Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 01-20-2011, 12:52 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW - Big Tube UpPipe From PERRIN "Is Bigger Better?"
PERRIN Performance Big Tube Up Pipe
The always popular UpPipe was PERRIN Performance's first product produced way back in the old days.
Now we are taking it a step further with the Big Tube UpPipe.
Special Introductory Price, Only $219.00 (msrp $239.99)
The "BIG" Tube Up Pipe
PERRIN has been known since our inception for the quality of our up pipe. The up pipe was the first product we ever released and has been a leader in this market ever since. Now we introduce the next evolution of the up pipe. The Big Tube Up Pipe is for enthusiast who are using a larger stock location turbo and are limited by the flow rates of a stock sized up pipe.
Precision CNC Bent Tubing
304 stainless steel tubing is CNC mandrel bent and precisely welded to perfection. Our precision CNC bent tubing eliminates the need for a flex joint, which is a major weakness in other up pipes including the OEM pipe.
Flanges
Flanges are all CNC machined from 1/2", 304 stainless steel to prevent warping. Flanges are now counter on the backside for smoother transition from header to tube and up pipe to header. The center bores of the flanges are port matched for a smoother exhaust flow. Proper sized ports increase exhaust velocity and assure gaskets will not burn out.
Critical Correct Sizing
The PERRIN Big Tube Up Pipe has a 2" diameter which best matches aftermarket headers and the inlets of aftermarket turbos. The images above show the difference between the standard up pipe (right) and the Big Tube Up Pipe (left)."]
PERRIN is offline   Reply With Quote
Old 01-20-2011, 01:15 PM   #2
25rsti
Member Sales Rating: (130)
Member#: 166324
Sweet. Anything for your rotated setup or just stock location?
Old 01-24-2011, 11:12 AM   #3
PERRIN
NASIOC Manufacturer
Member#: 6776
This is designed for stock location turbos.
Old 02-22-2011, 09:15 PM   #4
tmeultraman
Member Sales Rating: (6)
Member#: 49610
at what point would the larger uppipe be worth it? if im running grimmspeed ported headers and say a 20g i would see the benefit, but what about stock headers and say a 16g? thanks for the response!
tmeultraman is offline   Reply With Quote
New Turbo inlet Hose From PERRIN Performance PERRIN Perrin Performance 33 07-14-2011 01:18 AM
HELP! Coolant tube disconnected from radiator...bigger problem? Kulith Newbies & FAQs 4 12-11-2010 12:40 PM
NEW Turbo Inlet Hose From PERRIN Performance PERRIN Vendor Announcements 5 10-16-2010 10:41 PM
Perrin 3" Big Turbo inlet tube trade for Perrin Standard fastwrx04 Engine/Power/Exhaust 1 02-18-2008 03:40 PM
Perrin BIG MAF, uppipe,wastegate drewwrxrogers Private 'Wanted' Classifieds 2 04-05-2007 01:13 PM
