Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 07-09-2002, 08:22 PM   #1
spacemonkey
Member#: 16435
Default pricing on a wrx engine swap
Attention moderator: not really sure if this goes in this forum or factory forced induction
but i am just doing some preliminary research for the possibilitie of doing an engine swap. besides the obvious motor, tranny, axles, etc... what else is required/ recomended? has anybody accomplished this yet even? shopping around for engines and trannys the best deal i've seen is in the 5k range. does that seam steep? to little? I'm just looking for imput. thanks guys.
spacemonkey is offline   Reply With Quote
Old 07-09-2002, 09:15 PM   #2
christoph1371
Member#: 1090
Monkey: It will be in your best interest to do a search before you ask such really easy questions.
FYI the infor mation you seek is all around here even my unfinished site i-speedusa.com
chris
christoph1371 is offline   Reply With Quote
Old 07-10-2002, 12:52 AM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Going price around here is $4,500-$5,000. I emailed you.
garface is offline   Reply With Quote
Old 07-10-2002, 02:06 AM   #4
spiralsmurf
Member#: 16085
2005 STi
search on ebay for wrx motors and you'll find two people in oregon selling them for around $5000.
spiralsmurf is offline   Reply With Quote
Old 07-11-2002, 12:42 AM   #5
Skylab
Member#: 4263
Check out the Bay Area Forum and look for Cristoph.
Skylab™
Skylab is offline   Reply With Quote
Old 07-11-2002, 06:20 AM   #6
XT6Wagon
Member#: 524
04 STi
Well mine was under $3K with everything but I did ALOT of reserch on my own, and settled for a STi Version 1 driveline which isn't all that great compared to the later ones.
XT6Wagon is offline   Reply With Quote
Old 07-11-2002, 04:43 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
there is other much cheeper sources
i have been shopping i talked with john at outback motorsports he said that he had 20+ ej20s in stock ..normally they sell them to go into sand rails but they would bolt in to an impreza/legacy/forester with no problmes..
motor+preprogramed link+harness ~2500
i just need to find a body to put somthing in...
Old 07-11-2002, 05:16 PM   #8
christoph1371
Member#: 1090
no matter what you use, remember what you are doing it for and how long you want that car. Those two factors will help you pick your set-up.
Old 07-11-2002, 08:18 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
And if your in california you have to remember to pass smog. So much easier just to grab a wrecked usdm wrx.
Old 07-12-2002, 05:39 AM   #10
Shinji N
Member#: 3987
1999 Miata
Originally posted by ciper
And if your in california you have to remember to pass smog. So much MORE EXPENSIVE to grab a wrecked usdm wrx.
*sob* *sob*
Shinji N is offline   Reply With Quote
Old 07-12-2002, 06:14 AM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
And you dont HAVE to replace the tranny/rear diff... You can just drop the engine/ecu/wiring harnass in with the new crossmember or whatever that thing in there is that needs changing when you put a WRX engine in
Old 07-12-2002, 09:20 AM   #12
XT6Wagon
Member#: 524
04 STi
Hate to disagree, but you DO have to replace the tranny in anything other than the SVX, Impreza, Forester, Legacy, and Outback. Of course there is no way in hell it will go in a justy so lets just forget that one.
But the older cars like the Loyale, RX, XT, XT6, etc. use a different bellhousing pattern so you would need an adaptor. They were made once opon a time, but it was $300 for the couple left in the world a year or two ago.
Old 07-12-2002, 10:08 PM   #13
Skylab
Member#: 4263
Question
About the smog thing. Would a stock EJ20 in an older bodied RS pass of fail an emissions test? Visual? It would pass the physical, it's a stock motor! (?)
Skylab™
*Still in the planning stage*
Old 07-12-2002, 10:19 PM   #14
christoph1371
Member#: 1090
I just (7/10)passed CA stat referee...SMOG with my jdm upipe, FP turbo and stock wrx exhaust . Oh yeah, this was all on my 97 OBS conversion.
My car is completely legal by CA standards. They even put a sticker under the hood by the vin that wards off pesky smog stations and police who think I have aftermarket goodies
Old 07-15-2002, 03:48 AM   #15
Digital_Boy
Member#: 730
Skylab,
A 2002 USDM WRX motor swap is 100% legal. I've called CARB, and the gist of it is this:
Newer engine into older car, (assuming all smog equipment is installed too), is okay.
Older engine into newer car is not okay.
We're getting ready to swap a WRX drivetrain into a white RS at the shop right now.
Digital_Boy is offline   Reply With Quote
Old 07-15-2002, 04:10 AM   #16
christoph1371
Member#: 1090
I never even thought of doing swaaps into Loyale, RX, XT, XT6 hmmmm?
Old 07-15-2002, 10:33 AM   #17
XT6Wagon
Member#: 524
04 STi
Someone else and I are both doing a swap right now. He is using a 87 RX I think (3dr), and I am using a GL-10 Wagon (shell laying around).
The thing is really annoying, but on the good side most of the WRX wiring runs through stock openings. Also its plenty long so the underhood fuse box can be located in the fender. This is important since the battery tray would be useless with it there.
Other highlights
Driveshaft needs to be shortened.
Tranny mount needs to be done custom (looking at XT6 front tranny X-member soon to see if its a bolton)
Pedals need custom mounting, and legacy gas pedal needs the firewall cut and then rebuilt as the spare tire tray is in the way.
Old 07-15-2002, 02:07 PM   #18
christoph1371
Member#: 1090
remember to document every detail. pics and notebooks help... A Lot
Old 07-15-2002, 02:38 PM   #19
aek
Member#: 13888
2002 2.5 RS Black
:( sold ( now GC8 )
Cristoph and Digital_boy:
Do you guys know how hard it is to swap in EJ20 into MY02 RS ??
Do I have to replace the the original 4EAT tranny ?
thanks!
aek is offline   Reply With Quote
Old 07-15-2002, 04:03 PM   #20
christoph1371
Member#: 1090
What do you want man/auto?
the engine and tranny must match either way.
nope. i have never done a 4eat to '02. it should not be as difficult as the pre 02. I'd have to perform it to be completely accurate.
02 wrx or 05 wrx Engine swap juscool Subaru Conversions 5 08-29-2009 09:45 AM
96 impreza with wrx trans brakes, and wheels 3500 just needs wrx engine swap va beach valdezwhite02 Private Vehicle 'For Sale' Classifieds 0 08-28-2009 06:19 PM
is this a stupid question on wrx engine swap? newbiescooby2.5rs Newbies & FAQs 1 08-16-2005 04:06 PM
Any info on impreza's with engine swaps? FrostByte7 General Community 11 05-08-2002 06:07 PM
('93-'01) price on an sti engine/tranny swap into RS Krelkor Impreza Forum 4 10-12-2001 02:09 AM
