Old 01-23-2011, 05:40 PM   #1
vermont22gt
Member#: 234054
97 Frankenwagon
Default EJ18 injector flow
Anyone know how many cc's the ej18 injectors flow?
vermont22gt is offline   Reply With Quote
Old 01-24-2011, 09:55 AM   #2
vermont22gt
Member#: 234054
97 Frankenwagon
Bump....Anyone?
Old 01-24-2011, 12:17 PM   #3
JoshP
Member#: 94350
Im sure this wont help you at all, I want to say 480 or 520
JoshP is offline   Reply With Quote
Old 01-24-2011, 03:55 PM   #4
vermont22gt
Member#: 234054
97 Frankenwagon
Thanks anyway, but that can't be right.
Old 01-24-2011, 03:58 PM   #5
renyo
Member#: 93577
98 Impreza
I think the 2.2 injectors are 280 if that helps at all.
renyo is offline   Reply With Quote
Old 01-24-2011, 04:31 PM   #6
2.5ReallySexy
Member#: 167943
So they flow equal to wrx injectors. Nope
2.5ReallySexy is offline   Reply With Quote
Old 01-24-2011, 07:02 PM   #7
JoshP
Member#: 94350
I guess what I meant was 280 or 320. My mistake.
Old 01-27-2011, 07:53 PM   #8
meat_WRX
Member#: 96919
2004 sti
black
I guess what I meant was I have no idea and just wanted you to boost on your stock injectors thinking youd be ok, when infact, you will blow your shyt up. My mistake.
right?
meat_WRX is offline   Reply With Quote
Old 01-27-2011, 08:11 PM   #9
vermont22gt
Member#: 234054
97 Frankenwagon
HaHa. Does anyone REALLY know?
Old 01-29-2011, 10:20 PM   #10
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
ask Deatschwerks they should know.
stickfiguredanny is offline   Reply With Quote
Old 02-01-2011, 07:23 AM   #11
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
They flow 280 cc/min. Actually the same flow rate as 1989-1998 EJ22 and EJ25D.
Marnix is offline   Reply With Quote
Old 02-03-2011, 11:09 AM   #12
St.Schultz
Member#: 183694
89 Vanagon w EJ22
The gray ones are 280cc and the red ones are 285cc.
St.Schultz is offline   Reply With Quote
FS: 4 sets of Modded WRX Injectors-Flow tested and cleaned with flow sheet ScoobyNubieToo! Engine/Power/Exhaust 22 05-19-2008 10:11 PM
ej18 injector size jkjersey Subaru Conversions 14 03-31-2005 04:48 PM
EJ18 injector info, new (almost) drop option, not SR20's sick1.8t Normally Aspirated with bolt-on Forced Induction Powertrain 10 02-07-2005 05:02 PM
What is the size of the stock EJ18 injectors? Blugin Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-26-2002 04:09 AM
WRX Injector Flow Rate @ Idle Fuel Pressure HndaTch627 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-29-2001 01:21 AM
