Welcome to the North American Subaru Impreza Owners Club Wednesday April 22, 2015
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 07-03-2011, 03:52 AM   #1601
brocksdad
Member#: 107352
Not Respectable
Originally Posted by yman View Post
I'm about to send a request for the software. I ended up doing the intake thing, the car runs great with it but for some reason twice yesterday in traffic I threw a P0171/flashing check engine light.
I also noticed when I checked the MAF that there is a chunk missing out of the o ring, so I'm going to try and find the o'ring at a parts store.
I also ordered turbo blankets for both cars, and heat wrap to wrap half my downpipe, as well as my headers/uppipe.
Pretty much, I'm just trying to figure out more about the car and what is happening, not to mention the AP keeps shutting off while monitoring under boost (7psi+) I've deleted all the logs/almost all the maps so I know its not a memory problem, unhooked the obdII port and its still wonky. Yesterday I was loggin' when it threw the code the first time. I tried resetting the ECU because I had forgotten to when I put that intake mod on, and the car was runnin like doodoo for about 20 minutes, then it seemed ok. Up until the code it seemed great. Now it feels like there is a boost leak, and some weird hesitation between 2.7k and 3.0k with/without the mod.
I've checked everything and it seems fine. The only thing I see that is an issue is lately the AFR's aren't very stable when cruising or at idle. They bounce around from 13-16, and are worse with the intake mod so I took it off. They are still like 13-15.6 though. Could this be from the o'ring problem? Fuel filter? It seems to run better with the mod so who knows. I just wanna know whats goin' on and hopefully not drop $380 every time I want to adjust or change something.
p.s. if anybody wants to sell me a wideband kit for under $100 lemme know
P0171 is a lean code. It could be from the O-ring. A vacuum leak will cause that code to come on. It could also be from the new intake routing.
It might have been running like "doodoo" because the way the air was flowing over the maf. Remember what Cory said about the fluid dynamics.
Also, the wrx has gone all the way to 25.5 afr should I get it checked out. Its under deceleration but I'm just wondering what the extreme is, the sti never goes anywhere out of 11.0 to 20.7 so..
Any car will go lean under a deep vacuum, or deceleration. I wouldn't worry about it.
brocksdad is offline   Reply With Quote
Old 07-03-2011, 11:28 AM   #1602
yman
Member#: 199051
04 sti
psm
I replaced the O ' ring.
I wish I could make the intake behave the same for the fluid dynamics. What should I be logging to see if it is running the same? Maf G/S, short/long fuel trim, and AFR?
Anyways, I'll probably be puttin in spark plugs sometime in the next 2 weeks also while I've got the car apart wrapping the headers/downpipe.
yman is offline   Reply With Quote
Old 07-03-2011, 02:31 PM   #1603
brocksdad
Member#: 107352
Not Respectable
Really just look at your short/long fuel trims. If they are too deep in the (+) area, your car is running lean. The full range of the short fuel trim is -25 - +25, the full range of the long fuel trim is -15 - +15.
If the car threw a check engine light after you put the extension pipe on the intake, I would say the MAF needs some scaling done to it. Unless of course the only reason the light came on was simply because of the O-ring.
Old 07-03-2011, 03:25 PM   #1604
yman
Member#: 199051
04 sti
psm
I am thinking it probably needs to be scaled. I'm going to try one more setup and log, otherwise I'll switch it back and just suffer through the 180-200 degree intake temps.
Old 07-04-2011, 01:48 AM   #1605
brocksdad
Member#: 107352
Not Respectable
If you have the software, there's no reason to suffer through anything. Just scale the MAF. If you need help, let me know. My lessons aren't free though.
Old 07-04-2011, 06:42 PM   #1606
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Your NASIOC Administrator
madmax_087 is offline   Reply With Quote
Old 07-05-2011, 09:48 AM   #1607
yman
Member#: 199051
04 sti
psm
lol dude I'm happy to pay for some lessons, I'm at that point where I just think I should be able to start doing the easy stuff at least.
