Old 07-09-2002, 01:36 PM   #1
IMPEZER22
Member#: 12622
95L 2.2T
02 WRX Cobb Stage II
Default Do i need the stock FPR with a RRFPR?
Just like it says. I never hooked one up and just need some guidence.
Thanks Chris
IMPEZER22 is offline   Reply With Quote
Old 07-09-2002, 01:37 PM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
Default Re: Do i need the stock FPR with a RRFPR?
Thanks Chris
yes.
what RRFPR are you using?
Jewbaru is offline   Reply With Quote
Old 07-09-2002, 01:39 PM   #3
IMPEZER22
Member#: 12622
95L 2.2T
i think its a vortec
Old 07-09-2002, 01:39 PM   #4
Bobby321
Visiting NASIOC Timeout
Member#: 19774
Hey chris...
I am also Tuboing my 1.8 95 Impreza L... i was wondering if u designed ur own up-pipe or purchased one. Also if u can give me some details on ur install id appreciate it. Also any pics????
In regards to ur question Chad at www.uniquemotorsports.com turboed the same car and has some links on his page about the RRFPR... u may want to chk there if u already havent.
Bobby321 is offline   Reply With Quote
Old 07-09-2002, 01:43 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
kastle is offline   Reply With Quote
Old 07-09-2002, 01:51 PM   #6
IMPEZER22
Member#: 12622
95L 2.2T
yes i made my own up and down pipes. I got all my info from chads web page and i found it very useful. I used pretty much the same stuff he did like the saab intercooler. Just PM me to let me know what exactly you want to know. I'll have to get some pics around later. Right now i'm at school.
Thanks Chris
Old 07-09-2002, 08:22 PM   #7
IMPEZER22
Member#: 12622
95L 2.2T
Why do i need the stock FPR anyway? I want to know just so i understand. Thanks guys for all the info.
Thanks Chris
Old 07-10-2002, 07:52 AM   #8
giulio
Member#: 16040
1998 Impreza RS
Supercharged
The stock FPR controls fuel pressure by the intake manifold pressure in the ranges of 0 to 20, or more, inHg (vacuum).
The Votech FMU (i have one installed) controls fuel pressure from 0 to [max boost] psi (boost).
The FMU is an add-on, not a replacement, for fuel pressure regulation.
It should be intalled in the return line, after the stock FPR.
g
giulio is offline   Reply With Quote
Old 07-10-2002, 01:16 PM   #9
IMPEZER22
Member#: 12622
95L 2.2T
thanks for all the help
Chris
what length rca's do i need for a sedan with amps in the trunk? alpnwhite96 Car Audio, Video & Security 14 10-25-2006 10:48 PM
Do I need a different FPR? ShadowWRX77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-13-2006 09:14 PM
Need quick help: can I use the stock midpipe with aftermaket donwpipe and axleback? ewright Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-07-2005 01:29 PM
Do I need the high output fuel pump with my set-up? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-18-2002 12:30 AM
Anybody Relocated the Stock FPR? stimpy Normally Aspirated Powertrain 11 04-03-2001 09:28 AM
