Old 12-03-2012, 08:01 AM   #51
KManZ
Member#: 220694
2012 STi
Satin White Pearl
Do you have leather? I do and I get this same problem. The dealership can't do anything (as far as I know).
Here is my fix:
(might not be the right measurements, just for reference)
http://www.homedepot.com/buy/frost-k...rip-ac42h.html
Lay that between the back of the seat and the rear shelf, close the seats. That will put a nice cushioned barrier between and gets rid of the sound. Also, the dark gray color looks stock.
EDIT: sir, what is your Paypal address, so that I can send you a fricken reward! The nightmare is over, thank God!
I don't have leather, but the rear seats are "topped" with leather, which is contacting the rear deck lid. I will try this out tonight for sure, thanks for the tip!
KManZ is offline   Reply With Quote
Old 12-29-2012, 05:54 PM   #52
flk
Member#: 280838
2016 S4/GT4
Originally Posted by SPTTuner View Post
i foamed the crap out my rear deck and noise has 80% stopped...i think the rest of the noise might be the both sections of the C pillar... going to check that tomorrow
After I took care of the rear shelf, I was still getting some rattles from the C-pillar. I fixed it by doing this:
Originally Posted by KManZ View Post
I've been attempting to track down the worst ****ing rattle in my '12 sedan... I've performed this tutorial twice already, I've stuffed more dense foam up under the rear deck lid as can be stuffed under a rear deck lid, and am still plagued by this creaking. It sounds like a tinny, higher pitched creak, not so much a vibration. Every little bump, side-ways motion, even louder than normal farts set the creaking off, and i can't take it anymore.
So I hired my roomate to ride in the rear to narrow down the cause, and I believe I've found the answer: the rear seat, namely the 2/3rd's side, is rubbing against the rear deck lid, causing the noise. I folded down the seats, and the sound isn't there. The smaller side in place, no sound. The bigger side: BAM! Annoying-as-**** creak returns.
The creaking is very annoying over bumpy roads. Here's what I did to fix:
Originally Posted by yudangorgor View Post
with the car lowered now, my front dash is rattling and squaking.. is there a write up tutorial on how to remove the components of front dash?
I found out it was not my front dash, rather the A pillars. Take them off then put stickies around the edges like how I did the C pillar, with focus on the tabs that fit into the dash itself. Hope this helps!
flk is offline   Reply With Quote
Old 01-07-2013, 12:13 AM   #53
cambios12
Member#: 319866
2012 WRX Limited
To the op, thanks for the write up. Did my rear deck today with foam trim and dynamat. Huge difference, and more importantly, no rattle! I have a decent sub setup and the rattle was annoying as all hell.
cambios12 is offline   Reply With Quote
Old 02-01-2013, 02:57 PM   #54
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Originally Posted by rex.effect View Post
Any updates from people who dynamat'ed the whole rear shelf? What about matting the c-pilars? I am not trying to avoid doing it a cheap way, rather want to sound deaden most of the rear anyway.
Did any complications arise when matting the whole area? Are there certain locations I should avoid so that the shelf returns to it's place properly?
I have Dynamat on the entire rear deck and C pillars and it still rattles like crazy. The rattles are due to plastic-on-anything contact and are only solved by placing foam or something soft for those pieces to contact in between the plastic and whatever else it was touching.
The rear deck transmits a lot less noise, but it did not 'fix' the rattles.
Tyrial is offline   Reply With Quote
Old 02-01-2013, 03:25 PM   #55
flk
Member#: 280838
2016 S4/GT4
^The rear deck needs spot treatment with felt between rear windshield and shelf, also foam tape between the front edge of shelf that presses against back seats (this completely eliminates creaking/rub sound for leather owners. Lay some towel/old underwear between the shelf and the rear deck and you're set. Also needs C pillar edge foam/felt, the part that meets the rear shelf and windshield.
Front A pillar edges need treatment like my post above. B pillars don't rattle for me. Door rattles need ensolite/foam per their website recommendations and it's all gone. With just those fixes you've eliminated 95% of all rattles.
