Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-19-2011, 03:25 PM   #1
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
Default Squeeling AC belt or pulley issue..
My 2003 TS wagon just started making this weird ass chirping and squeeling noise. It sounds like its coming from the small belt that goes to the AC compressor and tensioner pulley. It sounds like a belt noise but could be one of these pulleys. At speed it will make the same repetative noise in patterns of 5 or 6 seconds where it sounds like a freakin Cicada or birds singing over and over and over. It starts slow and gets faster and faster until its a steady noise then stops. Then repeats. I sprayed belt dressing on the pulleys and belt and the noise pretty much vanishes for about a day if Im lucky. But then right back to the noise. The belt is newer... WTF? Do the Ac compressors go bad or the tensioner pulleys? Can I replace just the AC compressor pulley and not the whole compressor? Super annoying.. my car sounds like a total peice, I need to remedy this issue STAT!! thanks.
99imprezd is offline   Reply With Quote
Old 01-19-2011, 11:29 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Stat, eh? have you tried properly tensioning the belt?
Old 01-19-2011, 11:33 PM   #3
renyo
Member#: 93577
98 Impreza
AC Compressors/pulleys and the tensioner pulleys do go bad. The AC pulley technically is replaceable without replacing the compressor, but no one does it and it's not really made to be replaced. The tensioner pulley tends to go on some older cars. If either of the two are going though, you'll get a metal whining sound that's very audible at idle.
renyo is offline   Reply With Quote
is this a timing belt or rod issue? mountainhigh Normally Aspirated Powertrain 11 03-12-2007 04:51 AM
Remove AC belt or Not live_2race Motorsports 5 05-02-2006 12:08 AM
WTB: ej18 AC belt tensioner/pulley 83Rabbit Private 'Wanted' Classifieds 4 04-03-2006 09:10 PM
AC BELT or COMPRESSOR? SQUEEL/BURNING RUBBER SMELL ILSMKU2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-08-2005 05:13 AM
Squeeling AC compressor pulley. What to do? ilmaestro Normally Aspirated Powertrain 18 09-08-2004 07:36 PM
