter and the down pipe. And Do I need a catalytic converter ? mine exhaust line broked on the downpipe ending. So cat don't seems to be usable again
Old 01-20-2011, 08:57 PM   #5
suberdave
Member#: 101865
88 GL-10 STi
the "headers" and up pipe are the same.
-=Suberdave=-
FS : (SoCal) Down Pipe and Cat-Back 09 Wrx Sedan Parks09 Engine/Power/Exhaust 20 09-02-2010 12:00 PM
Does the Apex'i cat-back from a GC body fit the 2005 2.5RS? awdlifestyles Vancouver Impreza Club Forum -- VIC 6 09-26-2005 11:03 PM
Confused between down pipe and cat back 04Turboboxer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-03-2004 03:04 PM
up pipe, down pipe, and cat back question 04subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-22-2003 09:53 PM
according to txs: up/down-pipe, no cat-back? iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-04-2002 09:58 PM
