Old 01-20-2011, 05:02 PM   #1
twnygren
Member#: 246141
1999 Impreza OBS
Green
Default Phase I EJ22 into a Phase II Car?
I am looking at buying a 99 impreza with a blown motor. I know the MY99 imprezas have a phase 2 ej22. Would it be possible to drop a phase I long block into the phase II car? I know I would need a new exhaust manifold because the 99 ej22 has single port heads and the earlier ej22's have dual port heads. The part I am worried about is the intake manifold. Is the phase I and phase II intake manifold compatible?
twnygren is offline   Reply With Quote
Old 01-20-2011, 05:04 PM   #2
JoshP
Member#: 94350
No they arent. You could swap shortblocks, thats about it
JoshP is offline   Reply With Quote
Old 01-21-2011, 12:00 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
You can do it but you haveto keep the phase I intake manifold and swap the sensors from the phase II engine onto the phase I engine. I have actually done the swap you're talking about and it runs fine.
PhilSine is offline   Reply With Quote
Old 01-22-2011, 05:32 PM   #4
JoshP
Member#: 94350
Im sorry my post wasnt very clear, but yes you can do it with swapping like mentioned above. Most people want plug and play though, and it would be far from that. PhilSine- could you comment on how much work it was to do? Any customizing? Ive never heard from someone who actually has done it.
Old 02-02-2011, 02:03 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
It was minimal work. I only swapped the newer sensors onto the older block, swapped on the newer PS pump/bracket, alternator and bracket, and AC w/bracket (same bracket as alternator). I had a dual port exhaust on hand and simply got the correct gaskets for it as the dual port exhaist exits the same as the single port one so it mated right up to the rest of the exhaust.
Nothing else had to be done. Since both engines are SOHC, the ECU was none the wiser.
99 Phase II ej22 into 99 Forester Phase II ej25 subiman2005 Forester Forum 2 10-18-2009 10:39 PM
ej22 phase I head gasket vrs phase II alejo Normally Aspirated Powertrain 3 04-03-2009 12:59 PM
1998 phase 1 EJ25 into 2000 phase 2 EJ22 OBS. s'ko Subaru Conversions 0 04-14-2008 12:20 PM
Will EJ22 and EJ25 Phase II Cams Swap? GuyLR Normally Aspirated Powertrain 0 04-13-2005 12:43 PM
Phase 1 EJ22 mated to Phase 2 EJ25 SHortblock? huckedup16 Normally Aspirated Powertrain 0 03-25-2004 09:24 PM