Anyways, back-to-school-for-the-first-time-in-5-years bump, gonna be at ASU Polytechnic campus in BFE (owait thats where most of you guys are at)
Old 07-06-2011, 05:47 PM   #1608
Black_EG
Member#: 239917
2005 STi
Buttersauce!
Black_EG is offline   Reply With Quote
Old 07-06-2011, 11:51 PM   #1609
brocksdad
Member#: 107352
Not Respectable
Originally Posted by Black_EG View Post
Buttersauce!
Mmmmmm!
Old 07-07-2011, 01:38 AM   #1610
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
At the Track
School is for fools!
Old 07-07-2011, 02:19 AM   #1611
pajak
Member#: 95992
08 E92 335i
Grey
i wont make it out this week either.. last week i had full intentions on coming but the power was out, so i tried to manually open the garage door by pulling the release and lifting but somehow came off track and the top part fell off.... oops.. this week im using my schedule change to go to the AWOLNATION concert so wont be able to make it out tomorrow unless its after 9
pajak is offline   Reply With Quote
Old 07-07-2011, 11:55 AM   #1612
Momosaurus WRX
Member#: 214737
Awhatukee caravan? park and ride, at pecos and 40th at 7:00-15 ish?
Momosaurus WRX is offline   Reply With Quote
Old 07-07-2011, 01:16 PM   #1613
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I'll head out for a while I think. The wagon's battery is flat again. I'm thinking it is not long for this world and that I will be shopping for a new one soon. I'll probably rock the GC tonight instead.
Old 07-07-2011, 01:21 PM   #1614
Evil Imports
Member#: 14732
+ 13 B8
Erik came and stole my extra battery the other night
Evil Imports is offline   Reply With Quote
Old 07-07-2011, 01:33 PM   #1615
kpluiten
Member#: 120273
06 WRBWRXWGN
Steal his motor. That'll learn him.
Old 07-07-2011, 02:30 PM   #1616
yman
Member#: 199051
04 sti
psm
Delicious fresh turbo blanket smell
Old 07-07-2011, 04:05 PM   #1617
Momosaurus WRX
Member#: 214737
I'll be crawling underneath some of your cars tonight with a tape measure, don't mind me
Old 07-07-2011, 04:06 PM   #1618
mc06STI
Member#: 244681
2006 Impreza wrx STI
SGM
im going! who else?
mc06STI is offline   Reply With Quote
Old 07-07-2011, 04:48 PM   #1619
kpluiten
Member#: 120273
06 WRBWRXWGN
Who's cars are you planning to climb under? These aren't really high cars. Unless you're a holocaust victim or built like a 12 year old girl, you'd better bring some ramps.
Old 07-07-2011, 07:26 PM   #1620
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Subaru Stars
This guy could probably get under Erik's
Old 07-07-2011, 07:27 PM   #1621
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Oh, and ill be out tonight
Old 07-07-2011, 08:17 PM   #1622
Black_EG
Member#: 239917
2005 STi
Pure evil in this thread. Lol
I don't know if I want to. My back is hurting like hell.
Old 07-07-2011, 09:09 PM   #1623
Momosaurus WRX
Member#: 214737
haha. If you haven't noticed... I am kinda built like a 12 year old girl.
I just need to look at 2 bolt holes on the lower rad support, and bumper to ground clearance vs. lower radiator support to ground clearance.
Old 07-07-2011, 09:48 PM   #1624
Momosaurus WRX
Member#: 214737
I heard that there's a buffalo wild wings meet in Scottsdale for Rich Spohr tonight. Should we caravan over there?
Old 07-07-2011, 09:58 PM   #1625
yman
Member#: 199051
04 sti
psm
any more info on this? Source?
PHX: The NEW Weekly Westside meet! WRX357 South West Impreza Club Forum -- SWIC 1220 09-18-2014 10:34 AM
Eastside meet then Alki IV Meet 96WRX North West Impreza Club Forum -- NWIC 41 07-20-2008 01:06 PM
HR new weekly meet ideas, summer oriented LotusDriftx Mid Atlantic Impreza Club -- MAIC 17 04-10-2005 05:43 PM
trying to start a new weekly meet?? silverwerx Mid Atlantic Impreza Club -- MAIC 120 02-15-2005 01:57 AM
