Old 11-26-2011, 03:09 PM   #26
camasite
Member#: 301536
2012 WRX Sedan
Hi everyone... I have a 2012 WRX sedan and noticed a bad vibration from the rear shelf as well. After tapping around everywhere and getting the vibration noise, I finally put a light pressure on the tab for what the OP has described as the "keyless module" where it sticks into the trunk and the vibration stopped. I jammed a small piece of automotive carpet into the hole next to the tab and it seems to have stopped the vibration -- the location is on the left side of the trunk about 8 inches to the right of the large square opening with the insulation in it, as shown in the attached photo. Not sure if this is a permanent fix, but it only took a few seconds to do compared to pulling the whole shelf apart, so might be something for others to try first.
camasite is offline   Reply With Quote
Old 12-13-2011, 08:11 PM   #27
SPTTuner
Member#: 291950
2011 WRX STI
Obsidian Black pearl
i foamed the crap out my rear deck and noise has 80% stopped...i think the rest of the noise might be the both sections of the C pillar... going to check that tomorrow
SPTTuner is offline   Reply With Quote
Old 12-13-2011, 08:13 PM   #28
Subirex09
Member#: 207880
2013 STi
Awesome SWP
I want to do this soon as well, you guys all using similar foam for the job? Just a thin closed cell like the OP?
Subirex09 is offline   Reply With Quote
Old 12-13-2011, 09:03 PM   #29
SPTTuner
Member#: 291950
2011 WRX STI
yea pretty much and some dynamat in some areas, in other areas i have dynmat and adhesive foam on top..lol
Old 12-13-2011, 09:23 PM   #30
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
I took out the whole shelf and c-pillars. I then used 1/4" or less foam tape and put on every part that might touch another piece of plastic, metal, wire, glass, etc. this got ride of the intermittent noises. However, I still had the constant creaking. I determined if you put something between the leather seat back and the rear shelf t stops. I bought really thick Air Conditioning foam that is about 3ft long by 4" wide. Works great and since it is dark gray you can't really see it from outside the rear window.
I love my car again!
Old 12-13-2011, 09:47 PM   #31
SPTTuner
Member#: 291950
2011 WRX STI
please elaborate more on this... what T stops??
Old 12-15-2011, 08:39 AM   #32
Subirex09
Member#: 207880
2013 STi
Awesome SWP
Those of you just using foam, what thickness are you using, and where can I pick it up? Jo-ann fabric or the like?
Old 12-15-2011, 01:52 PM   #33
Snow Drift
Member#: 75071
4 Train - Subway
IT stops. sorry.
Old 01-09-2012, 03:33 PM   #34
widescreen86
Member#: 221964
Thanks for the write up! Did this today and rattles are gone!
widescreen86 is offline   Reply With Quote
Old 03-08-2012, 08:39 AM   #35
WhiteStreak
Member#: 288333
2011 Impreza WRX Ltd
I'm pretty sure this is the foam tape I used - it's available at Home Depot.
Also, to the OP - thanks for such a great write-up! Most of my rattles from the back are now gone - woohoo!
The only rattle I was not able to fix was the buzzing coming from the rear seat belt reels. The center reel seemed to be the main problem, but all of them buzzed when I pounded on the rear deck. I couldn't find much with a search, but I did read a comment from GrimmSpeed that suggested popping off the plastic covers of the reels and visually inspecting them to see if there is anything loose that can be tightened down.
WhiteStreak is offline   Reply With Quote
Old 04-19-2012, 04:43 PM   #36
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
I completely removed my center seat belt Cold day in hell when I'm having to lug 3 people in the back of my rex. Good thing too cause if you want to remove the center belt there's no going back cause you have to cut it in two places IIRC. One is the metal that holds the lower attachment point (2 buckle points attache to the same metal / 1 bolt) and the other is the belt.
Nice clean look. I should take a pic.
Mike 01Hawk is offline   Reply With Quote
Old 04-19-2012, 08:08 PM   #37
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
I got a 12in sub that every time it would hit I had the annoying rattle. Here's what I did and this might be "ghetto" to some but it was free and works great....
Took the rear lid off(u all know how by now) took old bathe towel and cut it up and laid it out and cut to fit. Reassembled, no rattle now.
krzywhtboi82 is offline   Reply With Quote
Old 04-19-2012, 08:11 PM   #38
Jdmoon86
Member#: 283328
2011 SWP WRX 4-door
TorquedPerformance Stage2
I bought some foam pipe insulator, cut a strip out of it and stuffed it in there.
http://www.lowes.com/webapp/wcs/stor...AID=1023538896
Worked like a charm!
Jdmoon86 is offline   Reply With Quote
Old 05-09-2012, 11:08 AM   #39
rex.effect
Member#: 99745
2013 C-Max Hybrid
Titanium White TriCoat
Any updates from people who dynamat'ed the whole rear shelf? What about matting the c-pilars? I am not trying to avoid doing it a cheap way, rather want to sound deaden most of the rear anyway.