Old 02-02-2013, 04:06 AM   #56
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
I've got my doors and a pillars done, will be working on the rear deck lid this weekend! Its amazing how quiet my car is by doing the doors with raamat, ensolite, and mlv.
I think I am going to do a solid layer of raamat on the deck lid metal surface and cover the inner side of it with ensolite along with felt tape on all the seams.
Now if I only had the courage to take out my carpet...
geddesk2 is online now   Reply With Quote
Old 02-02-2013, 03:50 PM   #57
Subirex09
Member#: 207880
2013 STi
Awesome SWP
So you are going to do raamat on the metal and the ensolite on the inside of the plastic rear deck cover?
That's a good idea if I am understanding correctly. When I did my '11 rex, I did both layers on the sheetmetal and ended up with a little higher of a rear deck cover than original because I couldn't get it to sit as flush as it was prior.
I will have to redo this job since I just traded in for a '13 Sti in Dec and I think I will take your approach this time.
One thing I did notice is that the Sti door speakers don't rattle anywhere near as much as the Rex's did, maybe they took out those little white boxes in the doors everyone always talks about.
Subirex09 is offline   Reply With Quote
Old 02-04-2013, 12:21 PM   #58
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Nope, those crush boxes are still there and annoying as
Old 07-11-2013, 10:21 PM   #59
SpartanSTi
Member#: 286884
2011 STi Sedan
great write up! Thanks
SpartanSTi is offline   Reply With Quote
Old 10-12-2013, 07:33 PM   #60
dragoryte
Member#: 277733
2011 STi 4D
Silver Spark Metallic
I am having trouble getting the rivets to line back up when putting it back in. Did anyone else have that problem and if so, what are your suggestions?
dragoryte is offline   Reply With Quote
Old 05-09-2014, 04:06 PM   #61
xxKnight48xx
Member#: 368492
2012 Impreza WRX
Bumping for anyone new with this issue, I followed this write up and im 99% sure that the issue is gone. Do yourself a favor and spend the $10 on the foam tape and take the shelf apart. Cover anything you might think may make contact and do the point in the OP as well. Also it may help to put some on your C pillars as well.
Great write up, thanks!
xxKnight48xx is offline   Reply With Quote
Old 08-17-2014, 05:38 PM   #62
wicked_ink
Member#: 394277
2011 WRX sedan
Just finished doing this to my 2011 sedan. No more rattles!
Thanks OP!
wicked_ink is offline   Reply With Quote
Old 08-23-2014, 02:04 AM   #63
2000gm
Member#: 347333
2013 WRX
WR Blue
I got lucky with my 2013. I noticed that the rear edge of the 3rd brake light housing (the edge facing away from the window) was able to be lifted up so it was free to rattle against the shelf cover. I jammed a piece of oil absorbent pad between them and now my rattle is gone. Of course, I only have 17,000 miles on it so I'm sure others will come out sooner or later.
2000gm is offline   Reply With Quote
Old 02-08-2015, 12:03 PM   #64
atxgravity052
Member#: 408982
This is by far the best write-up I've seen for rear deck rattle! Made it easy for me to take care of my cringe-inducing rattles, even after installing a sub. Thanks for the post!
atxgravity052 is offline   Reply With Quote
2011 Impreza/WRX/STI Spoilers Buy/Sell/Trade NotSoStock11 Private 'Wanted' Classifieds 51 08-16-2016 12:09 PM
2011 Subaru WRX STI Sedan vs. 2007 STI AVANTI R5 News & Rumors 42 01-18-2011 10:47 PM
The wing returns! Subaru teases 2011 Impreza WRX STI sedan wrxposer Vancouver Impreza Club Forum -- VIC 103 04-25-2010 11:46 PM
2011 Subaru Impreza WRX STI Sedan Ryan314 News & Rumors 30 09-09-2009 03:29 PM
FS: NorCal JDM WRX/STI sedan rear windshield with rear wiper Seranin Exterior/Styling 8 12-06-2006 12:31 AM
