Old 01-20-2011, 05:16 PM   #1
Johnnyk2851
Member#: 249327
Default 98 forester p0302 misfire
I'm driving a 98 forester with 200k roughly. It has been constantly giving me a p0302 misfire in the 3rd cylinder. I have replaced the spark plugs, and wires, but it did not help. Any other suggestions of where to go next or what it may be?
Johnnyk2851 is offline   Reply With Quote
Old 01-20-2011, 05:19 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
coilpack where all 4 wires come from
AliBenn is offline   Reply With Quote
Old 01-20-2011, 08:59 PM   #3
Johnnyk2851
Member#: 249327
The coilpack was replaced also
Old 01-20-2011, 09:13 PM   #4
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
first off a PO302 is a misfire in cylinder #2. if plugs, wires, and coil didnt fix it you have two more things to check, fuel, and compression. your injectors could be clogged or the electrical connecting is bad. compression is a tougher thing to test but you can check for a cylinder leak down test to see if that one cylinder can hold its pressure.
Good luck
Matt515 is offline   Reply With Quote
Old 01-20-2011, 09:28 PM   #5
elkyboy76
Member#: 204258
you need to do a compression check, have had many with burnt valves (common problem)
elkyboy76 is offline   Reply With Quote
Old 04-07-2011, 01:30 AM   #6
subbykc
Member#: 264573
2002 Legacy L
light silvergreen
I have to same problem is this an easy fix?
subbykc is offline   Reply With Quote
P0302 misfire code 03 spec r1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-14-2010 12:40 PM
Code P0302 misfire #2 Impwrxza Vancouver Impreza Club Forum -- VIC 4 06-21-2009 09:04 PM
HELP! P0302 Misfire Detected in Cylinder #2 awd-box-turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-03-2008 02:05 PM
04 Forester front end on a 98 forester Cstmboxermotorsports Subaru Conversions 0 05-05-2008 09:03 PM
98 Forester, tire rubbing. Possible strut from a non-forester? (pics) thrdeye Forester Forum 1 01-04-2005 10:42 AM
