Old 01-23-2011, 06:23 PM   #1
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
Default car won't start!
Just came back from Costco this afternoon and the car (2004 Impreza TS)
won't start. The battery is fine and have lots of power, the starter turns fine, but i suspect there is no fuel getting to the engine. The fuel pump was not priming before cranking. After 30 + mins of trying in -17 oC temperature, we heard this familiar sound of the fuel pump priming, and started the car successfully!
What could have gone wrong/defective? Fuel pump relay?
I need to sort this out ASAP. This is my wife's car and I need to assure her that everything is in working order.
Any suggestions?
BTW this is the first time this car has ever failed us. Owned it since new.
Thanks in advanced.
04ts is offline   Reply With Quote
Old 01-23-2011, 08:22 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
maybe there was a little bit of water in the pump. After a while of trying to get it to go, it warmed up.
yarrgh is online now   Reply With Quote
Old 01-23-2011, 08:32 PM   #3
Jeterkm02
Member#: 77133
95 240sx
Double check the battery connections?
Jeterkm02 is offline   Reply With Quote
Old 01-24-2011, 12:40 PM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
and the connections to the fuel pump itself. Look for loose and/or corroded connections.
Samirr76 is offline   Reply With Quote
Old 01-24-2011, 01:06 PM   #5
prezarevo
Member#: 266930
2004 WRX
well since one other member got bitched at for "cross posting" i figured id use this one because it's the original "car wont start" Well..Car wont start. It was turning over slowly. I threw the cables on it. cranked it over. it turned over fast how ever, it's blowing out the intake and also fires sporadically. I know it's not the fuel pump because i'm smelling raw fuel and i can hear it. Though my exhaust smells like ****. i like to run 93 in my car. it's winter and i dont want to risk ****ty fuel. so i buy 93. well for the one time i did put regular in it..it doesnt start!!!
prezarevo is offline   Reply With Quote
Old 01-24-2011, 02:02 PM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
OP: Could be clogged fuel filter (ever changed it?), or traces of ice in the fuel system. What maintenance have you done on it?
Prezarevo: 93 fuel is useless for your engine IMHO, 87 isnt by any means "****ty". The questions does remain about maintenance though. In your case it would seem the problems are more alongside the sparks/coil pack
Blowing out of the intake though?
Old 01-24-2011, 03:04 PM   #7
prezarevo
Member#: 266930
2004 WRX
well I found my issue. my timing belt jumped. loaded the intake up with a shot of starting fluid. (yes I know its bad stuff but it worked with a struggle). it fired up and barely idles. sounds like its cammed out
Old 01-25-2011, 09:49 AM   #8
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Glad you found the problem... but why did it jump? Old and streched, bad tension?
Old 01-25-2011, 12:34 PM   #9
prezarevo
Member#: 266930
2004 WRX
I honestly do not know why it jumped. its not due for replacement yet. I have one theory why. Maybe the cold had somthing to do with with the tensioner giving a little?
Car won't start and CEL won't illuminate DiscoGsus Normally Aspirated Powertrain 5 04-14-2010 10:19 PM
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2008 09:18 PM
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2007 10:29 PM
Car won't start, but won't turn off BigBlueSVX Legacy Forum 4 08-22-2007 10:23 AM
Car won't start. Won't crank, but lights will turn on Gorge Service & Maintenance 9 01-09-2007 01:23 AM
