Old 01-19-2011, 10:52 PM   #1
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Default Oops - put on wrong tire size!?!?
Hey folks,
Can't believe I did this but I just bought a new set of tires about 3 weeks ago (all 4 of course) for my 2001 Legacy S/W and I put on 205/60/R15 instead of 195/60/R15. I don't know if the shop made the error or I did but it was probably me because our other car uses 205s.
So, they are wider and larger. I know this means that the speedo will be off. I'm hearing a slight grind under turning conditions but can't find where it is rubbing. I can sometimes feel a slight vibration during the turns.
What should I do in your opinions?
Option 1: Live with it and keep driving unless the grinding gets worse?
Option 2: Put 'em for sale on Craigslist and replace again. Then I'm probably out at least $200, right...
Crap...
paddleboy is offline   Reply With Quote
Old 01-20-2011, 12:41 AM   #2
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
I really wouldn't be too worried about the tires being the wrong size. The size difference is only 10mm or 4/10 of an inch. I say just keep them and live with it.
Realistically the speedo won't be noticeably off if any at all. Again, the 10mm wider will hardly change actual circumference.
What kind of grinding noise do you hear? You might not have noticed it before the new tires because you weren't concerned about anything being wrong, but now that you're concerned you're paying much closer attention to all the noises and what not. Have you checked your CV boots? They could cause a slight vibration when they start to go bad. I know I could feel it in my Legacy when the right one tore apart. (I knew it was ripped but I didn't replace it until it got bad).
Frogsthatmoo is offline   Reply With Quote
Old 01-20-2011, 12:16 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm with froggy - that difference in tire size isn't worth worrying about. The 2.5GTs in the same body style use a tire (205/55-16) that's even a bit bigger than the 205/60-15, so it shouldn't matter at all.
Also concur with his thinking that the noise you're hearing is most likely not tire related.
Pat Olsen
Old 01-20-2011, 12:54 PM   #4
that one legacy
Member#: 103665
If it was the tires causing the transmission to go screwy, you'd hear noises whenever you drive, not just when you're turning. Noises when turning would usually indicate either a bad axle or a tie rod end. If you are hearing clunking noises when going over bumps, then add ball joints and strut top mounts to the list of things to check. There's more, but those are the most common in my experience. All of those parts would fail because of mileage by the way, not because of your tires. Of course, if your car is lowered, then that can complicate things.
that one legacy is offline   Reply With Quote
Old 01-20-2011, 02:13 PM   #5
PA-Outback2000
Member#: 161832
2000 Outback Limited
ur only .48" taller than the stock size and will be really going 58.8mph when the speedo says 60mph, which is kind of like having overdrive on ur car.
try this... http://1010tires.com/TireSizeCalculator.asp
PA-Outback2000 is offline   Reply With Quote
Old 01-20-2011, 03:21 PM   #6
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
it really depends how soft his suspension is. i know it doesn't relate to subaru's easily but my friend with a 07 speed3 went from 215(stock) to 225 and his rears rubs all the time with a 2nd or 3rd person in the car. His car is still on stock suspension and stock size rims but his rear's rub all the time
nighthawk06si is offline   Reply With Quote
Old 01-20-2011, 04:22 PM   #7
surfskater2003
Member#: 267991
2001 legacy b4 rsk
white
Default 225/50r16
The last set of tires i bought were 225/50R16's haha. My rear fenders were cutting into the tire itself so I had to roll the rear fenders. The fronts would also make a horrible noise when I cornered as well. for me, the width of the tires made them rub on the inside of the front fenders.
is that the sound your getting from your tires rubbing?
surfskater2003 is offline   Reply With Quote
Old 01-20-2011, 05:34 PM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I ran 225/45-18s on my 00 GT LTD.
I also ran 235 width on 7.5" Rota SDRs. 205 is narrow.
No fender rubbing in the rear and only very rare, full lock, over driveways rubbing on the front.
Get someone with an iPhone or Android, or GPS, to find out how much your speedo is off, and you'll be able to adjust in no time.
DLC is offline   Reply With Quote
Old 01-20-2011, 05:48 PM   #9
surfskater2003
Member#: 267991
2001 legacy b4 rsk
white
Default iphone?
haha, I dont think an Iphone would cut it. My Iphone once told me I was walking at 18 miles per hour...? haha but mine is a piece of crap.
Old 01-20-2011, 11:26 PM   #10
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Default Thanks folks - I think you're right that...
it may not be the tires rubbing. I pulled one wheel off and could not find any evidence or witness marks where it was rubbing. I checked the CV boots last night and they look good. Hmmm...I noticed the brake pads are about due for replacement. Maybe the left is more worn and I'm getting some rubbing. Will start there and then start considering bearings.
It is not a popping noise so I doubt ball joints - it definitely seems associated with speed so I'm suspecting brakes or tire rub.
-p
Old 01-20-2011, 11:27 PM   #11
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Oh yeah, and I checked speed against my GPS - it is only 1 MPH off.
Old 01-21-2011, 11:54 PM   #12
paddleboy
Member#: 122272
2006 Baja Sport
2001 Legacy L
Originally Posted by surfskater2003 View Post
The last set of tires i bought were 225/50R16's haha. My rear fenders were cutting into the tire itself so I had to roll the rear fenders. The fronts would also make a horrible noise when I cornered as well. for me, the width of the tires made them rub on the inside of the front fenders. YouTube - passenger-cam is that the sound your getting from your tires rubbing?
No, not at all. I get a very low frequency, deep pulsing sound.
Old 01-22-2011, 02:02 AM   #13
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
^ Sounds like a wheel bearing.
Old 01-22-2011, 08:59 AM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I agree with him ^^^ again.
Old 01-22-2011, 01:08 PM   #15
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
It certainly COULD be a wheel bearing, although with the worn brake pads, it could also easily be a sticking brake caliper.
Jonathan is offline   Reply With Quote
Consequence of using wrong tire size... JuggernautTCW Tire & Wheel 4 03-11-2008 11:02 AM
When to put on summer tires? dedgley North West Impreza Club Forum -- NWIC 19 02-27-2006 09:40 AM
When do YOU put on Winter tires? sizzflair Tire & Wheel 49 09-29-2005 03:25 PM
Bought a WRX, but wrong tire sizes? apak123 Tire & Wheel 11 08-18-2005 01:30 AM
Poll:Cols. Oh: Should I put on snow tires? LB2.5rs Mid West Subaru Owners Club Forum -- MWSOC 15 12-05-2003 04:45 PM
