Old 01-21-2011, 06:33 PM   #1
golf_o
Member#: 232836
1995 sti ra
white
Default speedo cable to electric dashboard
hi.
i want to convert the mechanical speedo cable of my 95 gearbox, to my 98 dashboard with electrical speedo conector.
how i can to make it?
thaaaanks!!!!
golf_o is offline   Reply With Quote
Old 01-21-2011, 07:01 PM   #2
DCCDPro
Member#: 227549
If you have abs sensors you can use my new VSSPro product.
It processes the signal form the abs tone ring to a proper VSS signal for the dash and the ecu.
-Jeff Reid
DCCDPro.com
DCCDPro is offline   Reply With Quote
Old 01-21-2011, 07:10 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
Unscrew the cable drive from the trans and screw in a speed sensor. It's that simple.
Old 01-28-2011, 09:41 PM   #4
h_p
Member#: 96894
^ what about the wiring then? have to make something work? just wondering
h_p is offline   Reply With Quote
Old 02-04-2011, 01:46 AM   #5
riffraff
Member#: 244244
1995 impreza
primer black
not to thread jack but im have the same problem what do we need to do with the wiring to the dash
riffraff is offline   Reply With Quote
Old 02-04-2011, 03:03 PM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Converting from a Cable VSS to a electric VSS is a PITA. You need to completely replace the cluster and in doing so rewire the cluster and add the circuit for the VSS. I have done a few of these conversions and it works but if you've never done it before I would not recommend attempting it.
Zephyr is offline   Reply With Quote
Old 02-04-2011, 07:28 PM   #7
AKGC8
Member#: 1305
2000 Impreza
If you have an electric speedo dash like the OP did then it should be plug and play. Otherwise it's a lot of wiring like Zephyr said.
AKGC8 is offline   Reply With Quote
longer speedo cable? AsphaltsCry Transmission (AT/MT) & Driveline 6 11-06-2011 10:08 PM
96 legacy 5mt>95 impreza speedo cable help bobturismo Transmission (AT/MT) & Driveline 10 01-06-2004 11:47 PM
Anyone using the speedo cable on their WRX swap? Aspen Subaru Conversions 1 10-08-2003 11:39 PM
Speedo cable part #? Legacy imprezza ciper Legacy Forum 1 06-17-2002 07:40 PM
pelz help speedo cable problem iceman Technical Forum Archive 0 07-06-2000 08:43 PM
