South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 05-01-2001, 08:31 AM   #1
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Question 15k service
Well, I didn't take it in for the 7500, but feel like I should take it in for this one. Maybe I'm warranty paranoid, but I want to do it by the book.
How much does this cost anyway?
Matt is offline   Reply With Quote
Old 05-01-2001, 09:17 AM   #2
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Post
I'm just about to hit 30K, and did my own 30,000 mile checkup this past weekend. Couldn't tell you how much the dealer might charge.
I did:
New plugs - NGK
Change oil & filter - Mobil1 & a Bosch 3310
Clean K&N air filter
Flush & Change brake fluid - Castrol GTLMA
Flush & Change coolant - Havoline Dex-Cool
Change tranny oil - Valvoline Durablend
Change Rear diff oil - Valvoline Durablend
Changed fuel filter
Changed wiper blades
Checked the brakes (pads, calipers, etc.)
Checked the suspension (struts, bushings, etc.)
Checked axles (CV boots, bearings)
Topped off clutch & power steering fluids
Checked battery (water)
This all cost me less than $90 and only took a few hours to complete. The only "recomended" service the dealer will perform will be the 60K checkup. And that's just because I don't feel like changing the timing belt myself!
Opie is offline   Reply With Quote
Old 05-01-2001, 09:28 AM   #3
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
Post
As far as the warranty goes, it doesn't have to be serviced at the dealer. You can do it yourself, just keep the receipts (to prove that you did it) and write down your mileage. Maybe even post the info on the Subaru mysubaru web page so that its semi-official. At least, I think this should be sufficient. Since I only have about 4k miles left on my warranty, I am not too concerned.
ForesterPerformance is offline   Reply With Quote
Old 05-30-2001, 06:45 AM   #4
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question
I'm bringing this topic back up since I'm approaching 30k. I have a few questions for all of you since I'll be doing this myself.
What brand fuel filter and wiper blades do you suggest?
How do I go about checking the bearings and what should I look for?
Where do you drain and fill the rear diff. oil?
TIA,
-Mike.
mpaone is offline   Reply With Quote
Old 05-30-2001, 07:24 AM   #5
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Post
The fuel filter I used was a Purolator (sp) and the wiper blades were Bosch Micro edge.
You drain & fill the rear diff using the 2 plugs an the back of the rear diff. the plugs take a 1/2" drive ratchet, the lower one is to drain the diff. the top one is to fill the diff.
As far as checking the bearings, do you hear any unusual noises while driving? If not chances are everything is good. If you want to be sure have your dealer check those. Visually checking the bearings & brakes and axles will cost much less than doing the full 30K service.
[This message has been edited by Opie (edited May 30, 2001).]
Old 05-30-2001, 07:28 AM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
Smile
when ya change the timing belt? or haveyou? how much did that cost?
Brian
bratmantlz is offline   Reply With Quote
Old 05-30-2001, 08:01 AM   #7
Matt
Allergic to turbos
Member#: 181
2009 Forester
Have a Nice Day?
I got destroyed on my 60k service--$780. The 30k service was about $350. Reasonable, but still a little pricey.
Needless to say, I'll go back up north to my independent Subaru shop for any services on my Impreza. It just seems like a ripoff to me. I just got an oil change for the 15k service.
And I'm sure as hell not taking the Brat to the dealer.
Old 05-30-2001, 10:22 AM   #8
mpaone
Member#: 3
2012 Geeteeeye
Thumbs up
Thanks Opie!
brat, I think the timing belt is 60k.
This shouldn't cost me close to the $350 the dealer quoted me. Part of that is because I replaced my front and rear brakes (along with the fluid), my strut tops, oil and filter, plugs and (cleaned) air filter recently.
The only stuff I haven't covered was the tranny, diff., power steering and clutch fluids and the coolant and wiper blades.
I'll probably take care of this stuff on Saturday.
-Mike.
Old 05-30-2001, 11:56 AM   #9
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Talking
Holy Cow! I just checked the Maintenance Scheadule for my RS and it says the timing belt (it actually says "drive belts") doesn't get replaced until the 105,000 mile service! Wow!
('93-'01) 15k service....how much should it cost? 4ontheFloor Impreza Forum 11 08-29-2001 05:34 PM
15K service skeisenb South East Region Forum 2 08-07-2001 11:01 PM
('93-'01) what is BG motor oil additive? 15K service manifest says they add it but i run synth nkodemus82 Impreza Forum 6 04-23-2001 09:37 AM
15K service today, advise for current RS owners JJTheSubeDriver Normally Aspirated Powertrain 5 01-12-2001 01:52 PM
15k service $$ Ragstylz General Forum Archive 5 10-15-2000 03:57 PM
