Old 07-09-2002, 10:18 AM   #1
mprezme
Member#: 1814
2013 STI-Hatch*SOLD*
Default 30,000 miles...
Well last night i got into my 29,000 mile status, and i know theres got to be a damn 30,000 maintenace on the car. does anyone know what it consist of, and if its really worth, or can i get it done cheaper, by going elsewhere, im sure the dealer wants like 300+ for it(dont really want to take it their with the intake, hehe). anyway please let me know, thank you.
mprezme is offline   Reply With Quote
Old 07-09-2002, 10:52 AM   #2
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Look in your manual or go here subaru.com.
HIHO is offline   Reply With Quote
Old 07-10-2002, 02:23 AM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default Use the Subaru.com website
Mouse over, in sequence at the top of the browser just to the left of "Find a Dealer", "Owners" and that will bring up "Subaru Care" below it and that will bring up "Maintenance Schedules" below that. Click on "Maintenance Schedules" then select your year (2000) and then look for either the Federal or the California schedule that matches your car/location (Arizona). Here's the 30,000 Federal maintenance info for 2000 Subarus:
Inspect:
Drive belt(s) [Except camshaft]
Camshaft drive belt I
Transmission/Differential (Front & Rear) lubricants (Gear oil)
Automatic transmission fluid
Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Brake linings and drums
Replace:
Engine oil
Engine oil filter
Engine coolant
Fuel filter
Air cleaner element
Spark plugs
Brake fluid
Perform:
Inspect cooling system, hoses and connections
Inspect fuel system, hoses and connections
Inspect brake lines and check operation of parking and service brake system
Inspect clutch operation
Inspect steering and suspension
Inspect front and rear wheel bearing lubricant
Valve clearance
Inspect (every 10 years) Supplemental restraint system
My suggestion would be to pull down a copy of the schedule from the Subaru.com website and check off/date/mileage the pieces that you can do. Unless you've got the tools and the time, the only thing I'd probably leave for the dealer would be to drain, checkand refill the coolant system. There's a process to this that I'm not familiar with to ensure that no bubbles/air gets trapped in the system. You could also have them do the brake fluid replacement at the same time. That way, you save some money by doing it yourself and you get all the blocks checked off on the maintenance schedule.
Br, Dale
Subietonic is offline   Reply With Quote
30,000 mile maintenance + info and pics! zaphod Normally Aspirated Powertrain 33 07-31-2006 01:45 AM
How many people have over 30,000 miles on a m/t 2.5 rs with no clutch shudder? driver Transmission (AT/MT) & Driveline 21 10-27-2001 03:05 PM
Time for a true 30,000 mile tune up, any advice? Boom New England Impreza Club Forum -- NESIC 2 09-26-2001 08:21 PM
30,000 mile check-up SupaScooby Newbies & FAQs 4 03-05-2001 05:52 PM
For the first 30,000 miles what do we use instead of synth? ChosenWon Newbies & FAQs 7 11-06-2000 07:31 PM