Did any complications arise when matting the whole area? Are there certain locations I should avoid so that the shelf returns to it's place properly?
rex.effect is offline   Reply With Quote
Old 05-09-2012, 04:36 PM   #40
Vietkaze
Member#: 230765
2009 WRX Sedan
THank you for posting. I will try this to get rid of the rattling in my wrx...
Vietkaze is offline   Reply With Quote
Old 05-11-2012, 08:46 AM   #41
Jose Gordils
Member#: 279134
2011 WRX STI sedan
Thanks for the info, very nice.
Jose Gordils is offline   Reply With Quote
Old 05-14-2012, 10:31 AM   #42
Jose Gordils
Member#: 279134
2011 WRX STI sedan
Thanks a lot for this write up! Finish the job yesterday, no more noise!
Old 08-29-2012, 10:26 PM   #43
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
Omg!!!! I just found this thread!!!! I've had the car since may and those rattles kill me, I always have my daughter in the back seat trying to pin point the origin of the rattle while I'm driving!!!! Hahahah she's a trooper , I'm gonna call the dealer and see if they know how to fix it, since I have to go in for an oil change. If not. I'll follow the steps on this thread and hopefully fix it!!!!
FerdSimao is offline   Reply With Quote
Old 08-30-2012, 07:01 AM   #44
DeadGeneration
Member#: 313753
2012 WRX
TSM Tuned - 310whp/340wtq
subscribed for awesome
DeadGeneration is offline   Reply With Quote
Old 08-30-2012, 11:01 AM   #45
nisti
Member#: 290168
2014 XV Crosstrek
CBS
Thanks for this thread
nisti is offline   Reply With Quote
Old 10-08-2012, 08:00 PM   #46
studgolfpro
Member#: 288840
2013 WRX STi
Crystal Black Silica
Great write up! I had a constant rattle from Day 1 since I bought the car. Turned out to be the Keyless Module. Followed these steps, padded up with some felt and thicker double-sided tape (because that's what I had laying around) and I'm in heaven!
studgolfpro is offline   Reply With Quote
Old 10-16-2012, 07:27 PM   #47
KManZ
Member#: 220694
2012 STi
Satin White Pearl
I've been attempting to track down the worst ****ing rattle in my '12 sedan... I've performed this tutorial twice already, I've stuffed more dense foam up under the rear deck lid as can be stuffed under a rear deck lid, and am still plagued by this creaking. It sounds like a tinny, higher pitched creak, not so much a vibration. Every little bump, side-ways motion, even louder than normal farts set the creaking off, and i can't take it anymore.
So I hired my roomate to ride in the rear to narrow down the cause, and I believe I've found the answer: the rear seat, namely the 2/3rd's side, is rubbing against the rear deck lid, causing the noise. I folded down the seats, and the sound isn't there. The smaller side in place, no sound. The bigger side: BAM! Annoying-as-**** creak returns.
Now that I know the cause, time to figure out a solution. Could take it to the dealer, but I'm not going to take off work for this bull**** until all options are exhausted.
KManZ is offline   Reply With Quote
Old 10-17-2012, 09:28 AM   #48
Snow Drift
Member#: 75071
4 Train - Subway
Do you have leather? I do and I get this same problem. The dealership can't do anything (as far as I know).
Here is my fix:
(might not be the right measurements, just for reference)
http://www.homedepot.com/buy/frost-k...rip-ac42h.html
Lay that between the back of the seat and the rear shelf, close the seats. That will put a nice cushioned barrier between and gets rid of the sound. Also, the dark gray color looks stock.
Old 10-17-2012, 11:44 AM   #49
yudangorgor
Member#: 151107
2011 WRX
with the car lowered now, my front dash is rattling and squaking.. is there a write up tutorial on how to remove the components of front dash?
yudangorgor is offline   Reply With Quote
Old 11-02-2012, 04:45 PM   #50
rdejesus486
Member#: 320454
subscribed because this is driving me nuts.
rdejesus486 is offline   Reply With Quote
2011 Impreza/WRX/STI Spoilers Buy/Sell/Trade NotSoStock11 Private 'Wanted' Classifieds 51 08-16-2016 12:09 PM
2011 Subaru WRX STI Sedan vs. 2007 STI AVANTI R5 News & Rumors 42 01-18-2011 10:47 PM
The wing returns! Subaru teases 2011 Impreza WRX STI sedan wrxposer Vancouver Impreza Club Forum -- VIC 103 04-25-2010 11:46 PM
2011 Subaru Impreza WRX STI Sedan Ryan314 News & Rumors 30 09-09-2009 03:29 PM
FS: NorCal JDM WRX/STI sedan rear windshield with rear wiper Seranin Exterior/Styling 8 12-06-2006 12:31 AM
