Old 01-24-2011, 09:57 PM   #1
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
Default Choice of fuels....93 w/ethanol or 91 ethanol free????
which would you choose? go for the 2 higher octane points with the 93 and 10% ethanol added or go with the 91 octane and no ethanol? mpg wise? tune? what do you think is better?
josh
jrrevo1 is offline   Reply With Quote
Old 01-26-2011, 01:57 AM   #2
acke61
Member#: 226553
2003 mkIV vw
no ethanol every time
acke61 is offline   Reply With Quote
Old 01-26-2011, 08:15 AM   #3
jleable
Member#: 266105
2011 WRX
no ethanol, you will get better gas mileage
jleable is offline   Reply With Quote
Old 01-26-2011, 08:29 AM   #4
blindgoldfish z
Member#: 218009
2011 WRX 5-door
Great question. I've wondered the same thing as we have both around here as well.
blindgoldfish z is offline   Reply With Quote
Old 01-26-2011, 08:52 AM   #5
soup_notzee
Member#: 245074
2008 WRX stg 2
Satin White Pearl
I wish I could find a station with no ethanol. Every one I've seen here in NY is "atleast 10% ethanol"
soup_notzee is offline   Reply With Quote
Old 01-26-2011, 09:31 AM   #6
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
93 with 10% ethanol.
stretchedk7 is offline   Reply With Quote
Old 01-26-2011, 09:41 AM   #7
blindgoldfish z
Member#: 218009
2011 WRX 5-door
What is your rationale for this?
Old 01-26-2011, 10:07 AM   #8
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
Its federal mandate for stations to have ethanol. non ethanol consumer grade fuel is no longer available
Non ethanol fuel may only be available at race tracks.... but I don't know because I don't go to tacks.
polarisboy385 is offline   Reply With Quote
Old 01-26-2011, 10:19 AM   #9
soup_notzee
Member#: 245074
2008 WRX stg 2
Satin White Pearl
So where are these people finding non-ethanol? ONLY at race tracks??
Old 01-26-2011, 10:20 AM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
my reasoning for the answer is if your two options are 91 with no ethanol and 93 with 10% then the 93 is better period. Thats whata I run and thats what is available where I live. Knock and det wise the 93 is better.
Old 01-26-2011, 11:33 AM   #11
rkramer
Member#: 118209
2015 WRX Limitec
umm, might want to do a road trip sometime... I buy non-ethanol fuel every day. Many states also have labeling laws for gas contents, so you know what you are actually buying. (new york also has a labeling law, so if it doesn't explicitly say contains ethanol at the pump, it doesn't.)
There is no federal mandate that e10 must be used, period. What does exist are the clean air laws, as well as biofuel minimum quotes for states. The clean air laws apply differently to different areas, and the biofuel standards can be met in other areas.
Old 01-26-2011, 11:52 AM   #12
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
I stand corrected. I did a quick search,, a lot of states have faught and won the requirement. Apparently the epa was trying to make it federal across the nation. It looks like cali and washington have won the right to revoke the ruling. So once again..... I apologize and stand corrected
Old 01-26-2011, 11:57 AM   #13
soup_notzee
Member#: 245074
2008 WRX stg 2
Satin White Pearl
another reason to hate NY.... I want ethanol free!
Old 01-26-2011, 01:31 PM   #14
heavyD
Member#: 194216
2016 MK7 Golf R
If your car is 100% stock you may save yourself a couple of bucks with 91 ethanol free as you will get slightly better gas mileage. However if your car is modded/tuned 93 + 10% ethanol is easily the better choice. The BTU content may be lower but once you raise the boost over stock levels it's all about using the highest octane fuel possible to prevent knock especially if you are using something like a Cobb OTS map which is a generic tune and not specific to your car or elevation, weather, etc.
heavyD is offline   Reply With Quote
Old 01-26-2011, 02:20 PM   #15
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
I personally do 93 and stayed away from gas stations with 91 because I had no idea 91 was ethanol free.... I might just try it next time!
G_REX is offline   Reply With Quote
Old 01-26-2011, 03:20 PM   #16
4-n-zics
Member#: 228961
2016 4Runner TRDP
a very large amount of gas stations in south central Oklahoma have up to 91 octane, but with 0 ethanol. I tried my hardest to find 93 octane, ended up having to use 91 with no ethanol. I got better gas mileage and didn't hear any knock.
4-n-zics is offline   Reply With Quote
Old 01-26-2011, 04:48 PM   #17
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
I try to get 91, ethanol free if possible. But when it comes down to it, my car really doesn't care either way.
ganzhimself is offline   Reply With Quote
Old 01-27-2011, 11:03 AM   #18
bluemk3
Member#: 263694
World Rally Blue
its not neccisarily. in fact if the same station has both. most likely its gonna have it
bluemk3 is offline   Reply With Quote
Old 01-27-2011, 01:31 PM   #19
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
I guess if you're 100% stock, then 91 would be OK. Personally for me, even for the short period of time my car was stock, I run the highest pump octane I can find which is 93 around here.
FCmaniac is offline   Reply With Quote
Old 06-23-2011, 11:05 AM   #20
TTown1983
Member#: 151165
2009 WRX Stage 2
WR Blue
I found this website when I was looking for ethanol free fuel for my ATV's...
www.pure-gas.org
It has a listing of all the stations that have ethanol free fuel by state. Hope this helps...
TTown1983 is offline   Reply With Quote
Old 06-23-2011, 11:26 AM   #21
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Wish I could find 91 at all... so it's 93 with 10% E for me.
jonklein611 is offline   Reply With Quote
Old 06-23-2011, 11:29 AM   #22
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
You buy fuel every day?
Gallo2011 is offline   Reply With Quote
Old 06-23-2011, 12:17 PM   #23
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
I run whatever I can get, there is one station in the area that I know of that sells 93 without ethanol, the others are 91 with no ethanol, and then there are a few 93 with 10% and the Renew E-85 stations that have "Super 93" with 20% ethanol. In the spring and summer the difference is negligable as far as MPG goes. Honestly the car seems to run best on the Super 93 E20 blend than anything else. Maybe 1-2 MPG difference, but it has been working out to cost $.10-$.15 a gallon less after working in the MPG difference.
Old 06-23-2011, 09:57 PM   #24
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
there's 1 station up here that has non-ethonal "recreational fuel". not sure what octane it is though, didn't say.
Meat Supply is online now   Reply With Quote
Old 06-23-2011, 10:02 PM   #25
n2oiroc
Member#: 141952
15 legacy 16 wrx
hey guys, 93 with ethanol is still *gasp* 93 octane. its superior to 91, dont be stupid.
n2oiroc is online now   Reply With Quote
FS : FREE box of Legacy junk 91-94? FREE bape-ape TXIC Private Classifieds 0 07-25-2010 12:08 PM
Sex with any girl of your choice 5x, or your choice of any one car with insurance -=C=- Off-Topic 184 01-10-2010 09:02 PM
Cobb Stage 2 91 or 93 Map in OR/WA jjimpreza North West Impreza Club Forum -- NWIC 28 04-25-2006 02:06 AM
AP 93 or 91 octane questions drfrink24 Engine Management & Tuning 3 05-31-2005 11:59 AM
choice of color? Silver or White or Blue? sshus924 Interior & Exterior Modification 39 05-07-2004 05:35 PM
