Old 01-22-2011, 12:09 AM   #1
Kontankerous
Member#: 257551
2011 WRX
Satin White Pearl
Default 2011 Impreza WRX/STI Sedan Rear Shelf - Stopping The Rattle [Part I]
I call this Part I, because i will eventually get down to the entire car as I slowly progress to other areas during the installs of aftermarket bliss.
I started off with the rear shelf because that and the front door panels are the most annoying thus far in the rattle dept. Plus I removed the rear shelf plastics so I could get closer to the rear window to install my tint (although it didn't provide me with much extra room].
Step I:
Disassemble the rear c-pillar trim. The piece closest to the rear window comes out first. The top most corner is held on by a plastic push rivet. Be careful as you pull the front trailing edge, it does just snap in 3/4 of the way into the rear triangle surround plastic, but you have a metal push clip that you will need a flat head to depress the tab to release (unless you have REALLY small hands).
Step II:
Pop off the bolt cover on the rear triangle glass surround. Using a 10mm socket remove the 3 bolts securing the rest of the c-pillar in place. Gently pull to release the one plastic pin, slide the surround down the seat belt to where it sits safely on the back of the lower rear seatback.
Step III:
Remove the rear brake light assembly (if you have it). Held on underneath the shelf with two 10mm bolts and a plastic clip toward the rear of the assembly (front of the car). Unhook the wiring harness and remove light.
There are 2 plastic pins holding the rear shelf plastic in at the front left and right corners you need to remove (rear seat back of course has to be down to see and get to these). Gently/firmly pull out and up on the front lip of the plastic shelf to release.
Underneath (from inside the trunk)you will notice 3 accessible WHITE pins. Using a pair of needle nose, gently pinch and push up. There are a total of 5 pins, you can only get to 3 of them.
Gently pull up on the front of the shelf plastic to release the 2 front white pins and you should now be able to maneuver the plastic out off the shelf exposing the wiring for the airbags, brake light, defroster, and keyless module.
**I'll grab some pics of this, I forgot***
Kontankerous is offline   Reply With Quote
Old 01-22-2011, 12:10 AM   #2
Kontankerous
Member#: 257551
2011 WRX
Satin White Pearl
Step IV:
There are 6 points of contact that I found that cause the rattle.
1-4 are the rear edge of the plastic shelf, it has 4 fins that are covered in an adhesive foam. You can see that it's worn through from rubbing the metal shelf underneath. i pointed out the spots on the metal shelf where you can see the rubbing from the plastic fins on the bottom of the plastic cover.
5 is the trailing edge of the plastic shelf where it touches the glass.
6 is the keyless module; it's a small metal clip suspending the module slightly above the metal shelf, the thin metal support flexes quite a bit allowing the module to vibrate against the metal. Remove this with a 10mm socket.
Old 01-22-2011, 12:11 AM   #3
Kontankerous
Member#: 257551
2011 WRX
Satin White Pearl
Step V:
Cut pieces of vibration dampening material, be it foam tape or butyl mat.
Place (4) 1.5"x.75" pieces where the 4 fins rub against the shelf.
Take a roll of .25 foam weatherstrip and adhere it to the trailing edge of the plastic shelf covering (topside where it meets the window).
Cut another 1.5"x3" piece of butyl mat or foam tape and adhere it where the keyless module
Step VI:
Install everything in reverse order of removing it.
Step VII:
Drive around and ask yourself, "Why the hell didn't I do this before".
Old 01-22-2011, 12:34 AM   #4
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
very nice. . . . i always figured it was the plastic covers over the hooks for a car seat because i after i used them they grew alot louder.
i really need to stop being lazy and fix this rattle, im just going to sound dampen the whole area
THE_SMURF is offline   Reply With Quote
Old 01-22-2011, 03:31 PM   #5
deanesn
Member#: 260578
2011 WRX Premium
Very nice write up. Finally someone brave to tackle this problem. I'm definitely doing this as soon as it warns up outside. Thanks a lot.
deanesn is offline   Reply With Quote
Old 04-02-2011, 12:42 PM   #6
101101
Member#: 260658
2011 STI Sedan
Any chance you could update this thread when you do more rattle tracking down in other places? I had this same issue in my sedan and this thread was very useful.
101101 is offline   Reply With Quote
Old 04-02-2011, 02:11 PM   #7
chester09
Member#: 214020
2016 STI
LBP
Just a heads up, I took my car to the dealership and they did all this for me for free under warranty, even the rear shelf. For the doors they knew were the rattles were and for the rear deck I showed them where I thought the rattles were coming from. Been a month now and still no rattles
chester09 is offline   Reply With Quote
Old 04-02-2011, 07:27 PM   #8
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Nice write-up, thanks man!
Stu_Gotti is offline   Reply With Quote
Old 04-05-2011, 01:45 AM   #9
Omutax
Member#: 243663
2011 WRX Sedan
I took my car to the dealer today to ask them about fixing my rattles after mentioning this thread, they said they couldn't recreate it after going out on a 5-min drive with it. They said they don't want to tear it apart for nothing.
I heard the rattling on the back shelf pretty much as soon as I was exiting the place and my drive home.
Omutax is offline   Reply With Quote
Old 04-05-2011, 07:34 AM   #10
k757
Member#: 274785
2014 Ford Fiesta ST
when I go in for rattles, I ask for a tech to go out with me right off so I can recreate and point out for them the rattles. I have one in each front door to point out when they get worse.
k757 is offline   Reply With Quote
Old 04-11-2011, 06:45 PM   #11
101101
Member#: 260658
2011 STI Sedan
Over the weekend I did this but when I took off my shelf I didn't have as much wear as you do (there was some wear). I did the foam on the contact points to play it safe but also put the soft side of velcro on all plastic pieces (C pillar components) where plastic-on-plastic contact would occur. If you do it right, you can't see the velcro once the pieces are installed.
