Old 01-24-2011, 11:39 PM   #1
99outback
Member#: 142634
Question 99 outback engine problem....
I have a 99 outback, with the 2.5 engine in it. The problem is while I am driving. I will be driving on the freeway, and the check engine light will come on, power seems fine, until I take the exit and come to a stop. It will just start to bogg out, then die. I restart it and it idles really rough. almost like it's running on two cylinders. Then while tring to start moving, it has almost no power. I have checked under the hood, and everything seems to be in working order. I have no idea what it could be! please help!
99outback is offline   Reply With Quote
Old 01-25-2011, 07:49 AM   #2
renyo
Member#: 93577
98 Impreza
Get the code read
renyo is offline   Reply With Quote
Old 01-25-2011, 12:13 PM   #3
99outback
Member#: 142634
It's kinda hard to do that. By the time I get to somewhere it get it read, it turns off
Old 01-25-2011, 12:21 PM   #4
renyo
Member#: 93577
98 Impreza
The CEL turns off, but the code is still stored.
Old 01-25-2011, 12:31 PM   #5
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
Sounds like your IACV. I've cleaned mine a couple times before finally replacing it. Pull it off, spray some carb/brake cleaner to get all the soot off. And manipulate it in/out a few times. Should do the trick, if not time to look for a new/er one...
HeyChris is offline   Reply With Quote
Old 01-25-2011, 09:03 PM   #6
99outback
Member#: 142634
Thanks! I will check that out and let you know!
EJ25 99 RS engine problem halightw Normally Aspirated Powertrain 6 06-17-2008 12:39 PM
99 Outback Engine Temperature brianecarlson Normally Aspirated Powertrain 7 07-27-2005 07:32 PM
99 Outback head gasket problem ? JPC Outback Forum 6 08-27-2004 10:02 PM
99 Outback engine problems Deadeye Outback Forum 0 01-30-2004 02:44 PM
98-99 = Impreza engine problems? dugrant153 Vancouver Impreza Club Forum -- VIC 23 09-27-2003 03:34 AM
