Old 07-09-2002, 04:29 PM   #1
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Default .028 gap for spark plug?
The place where i got my car dyno-tuned (Brainstorm) said to gap my spark plugs at .028 but i was researching the board and no one seems to go this low. Any comments? FYI my plugs are NGK BKR7E-11
Sid
GimmeScoobySnacks is offline   Reply With Quote
Old 07-09-2002, 04:32 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Uh, no.
Stock gap is specced .040-.044". IIRC, you were supposed to close the gap .004" for every 75hp. I run mine in the .036-.038" range when turbo'd.
Old 07-09-2002, 11:20 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I run mine at .035 or so. You shouldn;t have any problem with flameouts at this gap, especially with the subaru ignition
Eric
Eric SS is offline   Reply With Quote
Old 07-10-2002, 01:05 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I run 12+ psi with NGK BKR7EVX11 gapped at 0.035 but my old Denso Iridium came gapped at 0.028 and they worked fine too.
ImprezaRS dot com is offline   Reply With Quote
Old 07-10-2002, 08:09 AM   #5
Austin
Member#: 7089
2016 STi
I've gapped from .024 to .032 on the wrx, and the car ran fine.
Austin is offline   Reply With Quote
what is the best gap size for spark plugs? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-13-2003 08:06 PM
Complest pictorial for Spark Plug change. ChosenWon Normally Aspirated Powertrain 3 07-02-2001 03:41 PM
Inline capacitors for spark plugs Tony Normally Aspirated Powertrain 26 01-04-2001 10:09 AM
Silver core is best for Spark Plugs? HRE | giulio Technical Forum Archive 5 10-12-2000 12:50 AM