These two things combined eliminated all squeaks / rattles from the rear of my sedan.
Old 05-23-2011, 12:14 AM   #12
Trigg
Member#: 151781
2011 STI Sedan
Also did this this weekend, but im having problems with the lower piece of the panel below that is closest to the windshield not staying "clipped" in place. I used the quotations, because all i can see are two little notches that i guess are supposed to hold it in?? To clarify what im talking about, its the section in the upper right corner of this photo.
Trigg is offline   Reply With Quote
Old 05-23-2011, 06:59 AM   #13
101101
Member#: 260658
2011 STI Sedan
I don't remember that from doing it; to further make you disappointed, the rattle came back in mine. I'm guessing the velcro fuzz got compressed over time and lost its padding ability. I ordered some single-side foam tape from McMaster-Carr and if it doesn't rain will replace the velcro this weekend (and take off the plastic shelf cover again to measure for more padding).
Old 08-04-2011, 11:59 AM   #14
talisker
Member#: 238447
2008 Impreza 2.5i
Spark Silver Metallic
Sorry to bring up an old(er) thread, but this might be helpful.
I followed this procedure on my 2.5i (thanks for the tutorial by the way)! Although I noticed similar wear as you on the metal portion of the rear shelf, adding the butyl mat and weather stripping didn't seem to fix the rattling I was experiencing.
It turns out that the rattling was coming from the airbag brackets vibrating against the shell of the car. You can sorta see these brackets in the second picture of Step II in the OP. I could duplicate the noise by bumping the plastic piece surrounding the triangular window. Gently pushing on the airbag cylinder would make an audible clicking noise, so I figure a higher frequency vibration would sound more like a rattle.
At any rate, if you stick some butyl mat between the brackets and the shell of the car, the rattling disappears! (I tried tightening the bolts at first, but they were already fully tightened).
talisker is offline   Reply With Quote
Old 08-04-2011, 12:04 PM   #15
n2oiroc
Member#: 141952
15 legacy 16 wrx
anyone else getting a noise at the b pillar? i think its where the shoulder harness attaches.
n2oiroc is offline   Reply With Quote
Old 08-04-2011, 12:07 PM   #16
k757
Member#: 274785
2014 Ford Fiesta ST
yes, I patched it with a wad of napkins pushed into the seam of the pillar & deck. On my last visit to Subaru, they fixed it correctly.
Old 09-27-2011, 07:25 PM   #17
jay7660
Member#: 212992
2011 STI Sedan
awesome! any updates?
jay7660 is offline   Reply With Quote
Old 09-29-2011, 11:16 PM   #18
echardcore
Member#: 260638
2011 WRX Sedan
i was waiting for this thread to show up. that back deck is the loudest rattle.
happens when engine is struggling due to too low RPM.
echardcore is offline   Reply With Quote
Old 10-23-2011, 11:53 PM   #19
pennyrobber
Member#: 294504
2016 STI
Finally got around to doing this fix today. Worked great. Thanks again for the write up.
pennyrobber is offline   Reply With Quote
Old 10-24-2011, 02:12 PM   #20
RAzevedo330
Member#: 271121
2011 WRX Limited 4dr
SSM
need to do this!
RAzevedo330 is offline   Reply With Quote
Old 10-24-2011, 09:07 PM   #21
celosteelo
Member#: 80062
06 STi
Nice!
celosteelo is offline   Reply With Quote
Old 10-25-2011, 12:55 AM   #22
wrxstier
Member#: 295670
i have the same issue on my 2010 hatch but seems the rattle comes from the headboard at the back. cant really find where the rattle is coming from.
wrxstier is offline   Reply With Quote
Old 11-04-2011, 02:39 AM   #23
jibaro
Member#: 163879
2005 Sti
blue
and i thought i was the only, great write up, gonna try it on my day off...temp fix i did that actually took most of the rattling out when im on the highway was .... stick pieces of folded cardboard around the plastic edges!..LOL...cured most of it, but i want to do it the correct way!
jibaro is offline   Reply With Quote
Old 11-04-2011, 09:57 AM   #24
RAzevedo330
Member#: 271121
SSM
I'm going to try this tomorrow but I'm going to Dynamat the whole rear shelf.
Old 11-24-2011, 02:41 PM   #25
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
So I have a weird tapping sound from the rear deck area (I think on the driver side). If I put the passenger-side rear seat down flat, the noise goes away. As soon as I snap it back in place the noise returns while driving.
I tried stuffing stuff behind the rear seat where it touches the deck, but no use. Any ideas?
2011 Impreza/WRX/STI Spoilers Buy/Sell/Trade NotSoStock11 Private 'Wanted' Classifieds 51 08-16-2016 12:09 PM
2011 Subaru WRX STI Sedan vs. 2007 STI AVANTI R5 News & Rumors 42 01-18-2011 10:47 PM
The wing returns! Subaru teases 2011 Impreza WRX STI sedan wrxposer Vancouver Impreza Club Forum -- VIC 103 04-25-2010 11:46 PM
2011 Subaru Impreza WRX STI Sedan Ryan314 News & Rumors 30 09-09-2009 03:29 PM
FS: NorCal JDM WRX/STI sedan rear windshield with rear wiper Seranin Exterior/Styling 8 12-06-2006 12:31 AM
